Go Back   THE H.A.M.B. > Archives > Tech Archive
Reply
Thread Tools Display Modes
Old 12-11-2003, 06:22 PM   #101
mytlo56
Default Re: white wall tech
Somebody needs to nominate Nate for best (or maybe most useful) tech. post. This is good stuff. Way to go Nate.
offline   Reply With Quote
Old 12-11-2003, 06:32 PM   #102
kustumizer
Senior Member
kustumizer's Avatar
Kool, thanks i hope i win for best tech of week!! Thanks Nate
Old 12-11-2003, 07:57 PM   #103
Elrusto
Senior Member
Elrusto's Avatar
Ya got my vote!!
Old 12-11-2003, 07:58 PM   #104
kustumizer
Senior Member
kustumizer's Avatar
Kool, thanks. Nate
Old 12-11-2003, 07:59 PM   #105
SwitchBlade327
Old School HAMBer
mine too. This is one post that pretyt much everyone on here could use to save a nice chunk of cash. I get sets of skinny whites for $100. So this is SO much better than shelling out $500-$1000 for some wide ones.
Old 12-11-2003, 08:00 PM   #106
kustumizer
Senior Member
kustumizer's Avatar
Thanks!! Nate
Old 12-11-2003, 09:34 PM   #107
TP
Senior Member
TP's Avatar
The outer edge is the existing edge of the whitewall.TP
Old 12-11-2003, 09:49 PM   #108
kustumizer
Senior Member
kustumizer's Avatar
The whitewall goes past the exsiting whitewall edge. Heres a pic. Nate
Click image for larger version
Old 12-11-2003, 10:49 PM   #109
Dirty Dug
Old School HAMBer
Default Re: white wall tech *DELETED*
Post deleted by dirty dug
online   Reply With Quote
Old 12-11-2003, 11:09 PM   #110
Ryan
Administrator
Ryan's Avatar
Please ignore the above post. I don't wanna delete this whole thread cuz of one bad apple.
Again, please ignore the above post.
Old 12-12-2003, 07:00 AM   #111
kustumizer
Senior Member
kustumizer's Avatar
Its cool, he can go spend his money on buying whitewalls instead of saving some money!! Nate
Old 12-12-2003, 08:07 AM   #112
james
Senior Member
What if you jacked up the tire and set a bench grinder under the tire to spin it? Seems like spinning it somehow would give you a more even finished tire.
Old 12-12-2003, 09:11 AM   #113
Mongo
Mongo's Avatar
Location: G.R. baby !! Thats Grand Rapids for those of you from outside the mitten.
[ QUOTE ]
This week was a chance for you posers to actually learn something about building a hot rod but you chose to focus on one of the dumbest posts I've ever seen, grinding tires. You fucks should start your own website, call it, POSERS WITH FAKE WHITEWALLS.COM. Go paint your wheels red and get higher on the paint.
[/ QUOTE ]Do you even know what traditional hot rodding is about? It is about using what you have and making things that are ment for something else work for you.It's about fabricating your own parts when you can't get them or they are out of your price range.I would much rather be driving my car on a set of wide whites that I ground out then leting my car set while I try to come up with the money to buy over priced tires.Some of us are not made of money.
Old 12-12-2003, 03:30 PM   #114
kustumizer
Senior Member
kustumizer's Avatar
I hear you mongo. I dont know what his problem was. Its cool though! Thanks Nate
Old 12-13-2003, 12:23 AM   #115
____
Grenade Inspector
on the narrow whites ive seen latley ,the white portion is RASIED UP from the black,,,does this mean you GRIND down the white till its gound down past the black untill its all a solid white band? seems like ALOT of gringing to do and if so,it seems like it look like shit after it was all done with??? just wondering ,. i mean they may look good on the internet,but do they look decent in real life?
thanks
Old 12-13-2003, 12:30 AM   #116
SwitchBlade327
Old School HAMBer
some wide whites have a raised skinny section on them new, I never really noticed it until last week when a 50 plymouth was brought in for paint and i was checking out the wheels. I don't remember the brand but the guy said they were about $1000 a set.
Old 12-13-2003, 01:10 AM   #117
Threedeuce56
Grenade Inspector
It's cool that you are telling everyone about grinding whitewalls!I have some on my car that i did a few years back,i used some white letter tires,like bf goodrich radial ta's,and it worked great! at first i used a angle grinder,but then i found that a sanding disc on a drill works better,cause it's not too fast and it gives a smoother finish.after i sand them by hand with 80 grit then 120.for cleaning them i use an sos pad which is basically soap and fine steel wool.I've had mine for 3 years now and no problems .the outline white letter tires work even better cause there's less height to grind off.I think that this is one of the best kept secrets of our hobby !cool man this post rocks!
Old 12-13-2003, 02:01 AM   #118
ikillspies
Newbie
so, do you grind the tires dry, or would it be better to use oil or other lubrication, and also, is there white underneath the black on the bead part of the tire that is seated into the rim?
Old 12-17-2003, 06:15 PM   #119
Brootal
Senior Member
Brootal's Avatar
Some people have already asked this, but I couldn't see an answer so I'll ask it again.
I've been running Michelin thin line whites for years now. The latest set I've got on my car have a "dip" either side of the whitewall. Wouldn't that mean that the white rubber is either raised, or is only applied where required?
I think the same tyre in the US is a BF Goodrich.
Old 12-17-2003, 09:45 PM   #120
Rude Dude
Grenade Inspector
Rude Dude's Avatar
I just wanted to say thanks great post, I have got some small whites laying around in garage a 4 inch makita grinder now I know what Ill be doing this weekend once again thanks for the tech tip
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
