Reply
Thread Tools Display Modes
Old 02-20-2011, 12:25 PM   #1
potter142
Newbie
potter142's Avatar
Default 35 Ford Garnish Moldings
Finally I've got my 35 on the road. The body was chopped when I bought it
but needed a lot of help. Looks pretty good now but I new problem has come
up I need to cut down the garnish moldings and I'm not sure how to go about
it. Since they're hard to come by I don't want to screw things up. The first
photo is my 35 with a 3.5 inch chop the second is one of the moldings I need
to modify. Can someone offer some help? How but I cut these things without
making a bunch of scrap. Thanks!
Click image for larger version
ID:	1246649   Click image for larger version
Name:	35 WindowModling.jpg
offline   Reply With Quote
Old 02-20-2011, 12:28 PM   #2
tinmann
Senior Member
tinmann's Avatar
Default Re: 35 Ford Garnish Moldings
Make a paper template of the door window opening and then lay the molding on the paper. That should at least give you a road map as to where to make the cuts. The actual fitting needs to be done on the car.
__________________
You can touch the coupe, just don't fondle my chicken!!
Old 02-20-2011, 02:08 PM   #3
potter142
Newbie
potter142's Avatar
That's a good idea
Old 02-20-2011, 03:15 PM   #4
Corn Fed
Senior Member
Corn Fed's Avatar
Your cuts in the molding will be at about the same locations as the cuts to the top. My guess is they probably cut the top of the window and added metal to make up the gap. You'll need to use some of the molding you cut out of the front verticle section to fill the gap you'll have in the same place.
Don't worry, 35-6 moldings aren't hard to find. I have some extra rears that I'd sell for $25 each iif ya screw yours up.
__________________
A little slice of Hemi right here on earth.
Old 02-20-2011, 03:38 PM   #5
296 V8
296 V8's Avatar
Its best to use extras so you have fewer pieces weld back together
Old 02-20-2011, 04:01 PM   #6
36-3window
Old School HAMBer
36-3window's Avatar
nice looking `35 slantback , i had one i sold 15 years ago....i still miss it
i think i might have some 4-door moldings if you need some pieces
__________________
when small men begin to cast long shadows it is a sure sign the sun is setting.
online   Reply With Quote
Old 02-20-2011, 06:27 PM   #7
potter142
Newbie
potter142's Avatar
Everyone thanks for the advice. There's a lot of hard work in that frame off
build and I'd rather not mess it up in the last minutes.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
