Reply
Thread Tools Display Modes
Old 03-30-2011, 09:16 AM   #1
Plymouth
Grenade Inspector
Default 6 volt trumpet Horn adjustment..?
I got a 6 volt pair of 1940 Plymouth trumpet horns to work but dong so messed up the sound..
I thought or read somewhere one is E Flat the other is C ...?
Which one is which one is shorter than the other..
I Tried to google a sound (cheat sound ) but could not find one (not much info out there on the subject)
Does any one know which note goes to which one and have a demo sound to adjust them to Thanks
offline   Reply With Quote
Old 03-30-2011, 09:36 AM   #2
isettajohn
Senior Member
isettajohn's Avatar
Default Re: 6 volt trumpet Horn adjustment..?
Like a pipe organ, the shorter one will be the higher note.
Old 03-30-2011, 10:11 AM   #3
1950ChevySuburban
1950ChevySuburban's Avatar
You adjust them until they have a clear , clean note. You can't adjust the pitch, just the quality. Set screw on the back, under the bell cover.
Don't do it inside.
__________________
My '29 Sedan build thread can be viewed here:
/showthread.php?t=635145
Old 04-04-2011, 01:07 PM   #4
Plymouth
Grenade Inspector
Short update I spent around 4 hours but I got the horn (I was working on ) to work as it should..
Seems the point adjustment is not much help The problem was the round 2 inch disk .. IT was out of adjustment it was too close to the magnet field..
Once I reset the gap by loosing (the hold down nut) it up , and making a larger gap,, IT made a clear note...
There is no way too adjust the horn for a different tone..
The Point are adjusted too just touch and once its energized it works like a diving board and springs (fast) opening and closing ) making it vibrate..
I usually adjust modern horns with the set screw and makes different sound not these. These have a metal diapram and are preset...
I think my Autolite horns 1940 are E flat and G
Old 04-04-2011, 04:05 PM   #5
Flatman
Senior Member
Flatman's Avatar
The notes should clash, making the sound of the horn more noticable, hence the two tones.
Flatman
__________________
Some men are Baptists, others Catholics, my father was an Oldsmobile man.
Old 04-04-2011, 04:28 PM   #6
1950ChevySuburban
You did it right. The set screw is what I was referring to.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
