Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 04-29-2011, 06:30 PM   #1
Tony Travers
Newbie
Default More 1/4 elliptic rear suspension questions
G'day
I'm planning a small light vaguely lakes inspired T. I've looked at ways to get the chassis lower than traditionally but don't want to step the rear and have decided one option maybe rear 1/4 elliptics. I've searched the HAMB and I a question. Why do I need a shackle or an eye on the axle?
On the assumption my chassis rails aren't parallel so it tapers from front to rear about 6" if I ran rear 1/4 elliptics they would likewise be wider at the rear. Why can't I mount them fixed at each end without an eye or shackle. The vertical movement (yes I know the rear axle would be traveling in an arch) would be no different to so called NASCAR truck arms, the side ways movement would be contained by the splayed layout and any body roll would be minimized as the springs would twist and resist it. I don't think the springs would wind up any worse than a set up with top arms - I'm not planning any big power. I saw a pic of a '20's something Buick (?) that was not unlike what I'm proposing but it would have had a torque tube.
Cheers
Tony
offline   Reply With Quote
Old 04-29-2011, 06:48 PM   #2
Ghost28
Old School HAMBer
Ghost28's Avatar
Default Re: More 1/4 elliptic rear suspension questions
I don't know if I could answer your question, but here is a 26 buick rear assembly.
Old 04-29-2011, 06:51 PM   #3
Ghost28
Old School HAMBer
Ghost28's Avatar
And another. The buick mounting at the axle is a rotating unit that with the torque tube is needed, but with a u joint setup on your third member it most likely would not be needed. I am gonna use this same stock setup in the 26 but without a torque tube rear, but mount the spring on the bottom of the axle without the rotating part.
Click image for larger version
Old 04-29-2011, 07:00 PM   #4
Malcolm
Old School HAMBer
Malcolm's Avatar
Here's a couple shots of the rear QE setup on my Roadster chassis.
I think it's similar to what you are talking about --- no shackles.
Malcolm
__________________
www.instagram.com/hoesing
Old 04-29-2011, 07:06 PM   #5
Ghost28
Old School HAMBer
Ghost28's Avatar
Malcolm. I really like that setup. CLEAN
Old 04-29-2011, 07:08 PM   #6
FiddyFour
Old School HAMBer
you need the shackles due to the change in spring "length" relative to suspension travel... bind and broken springs will result otherwise
__________________
Custom "HF" bead roller dies
Tipping, body lines
PM for details...
Old 04-29-2011, 07:23 PM   #7
Malcolm
Old School HAMBer
Malcolm's Avatar
Quote:
I'm going to try to prove you wrong... we'll see what happens
__________________
Old 04-29-2011, 07:25 PM   #8
Tman
Old School HAMBer
Tman's Avatar
Two words TORSION BARS
__________________
Open for business, website in developement
www.compulsionrodandcustom.com
Old 04-29-2011, 07:30 PM   #9
FiddyFour
Old School HAMBer
Quote:
i like what i see, and i really, TRULY hope i am proven wrong bud
__________________
Tipping, body lines
PM for details...
Old 04-29-2011, 07:55 PM   #10
The37Kid
Alliance Member
The37Kid's Avatar
I was going to suggest you Google Bugatti GP or Type 40 for a photo of their rear spring setup, then I looked at Malcolm's photos. That setup looks very much like a Bugatti only the springs are in front of the axle. Is there a build thread on that chassis? Really like the looks of the tube work. Bob
__________________
Having the project is what makes me happy, finishing it isn't something I think about.
Old 04-29-2011, 07:59 PM   #11
The37Kid
Alliance Member
The37Kid's Avatar
That may be why the Bugatti setup has an oval eye in the main leaf that allows the bolt to slide back and forth a good inch if memory is correct. They had a torque arm that ran from the center section of the rear to the trassmission to center things.
__________________
Old 04-29-2011, 08:03 PM   #12
28dreyer
28dreyer's Avatar
Quote:
Originally Posted by Tony Travers View Post
G'day
...one option maybe rear 1/4 elliptics. I've searched the HAMB and I a question. Why do I need a shackle or an eye on the axle?
...the side ways movement would be contained by the splayed layout and any body roll would be minimized as the springs would twist and resist it. Cheers
Tony
Here's my Speedcar with a set of splayed 1/4 ellipticals with the axle end free to slide in a containment open ended box which is built on to the radius rod which also terminates with the big end of a connecting rod that allows the axle housing slight rotation during travel.
This is a torque tube drive line and we have included a panhard rod as the springs are narrow and the cornering forces high.
We have also mounted the spring and special U bolts to a pad that has a short piece of sawed off torsion bar welded to the pad that passes through a bushed spud welded through the tube frame with a splined torsion bar stop on the inside of the frame to provide ride heighth adjustment.
Are you in the Barossa Valley?
ID:	1308005   Click image for larger version
ID:	1308006   Click image for larger version
__________________
78 is too old to be driving a computer.I'm much safer in my midget getting in as many laps as I can.
Old 04-29-2011, 08:07 PM   #13
FiddyFour
Old School HAMBer
it would work, and WELL, if and if... both the spring and the bar move in a parallel arc and hit the apex at the same instant... i cant tell if nicks is going to be like that at ride height or no...
if im wrong, i;d rather be told what the reality is so then i know more than i do now
__________________
Tipping, body lines
PM for details...
Old 04-29-2011, 08:10 PM   #14
The37Kid
Alliance Member
The37Kid's Avatar
28dreyer, that is the exact same design used on a Type 59 Bugatti, much better IMO that the earlier oval eyed spring hole. Ever see a Dreyer Wiggle Front End, with two long springs and Model T Ford axle parts?
__________________
Old 04-29-2011, 08:15 PM   #15
Alliance Member
Mr48chev's Avatar
This T modified was in one of the recent Rod and Custom issues. Here are the photos I took at the Yakima Vintiques run last year.
It does have shackles because it runs split bones and the shackles keep the spring from binding as they don't act as a lower half of a fourbar.
This is a different modified with quarter elliptic springs on the front.
OSLYN05RUN062.jpg[/IMG]
Ok, I've been wrong for the past 7 years, the black car does have split bones with the spring mounted without shackles. I always had it in my mind that it used something more like the lower half of a fourbar so the spring acted as the top half. I'm inclined to think that the spring might want to bind a bit on this one.
It will work fine the way Malcom showed with his but with the split bones like the two I showed going without a shackle would probably cause the spring to bind.
__________________
Definition of a "work car". One you have to work on all weekend so you can drive it to work the next week.
Old 04-29-2011, 08:18 PM   #16
fossilfish
Alliance Member
fossilfish's Avatar
Just look at a 1959 Austin Healey Sprite rear axle assembly. They were 1/4 elliptic. One of the better road race designs ever. I am putting a version on my bobber. Works great for drag racing too...if you set it up properly
Old 04-29-2011, 08:20 PM   #17
Unkl Ian
Old School HAMBer
Unkl Ian's Avatar
Location: Just past the corner of Hell and The Twilight Zone.
You only need shackles if the axle is located by other means.
Four bar, hair pins, triangulated 4 link, etc.
If the springs help locate the axle, with no binding,
you don't need shackles.
__________________
Updated:
FlyingEyeballs.net
Old 04-29-2011, 08:22 PM   #18
FiddyFour
Old School HAMBer
read my next post... explains my thought better
__________________
Tipping, body lines
PM for details...
Old 04-29-2011, 08:38 PM   #19
28dreyer
28dreyer's Avatar
Quote:
This is a Dreyer 1/4 elliptical front end on a mid 30's Big car but propably not what you are referring to. Don't see any Model T parts here.
Notice the straight tubular front axle ala today's sprint cars and midgets. I'm not enough of a Dreyer person to know when he might have started doing that and how long it might have continued.
ID:	1308035   Click image for larger version
__________________
Old 04-29-2011, 09:23 PM   #20
jelp
FNG
jelp's Avatar
Jaguar MK11 cantilever rear suspension the front half of the springs mount inside the chassis rails a bit smoother than 1/4 ellipticals due to longer effective length
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
