Reply
Thread Tools Display Modes
Old 02-12-2011, 05:20 PM   #1
Bigtone
Newbie
Bigtone's Avatar
Default 235 chevy throttle linkage
Just installed a split manifold on my 235. Sweet looking manifold, but I've been every which way with the carb linkage and it always hits somewhere. Also, the bellcrank is VERY close to the rear dump. I'm to the point that I'd go with a cable set up for now if I could make it work. The problem is I 'm running a Rochester carb that the linkage needs to go up to open the throttle. Has anyone used a cable on a 235 chevy with this type of carb. Any help and any pics would be greatly valued.
__________________
" Don't blaspheme in here!" - Aretha Franklin, The Blues Brothers
offline   Reply With Quote
Old 02-12-2011, 06:11 PM   #2
xderelict
Senior Member
xderelict's Avatar
Default Re: 235 chevy throttle linkage
Can you put up a picture? Can the hook up be clocked opposite on the throttle linkage.Example, if it points to 9 o'clock to push up can it be reversed to 3 o'clock to pull down.I've flipped and flopped the linkage to these one barrels to figure out the path of least resistance..
__________________
A SOUTH OMAHA TURD
Old 02-12-2011, 06:49 PM   #3
Bigtone
Newbie
Bigtone's Avatar
I'll have to look closer at that. Thanks for the thought.
__________________
Old 02-12-2011, 09:51 PM   #4
Barnfind 56
Grenade Inspector
Barnfind 56's Avatar
If you don't mind me asking, what brand manifold did you use? I am getting ready to purchase a Fenton and was wondering if I would run into this problem as well.
Old 02-12-2011, 09:51 PM   #5
6inarow
Senior Member
6inarow's Avatar
Quote:
Patricks Fenton comes with all the linkage and fuel kit. You wont need anything.
Old 02-13-2011, 09:07 AM   #6
Paul
Editor
Paul's Avatar
..on my Edmunds 2x2 with Stromberg BXOV-2 carbs and Fenton headers
I whittled three arms out of brass and rebent and chopped the rod that runs up from the bellcrank
bought some adjustable linkage ends to connect the arms to the carbs
also moved the spring tab on the throttle rod to reposition the spring where it wouldn't rub on the exhaust
Old 02-13-2011, 12:50 PM   #7
terd ferguson
Old School HAMBer
terd ferguson's Avatar
You can bend the standard linkage to make it work without binding anywhere. It just takes LOTS of patience. For what its worth, it took me about three hours of bend, fit, bind, bend again, fit, bind, bend again, etc..
__________________
Quote:
Originally Posted by Buddha
What you are is what you have been. What you'll be is what you do now.
IRON LORDS CC
Old 02-13-2011, 09:08 PM   #8
Bigtone
Newbie
Bigtone's Avatar
Thanks guys. And Paul---that is sweet.
__________________
Old 03-07-2011, 06:52 PM   #9
DingDang
FNG
I have an old Fenton intake with the "rod and bellcrank set up" similar to what Paul posted. I'm flirting with the idea of running a cable instead of the 1/4" bent rod. The rod pushes, but the cable set up would have to pull. I thik that there is room to flip the bellcrank that accepts the top part of the rod linkage 180 so that pulling on it would rotate the bellcranks to the throttle bodies up. I'm just not sure what pedal assembly and throttle cable would work best for this set up.
It looks like everyone who has been down this road before just bent the 1?4" and made it work.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
