Reply
Thread Tools Display Modes
Old 04-29-2011, 03:53 PM   #1
LoLife928
FNG
LoLife928's Avatar
Default 1950 ford shoebox engine swap 302 c4 tranny
fellow hambers,
i am in need of some info, swaping the old flathead for a 302 with a c4 transmission, does anyone know a step by step instructions on how to do this???? I would really appriciate any help...thanks brothers..
offline   Reply With Quote
Old 04-29-2011, 04:33 PM   #2
RG49MERC
Default Re: 1950 ford shoebox engine swap 302 c4 tranny
This is a very common swap..You will need a conversion kit..jamco,opies and few other companies carry these..it's very simple..it will require some welding on the crossmember for the trans mount..
Old 04-29-2011, 04:49 PM   #3
OlSkool50
Grenade Inspector
OlSkool50's Avatar
I used the Jamco kit in mine, It's all bolt in makes it easy. If you have any questions PM me. I"m just finishing mine up.
online   Reply With Quote
Old 04-29-2011, 04:56 PM   #4
smarg
Senior Member
smarg's Avatar
Here is the parts from Jamco their stuff is well respected here.
URL Here: http://www.jamcosuspension.com/products/productID/159
Hope the swap works out for you!
Also, join the shoebox group on here!
URL Here: http://www.jalopyjournal.com/forum/g...hp?groupid=127
__________________
Dyin' ain't much of a living, boy.
Old 04-29-2011, 05:08 PM   #5
tedley
Senior Member
tedley's Avatar
I made my own mounts, very simple. I even used the flatty mounts. I don't have pics right now but it's not hard to make. Trans is even simpler. I also used a front sump intead of the rear or center hump. Why? I knew i was going for a rack and pinion and the rear front sump gives me tons of room. Just have to notch the front xmember and box it, No big deal either. Use a rad with a top tank from a mustang or similar and mount it on the other side of the cradle for clearance. Stock mustang headers fit perfect as does the aftermarket mustang h pipe assy.Just get ridof the h pipe. Pretty simple conversion.
Click image for larger version
Name:	50 ford 012 (Large).jpg
ID:	1307883   Click image for larger version
Name:	50 ford 022 (Small).jpg
ID:	1307884   Click image for larger version
Name:	50 ford 026 (Medium).jpg
Name:	50 ford 008 (Medium).jpg
ID:	1307886   Click image for larger version
Name:	50 ford 027 (Medium).jpg
Old 06-21-2012, 09:43 AM   #6
Orlando1701
Grenade Inspector
Orlando1701's Avatar
I'm pulling the I-6 and dropping in a 302, the car is already running a C4 and has a Mustang II front end what should I expect?
__________________
"It never got weird enough for me." - Hunter S. Thompson
Old 06-21-2012, 12:19 PM   #7
msalamanca
msalamanca's Avatar
There is a decent pictorial on hotrod mag online
__________________
My 51 Shoebox build http://www.jalopyjournal.com/forum/s...d.php?t=599018
Old 04-09-2013, 10:34 AM   #8
whitecrown
FNG
Anybody out there done a 351 Windsor with a Tremec 5-speed into a '50 Tudor Custom? I bought it set up for a SBC/TH350 but I would rather run a Ford, not sure why, just seems right. Would really like to find a 406 & 4-speed for it but I haven't hit the lottery YET
Old 04-09-2013, 08:40 PM   #9
Buddy Palumbo
Senior Member
Buddy Palumbo's Avatar
You don't really need step-bystep instructions , it isn't rocket surgery ! Trust me , some things you've just gotta learn by getting your handas dirty .
That being said , I have done the SBF & c-4 swap into 2 Shoeboxes - my 49 and Legend544's 50 . With his , we used Opie's mount kit and with mine we used the Jamco setup . Both worked fine . You can see pics of mine in my build thread below . Somewhere here on the HAMB I posted pics of Craig's Opie's setup - if I find it , I'll post up ...
In my build thread , I also have pics of our rad setup too - out of a FoxBody Mustang . It works like a charm .
__________________
~~~~~~~~~~~ Allen
Click here for My shoebox build thread - "The Penny Pincher"
Old 04-09-2013, 10:08 PM   #10
5window
Old School HAMBer
5window's Avatar
Jamco's stuff may be good, but you're a tad off base saying they're respected here. Quite, quite the opposite. OP, PLEASE do a thorough HAMB search before you order, and pay for, parts from anyone, but especially Jamco. Really.
__________________
I never learned anything while i was talking-Larry King
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
