Projects 1929 Roadster Pickup Build
Discussion in 'The Hokey Ass Message Board' started by Salt Flats Speed Shop, Jan 14, 2011.
  1. Salt Flats Speed Shop
    from Utah
    This is a father and son project for a guy here locally. He is building it for the son and they have been collecting parts for almost 10 years. They are having me finish building the frame and suspension, mount the engine and trans, mount the body, and get it a complete roller.
    Everything on this rod is pretty high dollar. The body and frame are from Last Refuge. The body is put together well, as well as the frame. (But im not sure what his plans were for the rear model a crossmember, because he had it tilted forward 3 degrees. So I had to cut it out and put it in right). It has a winters quickchange that is converted to 9" axles. Allen Johnson's rear radius rods. The new 32' original style axle from superbell. Socal hidden disc brakes. And to top it all off it will be running a completly built french flathead with a Navaro 3 deuce intake and a 5 speed.
    When I got it in the shop the first thing I did was mock everything up on the chassis so I could figure out the ride height of how the frame was going to sit off the ground.
    cheddar likes this.
  2. Salt Flats Speed Shop
    from Utah
    Now that I have figured out where the frame will sit in reference to the ground I tacked some tubing from the frame onto the frame rack to hold the frame solid.
    The next thing is to get the suspension figured out on the back. I have to get it exactly right because there is absolutly no adjustment at all in the rear radius rods.
  3. Looks like an awesome start. Great stance.
  4. I love it! That looks just like how mine would look, if I had money or skill.
  5. sits right...looks great...off to a good start
  6. pan-dragger
    pan-dragger
    nice, it's got the look.
  7. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    "High dollar" is not a bad thing if it's accompanied by it's long distant cousin "taste". Sits right and looks pretty damn cool!
  8. Salt Flats Speed Shop
    from Utah
    I got the new suspension brackets laser cut and got the suspension in place.
  9. dirtbag13
    dirtbag13
    looks good so far !
  10. Another great build on the HAMB. What is the plan for the bed?
    Keep up the great work SFSS!
  11. _ogre
    _ogre
    from Motown
    nice build.
    nicer shop and build table...
  12. threeston
    threeston
    looking at it, my mind says the suspension relies on flex more than articulation?
    when one wheel goes up and the other goes down, when turning for example, how will it not fatigue those axle mounts?
  13. SteadyT
    SteadyT
    You do some quality work out there. Must be the lower alc.% in Utah keeping you sharp! j/k
  14. Stu Padasso
    Stu Padasso
    What ever happened to the 32 Tudor????????
  15. -Brent-
    -Brent-
    Chris, did you make those radius rods?
  16. Nice work. Is there a torque arm or equivalent to go with those rear bars?
  17. Salt Flats Speed Shop
    from Utah
    No plans for a bed, just the gastank behind the cab.
    I honestly don't have an answer to that question. I just set it up the same as alan johnson did in the street rodder tech article. (http://www.streetrodderweb.com/tech/1003sr_hot_rod_wishbone_suspension/index.html)
    Can someone chime in and give their two cents?
    Ive been blocking the sheet metal getting things ready to paint. So it all looks the same even though im getting close to paint. Ill update soon i promise. :)
    No they are made by Alan Johnson.
    Thats all that came with the kit from alan johnson. The owner is thinking of putting a sway bar setup, and a panhard bar.
  18. 94hoghead
    94hoghead
    gonna be sweet...
  19. GaryB
    GaryB
    from Reno,nv
    nice ride, are the rear frame rails going to be cut offbehind cross member? what kind of tank is going on it?
  20. need louvers ?
    need louvers ?
    The rear suspension is relying on the same basic method of triangulation that Henry Ford built into every pre '48 Ford product. The articalation of the rear axle moves in a radius determined by the closer mounting of the front pivots on the radius rods. Think of it as a triangle - put the point down on a table and grab either corner, then see how it all moves as you roll it back and forth. This rear suspension will have a tiny amount of "bind" due to the fact that the front mounts are spread just a bit, but not enough to make any real difference in handling or ride quality...
    beautiful work by the way!
  21. threeimpalas
    threeimpalas
    It's an interesting body: 29 cowl with what looks to be a 32 back half.
  22. 58fed
    58fed
    Any shots of the front suspension, looks clean with the Quarter eliptics, they are really hidden. Nice lookin project.
  23. jimbo121
    jimbo121
    Looking good! Nice shop too.
  24. Iron Crank
    Iron Crank
    You're great to work with Chris. Very talented.
    I can't wait to see what folks think of your hairpins.
  25. Salt Flats Speed Shop
    from Utah
    I worked on making the body mounts yesturday and today. They will be welded to the sides of the frame and have rubber pads on top for the body to mount to.
  26. truckncoupe
    truckncoupe
    Very cool, thanks for sharing!
  27. 1929
    1929
    from Pomona
  28. x2.......I'd be keen to see your set up.
    nice workmanship btw
  29. brady1929
    brady1929
    very nice work
  30. Salt Flats Speed Shop
    from Utah
    Ill definitely do some detailed shots of the front end when I start making the hairpins.
