Reply
Thread Tools Display Modes
Old 03-18-2011, 01:21 PM   #1
ZZ-IRON
Senior Member
ZZ-IRON's Avatar
Default Ever straighten pot metal? school me
Just got a pair of 53 Studebaker grilles good driver quality one has a high spot the other has a low spot
the problem areas are in the center at the rear of the grille, the front edge is fine that the part that shows the most
re chroming is in my plans down the road
has anyone ever straightened a large area maybe a foot long and a 1/4" thick
or is this something a chrome shop can do?
the high and low areas
front view you can see the high and low areas
since the 53 Stude coupe did not have grilles just the grille surround bezels i was happy to get these
and with luck correct the defects
Thanks for any input
__________________
50 Olds 88 coupe build
http://www.jalopyjournal.com/forum/a...?albumid=32647
offline   Reply With Quote
Old 03-18-2011, 01:32 PM   #2
ELpolacko
Old School HAMBer
ELpolacko's Avatar
Default Re: Ever straighten pot metal? school me
Three of the four headlight rings on my 63 Mercury grille were damaged when I got them. Two of which were D shaped.
I used a propane torch to heat them and beat them gently back into shape by laying them in my sand bag and lightly hammering them with a urethane mallet. I did end up with cracks at the highest stress areas.
My intent is to have the chrome stripped and then use something like Muggy Weld to repair them before rechroming. Most people don't even notice the cracks though.
__________________
Visit my Social Group: Industrial Chassis Inc, Facebook , WEBSITE or Instagram
Old 03-18-2011, 01:59 PM   #3
oldrelics
Senior Member
oldrelics's Avatar
I have used a heat gun successfully, go SLOW and use blunt wooden tools to avoid marks....
Old 03-18-2011, 02:05 PM   #4
1971BB427
Old School HAMBer
1971BB427's Avatar
I had to straighten some of the horizontal grille pieces on my Austin. I took the grille sections out and put them in the same position on a bench, then used a clamp and a block to hold one end of a metal flat bar and after slipping the bar through the grille I gently pushed down on it until they were straight.
I worked slowly moving to each bent bar in the various grille pieces and they came out perfect. Just keep gently pushing down and checking until they look good. Never thought of heat, as I didn't want to rechrome the grilles.
Old 03-18-2011, 03:54 PM   #5
Bruce Lancaster
Alliance Member
Agree...push, pound, force rouded objects into collapsed hollows.
If you are not a knowledgable flame wizard lkke El Polacko, I would say get a good heat gun that allows peak temp to be set. There is not a whole lot of wiggle between slightly more malleable and molten metal running into your socks.
Think of it as somewhat brittle sheetmetal.
__________________
Bruce
Old 03-18-2011, 04:12 PM   #6
ZZ-IRON
Senior Member
ZZ-IRON's Avatar
Thanks for all the tips
Just posted the photos so you can see the problem areas now
I'll look into the the options posted
The cool thing i bought them from a member of Ron Hall's Studebaker Avanti crew
Ron broke 200 mph at Bonneville with a built Studebaker motor
Ron's video of his Avanti #1963 running at Bonneville and that sound
that was the reason i went to Bonneville in 2000
Going to Bonneville is with me forever and i'll never forget it, hope to make Speed week 2011
Ron Hall passed many years ago
__________________
Old 03-18-2011, 04:29 PM   #7
porknbeaner
Alliance Member
porknbeaner's Avatar
Just looked at your pics.
Just take a crescent wrench a tweak them a little then take a hammer and larrop the hell out of them.
On second thought don't I can't afford to replace them.
You already got plenty of good advice, the main thing or only thing that I could add is do it slow real slow and a little at a time.
__________________
If it don't make ya dirty it ain't yours
No man crosses a chasm in two jumps
Old 03-18-2011, 04:44 PM   #8
ChromePlaterJosh
Alliance Member
ChromePlaterJosh's Avatar
Good advice so far. Considering how broad of a dent/tweak your relatively wide pieces have, I would be surprised if they would straighten back to perfect, but they can certainly be improved. I would probably try to tweak them back with my hands over my leg or a wooden tabletop. Take not that pot metal work hardens very quickly and will crack easily, especially if any hammerwork is done. It will be very easy to make them worse, I know this from personal experience.
Many times, parts like that will be forced into position by installing them on the car, but that only works if there are enough attachment points to use.
Another concern, those grills look somewhat flimsy in how they are built, so they might try to go back to a tweaked position in the rechroming process. I fI were restoring them, and you specified you wanted them straight, I would strongly consider welding some reinforcement underneath to keep them from bouncing back later.
__________________
Custom Metal Finishing IN
1-866-489-4089
Call or Email for spot-on bumper quotes!
ChromePlater1@Yahoo.com
www.ChromePlatingIN.com
Old 03-18-2011, 05:50 PM   #9
pimpin paint
Old School HAMBer
pimpin paint's Avatar
Hey,
Back when vehicles featured pot metal trim, most metalmen had a trick or three to straighten it.
These can be straightened with the use of torch, some wooden formers, and the careful use of a hammer. Cold working potmetal/Zamac isn't a great idea, as many times the piece had cracks you can't see until it goes snap! Sometimes, on sightly tweeked pieces, boiling water can be used to warm up the bent area @ 212 degrees yer well below what zinc melts at, and this can be just enough to get the zinc to move. Try and avoid hitting plated pieces with a steel hammer-use wood or plastic only to shape them. On larger, thicker pieces a torch with a carborizing flame will be needed to gently warm up the part BEFORE you try to hammer or push it back into proper shape. Carefuly heat the damaged area always keeping the flame moving, and stop well before you leave any firescale on the chrome. Again, work over some plywood or a sheet of Masonite with ''soft'' tools. If at first it doesn't move, reheat and rework until it does.
Potmetal can be soft soldered to repair cracks or missing pieces, but will require replating afterwards.
" The real pity in America is that the people who really know how to run the country are all tending bar and cutting hair " - George Burns -
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
