Reply
Thread Tools Display Modes
Old 04-16-2011, 04:56 PM   #1
sssraj
FNG
sssraj's Avatar
Default Need pictures of 1939 Ford Deluxe hood latch spring locations
Anyone have a 1939 Deluxe Ford that could post some detailed pictures of the hood latch springs and there location. I'm missing the springs and I do not see where they attach.
Thanks
Bob
offline   Reply With Quote
Old 04-16-2011, 06:18 PM   #2
Rod and Wheeler
Grenade Inspector
Rod and Wheeler's Avatar
Default Re: Need pictures of 1939 Ford Deluxe hood latch spring locations
There you go
Click image for larger version
Name:	40 FORD 015.jpg
Old 04-16-2011, 08:53 PM   #3
sssraj
FNG
sssraj's Avatar
Rod and Wheeler,
Thank you very much for the picture but I was looking for the hood latch springs. These are the hood arm supports. The hood latch springs are the springs that mount behind the hood ornament and handle up inside the hood.
Thanks again though,
Bob
Old 04-24-2011, 10:43 AM   #4
sssraj
FNG
sssraj's Avatar
I have an early style hood latch from what I'm told. I guess the 1939 deluxe had 2 different latches, an early style with the 2 "thick wire hooks" that latch on either side of the grill support and the late style which has a single center latch in the middle of the grill support.
I'm still trying to find where the 2 springs attach on the early style.
thanks Bob
Old 04-28-2011, 06:33 PM   #5
sssraj
FNG
sssraj's Avatar
I'm still looking if anyone has a 1939 Ford Deluxe with the early style hood latch that could take some pictures of the hood latch spring locations I would really appreciate it. Thanks
Old 11-15-2011, 09:30 PM   #6
hotrod_grmi
Alliance Member
hotrod_grmi's Avatar
Did you find the pictures you were looking for? I too have a 39 deluxe coupe and need pictures to see what is missing for my hood latch. I do not see the 2 springs you are referring to (not there) but think I see where they should be on the cross bar behind the grille and have no idea where they go to the latch. The car was modified some time ago and uses the center latch operated by a Lokar pull release cable kit and has the safety release latch. If you have anything such as pictures, illustration or parts list on the latch I would appreciate hearing from you.
thanks, Mike
Old 11-15-2011, 11:50 PM   #7
cryobug
Grenade Inspector
cryobug's Avatar
http://www.bobdrake.com/Drake_Tech_T...Linkge-DTT.pdf
online   Reply With Quote
Old 11-16-2011, 09:00 AM   #8
Dak Rat
Grenade Inspector
Sorry, I don't have the pics you requested, but yes there are two types of hood latch systems for the '39 deluxe. The early version with the two "wires" even uses a different grill cross brace at the top. What this means is that you can not swap parts back and forth without having the matching grille/hood. Dosen't help you much but could save some grief for thoes trying to swap hoods and grilles.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
