Reply
Thread Tools Display Modes
Old 12-03-2010, 08:41 AM   #1
oldrelics
Senior Member
oldrelics's Avatar
Default Flattening enamel paint with talc - Experience with ratios?
I am going oldschool and flattening some paint with talc. Does anybody have any experience with ratios needed (as a baseline)? I have 2 quarts of enamel I need almost dead flat. Now I tried the pro flattening agents from the suppliers and it just made paint thin and changed color. I'm NOT going back there.
I used the search and talc is mentioned lots but nobody states how much to add.
Thanks
offline   Reply With Quote
Old 12-03-2010, 05:25 PM   #2
Ancient Rodder
FNG
Default Re: Flattening enamel paint with talc - Experience with ratios?
John Deer sells an enamel called Blitz Black. You'l probably have to order it from them on line. It's not expensive, as paint goes, and works dam good for flat black on a street rod. you might just check it out.
Old 12-03-2010, 05:42 PM   #3
oldrelics
Senior Member
oldrelics's Avatar
Quote:
Thats fine if you want black.
Old 12-03-2010, 05:46 PM   #4
Ancient Rodder
FNG
God ment for street rods to be FLAT BLACK.
Old 12-03-2010, 06:37 PM   #5
hotrod40coupe
Alliance Member
hotrod40coupe's Avatar
Just spray it with flat clear.
Old 12-03-2010, 06:54 PM   #6
CutawayAl
Senior Member
I have worked quite a bit with flattened paints. I don't know what kind of flattener you tried, none I have used thin the paint. Flattener normally contains solids. It settles really bad and takes a lot of work to get all the solids re-suspended. If the flattener wasn't thoroughly mixed that could have thinned the paint and produced unsatisfactory results. Either buy the color you want, use flat clear, or buy some good flattening agent and play with it until you get what you want. No matter how you flatten the paint, the amount of flattener needed for a given flatness will vary with the paint used, how the paint is applied, and how quickly the paint drys(temp). Those variables can make a lot of difference, so there is no general answer to your question.
This recent discussion here might be helpful.
http://www.jalopyjournal.com/forum/s...d.php?t=532624
Old 12-03-2010, 07:08 PM   #7
Pure Hell
Grenade Inspector
Pure Hell's Avatar
The old sign painters I use to work with used damb near anything .. baking soda, cornstarch... This was for brushing...
I used less than a quarter cup of cornstarch in a full quart and got about 80%...
If I was trying it on something good I'd say mix a few samples first on something like a 1'x1' panel...
__________________
" Women don't think like Men !"
Old 12-03-2010, 07:13 PM   #8
Chris Stapley
Chris Stapley's Avatar
The tlac works fine in One Shot enamel when sign painting, but I'd be leary about trying to be consistant enough to spray something as large as a car body, bad news from the start. If you're looking to do it on the cheap, use a flat clear, if you're really cheap use flat clear varathane.
Old 12-03-2010, 08:02 PM   #9
low-n-slo54
Senior Member
low-n-slo54's Avatar
No, r/r's are flat black. Rods need to be shiny. From what I remember 25% talc will give you medium satin and 50% will give you a full satin. However, remember that the more talc the weaker the paint. IMHO. The gun will be tough to get the flow right as well.
__________________
Goldchainers C.C./Munsterville Chapter
Breathe if you hate radials.
Old 12-03-2010, 09:23 PM   #10
KoolKat-57
Senior Member
KoolKat-57's Avatar
Used talc to match a repaired panel on a white Ford with weathered paint(very weathered). Took quite a bit to dull down the finish, but it matched very well.
We had to experiment, I think you will too!
Good Luck!
Old 12-03-2010, 09:28 PM   #11
lippy
Old School HAMBer
lippy's Avatar
I have used flattener in regular clear for interior paint. Works really well. Just shoot the same color base you used on the car(if that's what color you want the interior), then apply the clear with flattener, always worked great for me. JMO. Lippy
Old 12-05-2010, 03:45 AM   #12
kevron
Alliance Member
kevron's Avatar
i have used awax based flatning agent with good results allso spray your beast with the colour you want then get the green kitchen scourer and ajax powder and heaps of good old elbogreas it wont change the colour give it a couple of waxes and bobs your uncle
__________________
i love the smell of burning rubber so mutch i will still be buying condoms when i am 90
Old 12-05-2010, 06:15 AM   #13
darkk
darkk's Avatar
This company has any color flat and also carries flat clear.....
http://www.tcpglobal.com/kustomshop/
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
