Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 03-19-2011, 10:46 AM   #1
blown240
Senior Member
blown240's Avatar
Default Bad Brake Light Switch?
Is it possible for a brakelight switch to blow fuses? On my buddies 50 Shoebox if I jump the 2 brakelight switch wires together with a piece of wire, the lights work fine. But if they are plugged into the switch and you hit the brakes, the fuse blows.
To me that says bad switch, but I have never seen one. If it matters, he is using a dome light switch from a Volvo 240 as his brake light switch.
Thoughts? Also, it seems like brake lights should be on a 20 amp fuse. He is running a 15 even though its all 12-14 gauge wire.
offline   Reply With Quote
Old 03-19-2011, 11:04 AM   #2
Alliance Member
Mr48chev's Avatar
Default Re: Bad Brake Light Switch?
Sounds like the switch is shorting out inside. I well understand the use what ya got theory but I think I'd install a brake light switch designed to work with brake lights.
The door switches are designed to work a couple of times a day when you get in and out while the brake light switches are designed to work on a regular on and off basis.
__________________
Definition of a "work car". One you have to work on all weekend so you can drive it to work the next week.
Old 03-19-2011, 02:52 PM   #3
blown240
Senior Member
blown240's Avatar
Thanks. I went and got a brake light switch for it. The guy at the part store had a good point that I never thought about. Alot of door jam switches, even the ones with 2 pins, are grounding switches. That would explain the blown fuses.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
