1946 GMC Vin # Location ??
Discussion in 'The Hokey Ass Message Board' started by DE SOTO, Apr 12, 2011.
  1. DE SOTO
    DE SOTO
    Anyone here know the EXACT location for the VIN Number stamped in a 1946 GMC 3/4 ton Truck ?
    Its not on the Plate under the Right side of the Hood on the Cowl like a Chevy.
    Original Engine is Gone.
    Only a serial # on Cowl tag.
    Is it stamped in the Frame somwhere ?
    We need some help locating this # so it can get Registered.
  2. 1934coupe
    1934coupe
    The two that I worked on had a VIN stamped on the frame rail, drivers side top in the front near where the bumper bolts on.
    Pat
  3. Amanda Suckerpunch
    Amanda Suckerpunch
  4. DE SOTO
    DE SOTO
    I checked it out but its for Chevrolet Trucks.
    GMC's are different, I have another friend that has Chevys & it a whole different deal.
  5. Amanda Suckerpunch
    Amanda Suckerpunch
    Sorry, wish I could have helped, good luck. It was a nightmare to get mine changed and I still have the original motor. The truck was already in PA, and PA wanted CA to change it. CA flat out told me, "sorry, no. That's just the way we do it". Glad I pushed the issue and got it done right, especially after reading Swifster's thread yesterday!
  6. DE SOTO
    DE SOTO
    Anyone else ?
  7. pcterm2
    pcterm2
    try the drivers door sill.
  8. 1946chevytruck
    1946chevytruck
    from london ,ky
  9. Bearing Burner
    Bearing Burner
    from W. MA
    I used the # on the plate on firewall. Registry took it with no problem.
  10. greenie-reddy
    greenie-reddy
    from maryland
    My '46 GMC has a plate on the side of the cowl section, under the rear portion of the right side hood. Send me your email and I'll send you back a picture.
    [email protected]
  11. DrJ
    DrJ
    On outside side of RIGHT front frame rail just behind shackle/bumper mount rivet area.
    (at least that's where the '40 is and it's the same frame.)
  12. J Twitero
    J Twitero
    from Minnesota
    I have a 1948 heavy duty GMC truck (10 ton) and the serial number / body tag is on the inside of the firewall below the dash. There is also a serial number just above and ahead of the front axle on the outside of the passenger side framerail IIRC. The truck is stored at my dad's place about 150 miles away so I cant go check easily, but it also may be in a different spot on a lighter duty truck, the big ones carried over the older pre-war body style for a while.
  13. motion guru
    motion guru
    from yacolt, wa
    DrJ & J T have the right answer - right side frame rail on the vertical outside portion of the C-Channel right behind the bumper bracket.
    GMC stamped all frames here up to and including 1948.
