Reply
Thread Tools Display Modes
Old 02-18-2011, 10:49 PM   #1
southcentraldodge
Newbie
southcentraldodge's Avatar
Default another frame swap question
i just got a 47 dodge 5 window coupe,and need advice on a frame swap,i know i can use long bed dakota frames as well as s 10 frames.my friend got a 89 camaro thats willing to "donate" will this year work fine because i was told that 79 was latest it will work, thanks any advice or help will really be apprecieted
offline   Reply With Quote
Old 02-18-2011, 10:51 PM   #2
THE_DUDE
Old School HAMBer
THE_DUDE's Avatar
Default Re: another frame swap question
The steering box is the first problem you may have with the Camaro
__________________
Too weird to live...TOO rare to die..
Old 02-18-2011, 10:56 PM   #3
southcentraldodge
Newbie
Quote:
yeah thats what i heard, will i have that problem if cut the front clip (if it works with the 89 camaro)and weld it to the dodge frame?
Old 02-18-2011, 11:00 PM   #4
THE_DUDE
Old School HAMBer
THE_DUDE's Avatar
I don't see a reason why you would'nt want to do that... Width and and wheel base is all ya gotta worry about. Well that and the location of the steering gear box
__________________
Old 02-18-2011, 11:01 PM   #5
53sled
Old School HAMBer
53sled's Avatar
not even close. it is not anything like a 2nd gen camaro and uses struts. what direction do you want to go with this build? there are options that are less work.
__________________
If only the good die young. I'll be here when you're gone.
Old 02-18-2011, 11:03 PM   #6
gsport
gsport's Avatar
an 89 camaro doesn't have a "real" frame...
Old 02-18-2011, 11:16 PM   #7
southcentraldodge
Newbie
cool, so for now my best option is to used a s 10 frame, i been looking for one but they just hard to come by as parts trucks, thats why i was thinking on using my friends maro,but thats just to much unnessary work i guess, you guys now any links to past tech advise with piuctures, thanks
Old 02-18-2011, 11:37 PM   #8
50dodge4x4
Old School HAMBer
Whats wrong with the frame that belongs to the car? If its intact and not bent or rotted away, you can upgrade the brakes and add a rack & pinion steering pretty easy. Its a lot easier to bolt stuff on then it is to hack up the frame. Gene
Old 02-19-2011, 08:51 AM   #9
Frankie47
Senior Member
Frankie47's Avatar
The original frame has independent suspension way beefier than an S10 and all it needs is a shock relocation kit and a bigger sway bar, plus a disk brake upgrade. No cutting required.
And if you feel you still want a clip go with a dodge dakota, it's perfect for your application........are you putting in a sbc? That is the only reason for using an S10 clip I can think of.
__________________
1947 Dodge CC
The man's prayer
I'm a man, I can change,
If I have to,
I guess....Red Green.
Old 02-19-2011, 03:19 PM   #10
southcentraldodge
Newbie
yeah, i got a sbc,and auto trans thats going into it,thats why i was thinking of an up grade to disk brakes and power steering.What year dakota can i use,also the frame i got is bent and i got it with no rear end.
Old 02-20-2011, 11:20 AM   #11
Frankie47
Senior Member
Frankie47's Avatar
Use what you gotgetting it back on the road is the main thing!
__________________
1947 Dodge CC
The man's prayer
If I have to,
Old 02-20-2011, 12:06 PM   #12
birdbuilder
Newbie
birdbuilder's Avatar
Wheelbase, front track, rear track
[edit] American Motors
  • 100.0, 61.2, 60.2 -- 75 AMC Pacer
[edit] GM Car
  • 122.0, 58.31,59.25 - 37 Buick Special
  • 126.0, 58.31,59.25 - 37 Buick Century
  • NA,,,, 59.1, 58.8 -- 68-74 Buick Apollo
  • NA,,,, 59.0, 58.8 -- 78-86 Buick Century
  • 111.0, 59.1, 59.7 -- 75 Buick Skylark
  • 115.0, 58.5, 60.0 -- 55-57 Chevy
  • 108.1, 58.7, 60.5 -- 67-69 Chevy Camaro (other source shows 1081/590/589)
  • 108.1, 60.4, 61.0 -- 70 Chevy Camaro
  • NA,,,, 61.3, 60.5 -- 76-80 Chevy Camaro Z-28, Pontiac Trans Am TA
  • 101.1, 60.7, N/A, -- 93-02 Chevy Camaro
  • 101.0, 60.7, 60.6 -- 86 Chevy Camaro IROC Z
  • 101.1, 60.7, 60.7 -- 98 Chevy Camaro
  • 112.3, 63.7, 64.1 -- 99 Chevy Camaro LS, LT
  • 112.3, 63.7, 63.7 -- 99 Chevy Camaro SS
  • 119.0, 62.5, 62.4 -- 65-70 Chevy Caprice
  • 121.5, NA,,, NA,, -- 71-76 Chevy Caprice coupe/sedan
  • 125.0, NA,,, 64.5 -- 71-76 Chevy Caprice station wagon
  • 116.0, NA,,, NA,, -- 77-90 Chevy Caprice
  • 115.9, 61.8, 60.7 -- 91-96 Chevy Caprice
  • 102.0, NA,,, NA,, -- 54 Chevy Corvette
  • NA,,,, 58.7, 59.5 -- 68-83 Chevy Corvette
  • NA,,,, 59.6, 60.4 -- 84-95 Chevy Corvette
  • 108.0, 58.5, 58.8 -- 78-88 Chevy Monte Carlo, Malibu, El Camino(117.1 wheelbase), Olds Cutlass, Pontiac Grand Prix
  • 111.0,59.8, 59.6 -- 68-74 Chevy Nova
  • 097.0, 54.7, 53.6 -- 71-77 Chevy Vega, 73-77 Pontiac Astre, 75-80 Chevy Monza, Buick Skyhawk, Olds Starfire, 76-80 Pontiac Sunbird
  • NA,,,, 58.9, 59.0 -- 78-86 Pontiac Grand Prix
  • 115.0, NA,,, NA,, -- 66 Pontiac GTO
  • NA,,,, 59.9, 59.6 -- 68-74 Pontiac GTO
  • 112.25, 57.5, 59.0 -- 39 Chevy knee action
  • 112.25, 56.375, 59.0 -- 39 Chevy I beam
  • 116.0, 57.6, 60.0 -- 42-48 Chevy
[edit] GM Truck
  • 106.5, 64.5, 63.0 -- 73-91 Chevy Blazer 2WD
  • 106.5, 65.75, 62.75--73-91 Chevy Blazer 4WD
  • 131.5, 65.8, 62.7 -- 73-87 Chevy C-10, K-10
  • 131.5, 65.8, 62.7 -- 73-87 Chevy C-20, K-20, C30
  • 164.5, 65.8, 62.7 -- 73-91 Chevy C-30 Crew Cab
  • 129.5, 65.8, 62.7 -- 73-91 Chevy Suburban
  • 114.5, NA,,, NA,, -- 55 Chevy 2nd Series (1955 1st series was same as 54)
  • 116.0, 59.5, 60,, -- 47-54 Chevy AD 1/2 ton
  • 125.25,NA,,,,62,, -- 47-54 Chevy AD 3/4 ton
  • 137.0, NA,,, NA,, -- 47-54 Chevy AD 1 ton
  • 144.0, NA,,, NA,, -- 02 Chevy Silverado 1500 4WD
  • 102.4, NA,,, NA,, -- 72-80 Chevy LUV w/std cab and 731" box Unequal length A-arms with torsion bars was std front suspension on LUV
  • 104.3, NA,,, NA,, -- 81-82 Chevy LUV w std cab and 731" box Unequal length A-arms with torsion bars was std front suspension on LUV
  • 117.9, NA,,, NA,, -- 78-82 Chevy LUV w std cab and 901" box Unequal length A-arms with torsion bars was std front suspension on LUV
  • 100.5, 54.5, 54.7 -- 83-01 Chevy S-10 Blazer 2-dr, 83-01 GMC Jimmy 2-dr
  • 107.0, 54.5, 54.7 -- 90-01 Chevy S-10 Blazer 4-dr, 90-01 GMC Jimmy 4-dr
  • 108.3, 54.5, 54.7 -- 82-93 Chevy S-10 reg cab, 73" box, 82-93 GMC reg cab, 73" box STOCK Malibu and El Camino drop spindles are bolt-on
  • 117.9, 54.5, 54.7 -- 82-93 Chevy S-10 reg cab, 89" box, 82-93 GMC reg cab, 89" box
  • 122.9, 54.5, 54.7 -- 83-? Chevy S-10 ext cab, 83-?? GMC ext cab
  • 135.0, 67.8, 67.8 -- 08 Chevy Express Cargo 1500 Work Van
[edit] Ford Car
  • 108 -- 64-68 Mustang
  • 096.2, 55.6, 55.8 -- 74-79 Ford Mustang II, Ford Pinto, Mercury Bobcat, Mercury Capri (have also seen track listed at 551/553)
  • 100.5, 56.6, 57.0 -- 86 Ford Mustang GT
[edit] Ford Truck
1953-1955
  • F100 1/2-ton - 110"
  • F250 3/4-ton - 118"
  • F350 3/4-ton - 130" (F350s were still classified as 3/4 ton trucks up through '55.)
1956-1960
  • F100 1/2-ton SWB - 110"
  • F100 1/2-ton LWB - 118"
  • F350 1-ton - 130"
1961-1963
  • F100 1/2-ton SWB - 114"
  • F100 1/2-ton LWB - 122"
  • F250 3/4-ton - 122"
  • F350 1-ton - 132"
1964
  • F100 1/2-ton LWB - 128"
  • F250 3/4-ton - 128"
  • F350 1-ton - 132"
1965-1966
  • F100 1/2-ton SWB - 115"
  • F100 1/2-ton LWB - 129"
  • F250 3/4-ton - 129"
  • F250 3/4-ton CrewCab - 147"
  • F350 1-ton - 132"
  • F350 1-ton CrewCab - 152"
1967-1968
  • F100 1/2-ton LWB - 131"
  • F250 3/4-ton - 131"
  • F350 1-ton - 132"
1969-1970
  • F350 1-ton - 135"
  • F350 1-ton CrewCab - 159.5"
1971
  • F250 3/4-ton CrewCab - 159"
  • F350 1-ton - 135"
1972
  • F350 1-ton - 135"
  • F350 1-ton CrewCab - 159"
1973
  • F100 1/2-ton SWB - 117"
  • F100 1/2-ton LWB - 133"
  • F250 3/4-ton - 133"
  • F250 3/4-ton CrewCab - 161"
  • F350 1-ton - 137"
  • F350 1-ton CrewCab - 165.5"
1974
  • F100 1/2-ton Supercab LWB 6-ft bed - 140"
  • F100 1/2-ton Supercab LWB 8-ft. bed - 155"
  • F250 3/4-ton Supercab - 140"
  • F250 3/4-ton CrewCab - 155"
  • F350 1-ton - 137"
  • F350 1-ton Supercab - 140"
  • F350 1-ton Platform/Stake - 161"
  • F350 1-ton CrewCab - 166.5"
1975
  • F100 1/2-ton Supercab 6-ft bed - 140"
  • F100 1/2-ton Supercab 8-ft. bed - 155"
  • F150 1/2-ton - 133"
  • F350 1-ton - 137"
  • F350 1-ton Supercab - 155"
1976
  • F100 1/2-ton Supercab - 155"
  • F350 1-ton - 137"
1977
  • F150 Supercab - 155"
  • F350 1-ton - 137"
1978-1979
  • F250 3/4-ton Supercab - 155"
  • F250 3/4-ton Crewcab - 155"
  • F350 1-ton - 137"
[edit] Mopar Car
  • 115.0, 61.9, 62.0 -- 75 Chrysler Cordoba
  • NA,,,, 58.9, 59.0 -- 75-79 Dodge Aspen, Plymouth Volare
  • 111.0, 59.2, 55.6 -- 67-76 Dodge Dart/Plymouth Scamp
  • 108.0, 59.2, 55.6 -- 70-76 Dodge Demon/Dartsport, Plymouth Duster
[edit] Mopar Truck
[edit] Miscellaneous Car
  • 105.0, 58.0, 58.0 -- 51 Cunningham C-1, C-2R
  • 107.0, 58.0, 58.0 -- 53 Cunningham C-3
  • 100.0, 54.0, 54.0 -- 52 Cunningham C-4R, C-4RK
  • 100.0, 55.0, 55.0 -- 53 Cunningham C-5R
  • 100.0, 52.0, 52.0 -- 55 Cunningham C-6R
  • 086.0, 50.5, 50.3 -- 48-74 Morris Minor
[edit] Axle to axle, rear differential
[edit] GM Car
  • 58.0 -- 78-88 Mid sized GM Car, Malibu, Monte Carlo (82 up Metric Studs), Regal with 10-bolt, 65-67 Nova
  • 59.0 -- 68-83 Corvette
  • 60.0 -- 55-64 Chevy, 67-69 Camaro, 64-67 Chevelle, 68-74 Nova, 84-95 Corvette
  • 62.0 -- 64-77 Chevelle, 89 Trans Am
[edit] GM Truck
  • 58.0 ---S-10
  • 60.5 -- 64-69 1/2 ton 2wd Chevy, Some GMC 6 lug rear end 12 bolt Coil spring set-up
[edit] Ford Car
  • 56.5 -- 71-77 Ford Maverick 8"
  • 57.0 -- 71-74 V-8 Mavericks 8", All '75-77 6's & 8's Maverick 5 Lug 8", 49-51 Ford, 57-59 Ford 9"
  • 57.25 -- 64 1/2-65 Mustang
  • 58.0 -- 80 Granada & Lincoln Versailles, 67-70 Mustang/Cougar/Fairlane
  • 58.5 -- Granada (year unknown)
  • 60.0 -- 71-73 Mustang/Cougar
  • 62.0 -- 73-76 Torino
[edit] Related resources
Old 02-21-2011, 01:46 AM   #13
southcentraldodge
Newbie
thanks birdbuilder for that info, iam print it and keep ti for reference
Old 02-21-2011, 09:07 AM   #14
flynbrian48
Old School HAMBer
flynbrian48's Avatar
Quote:
An S10 is too hard to find for parts? Are you kidding? You can't swing a dead cat and not hit an old S10 pickup around here. Unless your frame is rusted, smashed, or missing, your "...best option..." would be rebuild the brakes and suspension of the frame the body is sitting on. These drive nice, have reasonably good brakes, and best of all, they fit the body.
Where did the idea that an S10 pickup frame swap come from anyway? You'll have to modify the floor (if there's any left in your car), build body mounts, shorten or lengthen the frame, and then you still have to fabricate engine mounts, trnas mounts, and so forth.
Brian
__________________
Member: Gold Chainers CC, Michigan Chapter.
http://flynbrian48.wordpress.com/
Old 02-21-2011, 09:19 AM   #15
Left Turn
Left Turn's Avatar
I never get these frame swaps... for the time it takes a person to rework an entire car and a random mini truck chasis they could have easily found a factory frame, upgraded it a bit and slid it under...
With all the aftermarket upgrades available why not use the factory frame? how bent is your frame? I'd think a competent frame/alignment shop could straighten it...
Plus if you decide to sell the car later.. I'd think a car on it's original frame, instead of some cobbled swap job would be worth a bit more...
__________________
I built her with what I had layin' around... Didn't find no cash in that ol' barn though...
Old 02-21-2011, 10:16 AM   #16
banginona40
banginona40's Avatar
Ditto left turn!!
Old 02-21-2011, 12:01 PM   #17
73RR
Old School HAMBer
73RR's Avatar
Why not just put your sbc in the camaro and drive that??
__________________
www.qualityengineeredcomponents.com
Early Hemi Parts, Pieces, Tech
Trans adapters for EarlyHEMI, Flat 6&8 and pre-62 A series
http://www.discoverthenetworks.org/Articles/Hansen.pdf
Old 02-21-2011, 12:24 PM   #18
53sled
Old School HAMBer
53sled's Avatar
it is still easier to straighten a frame than swap one. bolting a rear to leaf springs is still easier than a frame swap. this is one of those times to step back and look at the overall picture.
__________________
Old 02-21-2011, 12:43 PM   #19
porknbeaner
Alliance Member
porknbeaner's Avatar
Quote:
Its a good time to step away from the computer and pick up a wrench.
That said I did slide an S-10 chassis under a '53 F-100. I had the chassis and got the F-100 sans chassis. But in retrospect it would have been a better choice to build a chassis for the ford than to use the S-10 chassis.
__________________
If it don't make ya dirty it ain't yours
No man crosses a chasm in two jumps
Old 02-24-2011, 12:01 AM   #20
alleyboy1954
FNG
alleyboy1954's Avatar
el camino frame work great, check out my albums
__________________
Its only low if you DRAGGIN ASS!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
