Go Back   THE H.A.M.B. > The H.A.M.B. Marketplace > Classifieds > Parts For Sale
Reply
Thread Tools Display Modes
Old 04-22-2011, 08:36 AM   #1
FoxSpeed
Alliance Member
FoxSpeed's Avatar
Default 1941 ford frame, same as 42-48 ?????
I have a WTB post for a 1941 ford passenger car frame. One potential seller has a 42-48 frame, he believes the 42-48 frames is the same dimensions as the 41. He lives too far for me to consider buying his frame, however, I was under the impression the 41 frame was a one year only. Are they interchangeable??
Thanks, Gary
__________________
" It takes me all night to do what I used to do all night"
offline   Reply With Quote
Old 04-22-2011, 08:59 AM   #2
Boeing Bomber
Senior Member
Boeing Bomber's Avatar
Default Re: 1941 ford frame, same as 42-48 ?????
Hey Gary, I got my '41 from an 81 year old hot rodder who knows more about these cars than I'll ever know. I'll ask him and find out. Usually it's just a matter of riveted on brackets. The front cross member may be a bit different, but can be modified. I'll let you know.
__________________
Beware of High Performance cars with Low Performance drivers
Old 04-22-2011, 09:09 AM   #3
krylon32
Alliance Vendor
I've done several 41 repro chassis using rails from a rail fabricator that claims they fit 41/48. I used the dimensions from a 46 chassis I have out back. I have so far had no negative feed back as I always tell the buyer that some brackets may have to be used from the original frame. I use Heidts Superride on the front and have done the rear with leafs or coilovers and straight 4 bar.
Old 04-22-2011, 09:41 AM   #4
fcarnut
Grenade Inspector
fcarnut's Avatar
If memory (?) serves me right the '41 is narrower on the front end than the '42 to '48. When i bought the Heidts front end I used the '40 member so the tires didn''t stick out to far. The Green Book shows some of the differences. The mounting of the rear running board brackets and the radiator brackets are just a couple of the differences. Good Luck in your search!
Tom
Old 04-22-2011, 09:49 AM   #5
Fordgasser1
Fordgasser1's Avatar
Good info to know..I am looking for a 41' frame too..
Old 04-22-2011, 09:54 AM   #6
fcarnut
Grenade Inspector
fcarnut's Avatar
When I first started on the car, the frame was butchered up. I ended up buying a Sedan project, took the frame and parted the rest out. At least you know that it's straight when you start.
Old 04-22-2011, 09:06 PM   #7
FoxSpeed
Alliance Member
FoxSpeed's Avatar
Would the only difference be body mounty locations?
__________________
Old 04-22-2011, 09:12 PM   #8
fcarnut
Grenade Inspector
fcarnut's Avatar
As I recall (?) the '41 was a narrower body than the '42 to '48. Could be wrong on this one? I could find frame dimensions for the '40 and the '42 but not the '41. I have seen a '41 front clip on a '48 at one time. Not sure what was required to pull this off.
Old 04-22-2011, 10:25 PM   #9
fordman67
FNG
41 had no front panhard bar also wheras 42-48 did.prob lots of small differences.
I hate to say it but I have seen several on fleabay lately....GOT to love these 41's...
Old 04-22-2011, 11:40 PM   #10
David Atkins
FNG
I have a 1941 Ford frame. I also have 42-48 Ford frames. I will be out at my barn Monday. I will take pictures to show the difference.
Old 04-23-2011, 06:58 AM   #11
skidmarks
Old School HAMBer
skidmarks's Avatar
chassis enginerring's catalog use to show the difference, like there is a early and late frame. i think the main difference is the center of the x member. one is rivited and one is welded. i think the body mounts changed alittle too.
online   Reply With Quote
Old 04-23-2011, 07:34 AM   #12
343w
Senior Member
343w's Avatar
I have a 42-48 frame in great shape in the classified, if you need measurements, or pics, PM me and I'll help you out. I realize it is also too far from Ca.to buy......
Old 04-23-2011, 09:51 AM   #13
hotrodhillbilly23
Grenade Inspector
hotrodhillbilly23's Avatar
I have a 41 short door coupe body that I sat on a '47 frame, my body was pretty bad, and had to replace all the lower sections anyway, so I just copied a '48 rockers and body mounts and it worked fine. I also used the '47 doghouse and everything lined right up, so I'd say they are the same width, biggest difference I saw were the X and the running boards and mounts ('41 is a one year only on the running board, but '42-48 boards can be modified to use.
Old 04-23-2011, 08:26 PM   #14
FoxSpeed
Alliance Member
FoxSpeed's Avatar
thanks David and 343W, that would be great. gary
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
