Reply
Thread Tools Display Modes
Old 04-15-2011, 08:56 AM   #1
coopsdaddy
coopsdaddy's Avatar
Default schroder steering
I see they have them with the steering coming out of the top and bottom,which one works the best in model a's.
offline   Reply With Quote
Old 04-15-2011, 09:37 AM   #2
silent rick
Alliance Member
Default Re: schroder steering
i don't think schroeder made them both ways. more than likely, you saw someone running one meant for right hand drive upside down so it comes out the driver's side.
__________________
selfish disgusting anti-social bad influence friend of the devil seeks an intelligent young hard belly with large breasts to dance naked for my amusement.
must ride on fender.
Old 04-15-2011, 09:47 AM   #3
Alliance Member
Mr48chev's Avatar
Are you talking the pitman arm or the steering shaft?
Here is the link to the one that they are aiming at guys with street cars http://www.schroedersteering.com/HotRodSteeringPg.html
As Silent rick said, having the steering shaft come out top or bottom depends on which side you want the drag link on. http://www.schroedersteering.com/OWSteerings.html
__________________
Happiness is having a garage big enough to hold all ttools and projects and small enough to keep warm enough to work in the winter.
Old 04-15-2011, 09:59 AM   #4
silent rick
Alliance Member
Quote:
maybe i should elaborate. they came in both left and right hand drive. they are intended to be run one way more likely to keep the gears in the lube. the one i had used a heavy grease. i don't think it mattered much if it was run upside down. one drawback to running it upside down would be the shaft that went to your steering wheel might be in the way of your pedals because it now hangs below the cross shaft that goes out to your pitman arm. or did i just confuse you more?
__________________
Old 04-15-2011, 10:11 AM   #5
silent rick
Alliance Member
here's a pic of one intended for right hand drive flipped over and ran out the other way.
__________________
Old 04-15-2011, 11:10 AM   #6
Da' Bomb
Alliance Member
Da' Bomb's Avatar
Mine runs on the top, exiting the cowl on the drivers side. If it's low, it's probably going to make for some interference with the feet.
Pat
Old 04-16-2011, 10:25 AM   #7
coopsdaddy
coopsdaddy's Avatar
Ok,i learned something,how bought some mounting pics..
Old 04-16-2011, 11:02 AM   #8
GARY?
Senior Member
GARY?'s Avatar
Here ya' go.
Click image for larger version
Old 04-17-2011, 08:49 AM   #9
coopsdaddy
coopsdaddy's Avatar
How bought with swinging pedals?
Old 04-17-2011, 11:09 AM   #10
Kirk Hanning
Senior Member
.....with Wilwood hanging clutch/brake pedals.
Name:	cowl steering 2.jpg
Old 04-17-2011, 11:24 AM   #11
sdluck
Senior Member
Dirt cars ran them on left side pavement cars on right side
Old 04-19-2011, 07:41 PM   #12
coopsdaddy
coopsdaddy's Avatar
btt
Old 04-20-2011, 12:05 AM   #13
lakester47
Alliance Member
lakester47's Avatar
Here's another example of swinging pedals. The pedal mount also does double duty and mounts the steering. This is a right hand steer version.
Old 04-20-2011, 04:58 PM   #14
coopsdaddy
coopsdaddy's Avatar
Nice setup lakester
Old 04-20-2011, 11:52 PM   #15
lakester47
Alliance Member
lakester47's Avatar
Thanks.
Old 04-21-2011, 12:40 AM   #16
AJofHollywood
AJofHollywood's Avatar
Quote:
If someone could elaborate on this, I would appreciate it.
__________________
AJ Elias
http://www.HotRodDisorder.com/
Old 04-21-2011, 06:17 PM   #17
AJofHollywood
Also if anybody knows, Schroeder steering assemblies are sometimes attached using connecting rods at each arm. What engine do those connecting rods come from?
__________________
AJ Elias
Old 04-24-2011, 10:44 AM   #18
coopsdaddy
coopsdaddy's Avatar
easter bump
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
