Reply
Thread Tools Display Modes
Old 01-16-2011, 10:57 PM   #1
BaznJosh
Grenade Inspector
BaznJosh's Avatar
Default Wanna put an automatic transmission in my 1950 Dodge Coronet
Anyone suggest a suitable trans I can use that won't be too much work?
offline   Reply With Quote
Old 03-19-2011, 05:59 AM   #2
holdfast2628
FNG
holdfast2628's Avatar
Default Re: Wanna put an automatic transmission in my 1950 Dodge Coronet
i dont know but im wanting to know for myself. i havent had any luck finding anything that will bolt right up, unless you by a adapt kit but that was a ton of money last i checked.
Old 03-19-2011, 07:50 AM   #3
Frankie47
Senior Member
Frankie47's Avatar
A 904 torqueflite will handle your flattie just fine, there is an adaptor already out there for it. Maybe go with an early 518 overdrive......
__________________
1947 Dodge CC
The man's prayer
I'm a man, I can change,
If I have to,
I guess....Red Green.
Old 03-19-2011, 08:03 AM   #4
moparob
Grenade Inspector
moparob's Avatar
who makes the tranny adapter for the flattie six..... just currious? still got the one out of my 50.
__________________
"Worker hours will increase until moral improves"
RUSTY KNUCKLES
Old 03-19-2011, 08:05 AM   #5
PhilJohnson
PhilJohnson's Avatar
Quote:
I'm curious as well. The transmission in my 50 Coronet is making clunking noises.
__________________
Lowering my property value one rusted car at a time
Old 03-19-2011, 08:21 AM   #6
Frankie47
Senior Member
Frankie47's Avatar
http://www.jalopyjournal.com/forum/member.php?u=26736
Pretty sure this is Him.
__________________
1947 Dodge CC
The man's prayer
If I have to,
Old 05-25-2011, 07:29 PM   #7
bucket73
FNG
you can try www.wilcap.com they make alot of adapter
Old 05-25-2011, 07:42 PM   #8
plym_46
Old School HAMBer
plym_46's Avatar
Transmissions in 50 Dodges were called clunk o matics, what's the problem????
A friend put a 350 chevy behind a 251 desoto with a wilcap adapter. put the combination in a A coupster, went like stink.
__________________
If yer running a flathead, how come yer plugs are slanted????
Old 05-26-2011, 04:15 AM   #9
Hnstray
Alliance Member
Hnstray's Avatar
You should be able to use a '54 thru '59 Mopar 6 cyl Powerflite..........'54 is when they were introduced and '59 was the last US production pass car flathead 6.
Not that they are easily found, but surely there are some out there. If you do decide to spend for an adapter to a later model trans, also check with Bendtsens www.transmissionadapters.com. Not cheap, but very well made.
Ray
__________________
"In any conflict between Physics and Style, Physics always wins"
Old 05-26-2011, 05:10 AM   #10
rdrunner1974
Newbie
rdrunner1974's Avatar
/6 or 318 with 904 is easy swap
__________________
My Doc gave me pills for memory loss, but I forgot where I put them.
Old 05-26-2011, 08:28 AM   #11
George
Old School HAMBer
George's Avatar
Quote:
Originally Posted by Frankie47 View Post
That's him! Like his better than Wilcaps.
__________________
Confucious say Tennis elbow better than Tennis balls
Old 05-26-2011, 08:55 AM   #12
Mr Blue
FNG
Mr Blue's Avatar
I think you should go with an adapter.
Spend the money now. It will be a much more enjoyable car with a good shifting, reliable tranny behind it. Thanks. Don
__________________
"Once Again I have thoroughly disgusted myself"
Old 05-26-2011, 09:49 AM   #13
73RR
Old School HAMBer
73RR's Avatar
Thanks Frankie and George.
Yes, I can adapt the A904/A500 as well as later Mopar manual boxes to the flat 6 and 8. I am way behind on getting details on to the web site so if you have questions send a PM.
__________________
www.qualityengineeredcomponents.com
Early Hemi Parts, Pieces, Tech
Trans adapters for EarlyHEMI, Flat 6&8 and pre-62 A series
http://www.discoverthenetworks.org/Articles/Hansen.pdf
Old 05-26-2011, 10:12 AM   #14
1950coronet600hp
Senior Member
1950coronet600hp's Avatar
if you can find an adapter plate, I would run an a500, there not electronic, just have an electric operated torque converter lock up and 4th gear operation, which is easy to control with 2 switches inside the car, and with the exception of an extra gear they are no different then a 904.
__________________
No trees were killed to send this note but a large number of electrons were terribly inconvenienced
Old 05-26-2011, 01:16 PM   #15
d2_willys
Old School HAMBer
d2_willys's Avatar
Ray
54-55 P'flites had typical column linkage, but 56-59 were pushbuttons. Don't recall if Plymouth used cast iron t'flites with 230 6 cyl flatties, but if they did, u could also go that route. I would think the biggest issue in using a modern transmission and an adapter plate would be starter issues. If the transmission is for a V engine then how the 6 cylinder back of block could have interference issues, unless the starter on these adapter plates are mounted below bottom of block.
__________________
Dual range hydros rule!
Wise man say to 53 Olds with Dynaflow owner: SHIFT TO LO & GO!
Old 05-26-2011, 08:03 PM   #16
73RR
Old School HAMBer
73RR's Avatar
Quote:
Recall that on a Mopar the starter mounts to the bell.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
