Reply
Thread Tools Display Modes
Old 01-08-2011, 08:05 PM   #1
Roothawg
Old School HAMBer
Roothawg's Avatar
Default Vatting a block (Caustic)
I have a block that has been bored but not final honed. It is not clean enough for my liking. I was wondering if a caustic vat would wreck the cylinder walls of the fresh bore. It still has to be final honed. It was jet washed previously.
Thanks
Root
__________________
Drive.
http://www.hotrodhundred.com
offline   Reply With Quote
Old 01-08-2011, 09:05 PM   #2
Roothawg
Old School HAMBer
Roothawg's Avatar
Default Re: Vatting a block (Caustic)
Dang....3 pages down in an hour.
__________________
Drive.
Old 01-09-2011, 07:24 AM   #3
Vern Christy
FNG
Vern Christy's Avatar
Check out thread by Dolmetsch on his New FED Build. Don just useds his homebuilt caustic tank on his Poly Motor.
__________________
Vern Christy
Motorsport 1320
Taggz Collector Cards
AJC-CA 1427
SFI-IH-S143 Silver
613-827-1582
Old 01-09-2011, 07:34 AM   #4
The Shocker
Old School HAMBer
The Shocker's Avatar
I wouldnt think it would hurt the finish on the cylinder walls if you dont keep it in the caustic soda too long. I etch aluminum in it at work and it doesnt even eat it too much for 3 or 4 minutes.We also use it to clean the aluminum build up off the steel dies and they soak for 12 hrs in it ...
__________________
Go for an 11.5 ET ride in my Dodge .http://www.youtube.com/watch?v=OAjcsGx6hqo
Old 01-09-2011, 07:45 AM   #5
noboD
Old School HAMBer
Roothawg, it won't hurt the bores but will eat cam bearings if they are still in.
__________________
Hot snot, NOW we're back in business!! Doc Hudson
Old 01-09-2011, 09:10 AM   #6
wfo guy
Senior Member
The vat won't hurt it. As stated, it will destroy alum. If the oil galley plugs haven't been removed, do that before vatting. There's no such thing as too clean at this stage.
online   Reply With Quote
Old 01-09-2011, 09:16 AM   #7
Ole don
Alliance Member
Ole don's Avatar
Location: Southern Illinois half way between Benton and DuQuoin
The shop who does the machine work on my blocks always give it a short shot when the machine work is done. They blow it off and wipe it down right away when it comes out, and they deliver a clean block.
Old 01-09-2011, 09:29 AM   #8
Old School HAMBer
squirrel's Avatar
A normal caustic hot tank (for iron) won't hurt iron. It's the soft metals you have to worry about.
Also after it's honed, you'll need to clean it very well to remove all the metal and abrasive particles. I consider this the responsibility of whoever assembles the engine to give it the final cleaning. I would never assemble a block without cleaning it myself first, no matter how nice it looks coming from the machine shop.
__________________
Jim Forbes
my shtuff
Old 01-09-2011, 11:07 AM   #9
Engine Pro 5X
Old School HAMBer
Engine Pro 5X's Avatar
I like to give em a dip in the hot tank for at least 48 hours then after all machine work is done I give em a spin in the Jet Washer for about 3 hours with brushing all of the holes and bores in between washing cycles. When I present the block to the customer I will have all of the plugs installed along with the cam bearings. The cylinders will be clean and lightly oiled to prevent rust and the block is wrapped in an engine bag ready for the builder to get to work >>>>.
__________________
GET IN THE TRUCK JETHRO!!! WE'RE GOING TO CALIFORNIA!!! SWIMMING POOLS!!! MOVIE STARS!!!***CAN I SHOW YOU MY BEST KIELBASA ???
Old 01-09-2011, 11:07 AM   #10
ems customer service
Senior Member
ems customer service's Avatar
caustic is quick harms soft metals, i would pay to have this done not a home job,
but as a option a least for home how about soaking the block in kersosine in a 55 gal drum for about a week, should work well and cheap. does not hurt the softer metals.
now remembering a thread on the hamb a while back i made fun of the post as it sounded stupid but after awhile it made sense.
soak it with kerosine and the hit it with a power washer after the wash. 3/1 oil the block to stop rusting, have a few small dia steel brushes for the oil galleys and done
Old 01-10-2011, 10:39 AM   #11
Roothawg
Old School HAMBer
Roothawg's Avatar
Well, the deal is, I got this block in a trade and it was rough bored but all the cam bearings, plugs etc were still in it. It was put in the jet washer and is somewhat clean, but not clean enough for me.
I am knocking all the flahing off the outside and sort of polishing the visable areas.
Now, I wanna put it back in a vat to get rid of any leftover junk. Then I'll have it honed and then I'll clean it thoroughly before I assemble it.
__________________
Drive.
Old 01-10-2011, 10:51 AM   #12
FWilliams
Senior Member
FWilliams's Avatar
knock the plugs and bearings out of it and run it thru the tank
Fred
__________________
Old 01-10-2011, 11:11 AM   #13
Roothawg
Old School HAMBer
Roothawg's Avatar
I knocked all of the cam bearings and soft plugs out this weekend. I have to look for a shop with a vat. The epa has made it so hard around here that most shops just have the roto-jet or whatever they call em.
BTW Fred, I am building the 327 article that you did a few years back.
__________________
Drive.
Old 01-10-2011, 06:05 PM   #14
FWilliams
Senior Member
FWilliams's Avatar
cool beans...
we dont use the vats around here much anymore either, most everything is burn and blast.
Fred
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
