Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 02-25-2011, 01:56 PM   #1
STRANGERODZ
Newbie
STRANGERODZ's Avatar
Question Sheet metal vs. Body panel gauge???
Hi, I would like to know if there is a differents in body panel steel and mild steel?? If a car hood is 18ga and a peace of 18ga sheet metal is the same. Way will one have louver punch in it easyer than the other. Is car steel mild, cold rolled or hot roller. Can any one please HELP?? Thanks..
__________________
STRANGERODZ.COM-- LOUVERS & MY RODZ.
offline   Reply With Quote
Old 02-25-2011, 02:11 PM   #2
53sled
Old School HAMBer
53sled's Avatar
Default Re: Sheet metal vs. Body panel gauge???
http://www.sheetmetalguy.com/sheet_m...auge_chart.htm
I've read Ford used 19 gauge, so you just use some mild steel 18 and go to town. Most seem to prefer cold rolled, I think there is more slag?crap on the surface of hot rolled.
__________________
If only the good die young. I'll be here when you're gone.
Old 02-25-2011, 02:25 PM   #3
1Bad67
Grenade Inspector
1Bad67's Avatar
Type of steel, not the thickness, is probably the main difference. I think they use a type that is easier to form for body parts.
__________________
Shop rule #1: You have to ask if they are okay before you start laughing
Old 02-25-2011, 02:27 PM   #4
metalfaber
Grenade Inspector
metalfaber's Avatar
Cold rolled sheet is what you want, 18, 19 or 20 gauge is best for bodypanels. Cold rolled is rolled and formed cold, hence the name, and it has tighter tolerances and a nicer slag free finish. Hot rolled is rolled while hot, and then ends up with slag on it. If you take a piece of cold rolled and hammer it over in the vice, and take a piece of hot rolled, you will see the crap pop off of the hot rolled.
Use cold rolled for sheetmetal, and you can take your pick on thicker stuff for brackets, frame parts, etc. There are several other options for the thicker material, such as P&O (pickled and oiled) which is basically hotrolled with some things done to it afterwards to improve its appearance.
To sum up for you, a car panel should react the same as cold rolled, unless you get a newer car that has some of the high strength steel in it, but I very well doubt you will, as that is also on in certain structural areas of the cars anyways, and it is new.
Probably more than you wanted to know. LOL
Brian =)
__________________
Model A/T/32/33-34/35-40 Ford Boxing Plates, Shrinking Discs & more www.wolfesmetalfabrication.com
Old 02-25-2011, 04:20 PM   #5
STRANGERODZ
Newbie
THANKS, guy. That's a lot of help..
__________________
Old 02-25-2011, 04:23 PM   #6
65COMET
Senior Member
65COMET's Avatar
I am a retired sheet metal worker and we used 21 gauge cold rolled metal made for forming body panels,much more plyable,on all our custom body panel products. ROY.
Old 02-25-2011, 05:25 PM   #7
61 chevy
61 chevy's Avatar
cold roll is stronger than hot roll when it comes to bending it
Old 02-25-2011, 05:29 PM   #8
jimvette59
jimvette59's Avatar
With out going to it cold rolled is more pliable as per specs.
online   Reply With Quote
Old 02-25-2011, 06:46 PM   #9
Hnstray
Alliance Member
Hnstray's Avatar
If you are looking for good sheetmetal for forming body panels, 19 ga. AKDQ is the type favored by many pros. The AKDQ is short for "aluminum killed, draw quality". Yes, we're talking steel, not aluminum, that just refers to the mill process and the "draw quality" indicates it's greater stretchability for being drawn into or over dies without tearing. That is, of course, an equally a beneficial quality when hand forming panels.
Ray
__________________
"In any conflict between Physics and Style, Physics always wins"
Old 02-26-2011, 09:10 AM   #10
STRANGERODZ
Newbie
Lots of good stuff. Thanks
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
