Reply
Thread Tools Display Modes
Old 11-30-2010, 10:55 PM   #1
oldrelics
Senior Member
oldrelics's Avatar
Default ESAB EASY GRIND VS LINCOLN mig wire
offline   Reply With Quote
Old 12-01-2010, 01:27 AM   #2
Piston Farmer
Piston Farmer's Avatar
Default Re: ESAB EASY GRIND VS LINCOLN mig wire
Interesting, thanks for posting
__________________
"The only good years in our life, are the tires on our car" ~ Jim Stafford
Old 12-01-2010, 02:52 AM   #3
Rodhotz
Senior Member
Rodhotz's Avatar
So what you are saying is same shit!
__________________
Never put off today what you can put off till tomorrow..By then some other sucker might do it!
online   Reply With Quote
Old 12-01-2010, 06:51 AM   #4
Paul
Editor
Paul's Avatar
what happens when you grind the continuos weld flush, beat on it with a hammer, then bend it?
does it crack in the weld or tear the parent metal adjacent to it?
Old 12-01-2010, 07:51 AM   #5
oldrelics
Senior Member
oldrelics's Avatar
oh, I didn't do that one.....and probably won't
Old 12-01-2010, 07:53 AM   #6
Phil1934
Senior Member
Phil1934's Avatar
I used two rolls and could not see a difference so went back to the standard stuff.
Old 12-15-2010, 02:07 AM   #7
Hitchhiker
Old School HAMBer
Hitchhiker's Avatar
Interesting.....
__________________
Instagram: Wallingford_Hot_Rods
Old 12-15-2010, 05:33 AM   #8
saltracer
Grenade Inspector
saltracer's Avatar
The guys at the welding supply place where I get my Argon mix (or whatever it is) bottle filled told me it was the same. This pretty much proves it.
__________________
Holder of THREE land speed records with FLATHEAD power! (Faster than Skotz)
Old 12-15-2010, 05:42 AM   #9
moefuzz
Old School HAMBer
moefuzz's Avatar
Your kinda missing the point of easy grind wire.
It's more malleable or workable.
-As in hammer welding.
Easy grind is made to be worked longer before failing while using less force to accomplish the task.
Hammer welding is a poorly understood body working technique that is seldom used in body shops as the so called fabricators are not really welders as much as they are a guy with a welder at his disposal and they know nothing of hammer welding or what it would be useful for.
A good fabricator/welder will know how to work a hot weld bead to reduce warpage/shrinkage as he welds a panel into place.
Easy grind allows for easier working of the weld whether it is hot or cold.
Mig wire (in general) is very hard and brittle.
Easy grind elevates some of the hard brittle nature of the actual mig wire that is deposited in the the welded panel.
Also, your pic of the broken metal at the edge of the weld just means that the two pieces of metal were identical/malleable and hence the (similar pieces of) metal broke at about the same place under the same amount of stress.
The metals malleability or lack thereof has nothing to do with how malleable the actual deposited wire or weld was.
As others have mentioned, work the weld then report back .....
....Perhaps once a person understands how the wire was made to be used and how he can make use of the wire, then maybe a more positive revue of this (excellent) wire will result.
-Reading up on hammer welding might also help to understand the idea behind using a more malleable mig wire to yours and to it's full advantage.
Additionally, a person might benefit form being able to install patch panels with less warpage which ultimalty speeds up the job of restoring your project while also improving the quality of your restored body.
Also consider that a person can save considerable money on things like sandpaper and fillers over and above the time that is saved in not having to use them to such an extreme extent.
http://www.google.com/webhp?sourceid...111c1d610a8252
"As the weld cools, the metal wants to shrink, so your job is to counteract the shrinkage and return the metal to its original shape. As soon as you finish the tack/weld, position your hammer and dolly directly over the center of the weld and start hammering on-dolly. Don’t overdo it, though—you’re not hammering a nail into cement. Let the weight of the hammer do the work, but work fast. The whole procedure only lasts for about 15-20 seconds from beginning to end"
jmho
__________________
.. Wise men talk about ideas, ordinary men talk about things, fools talk about each other
Old 12-15-2010, 08:51 AM   #10
oldrelics
Senior Member
oldrelics's Avatar
jmho
I was just testing its own claim of "EASY GRIND".
I'm done with it.
Old 12-15-2010, 08:59 AM   #11
39 All Ford
Alliance Member
39 All Ford's Avatar
Quote:
I'm done with it.
It does say "easy grind".....
__________________
Building a car is easy, building a car right is a mite bit harder.
Old 12-15-2010, 08:59 AM   #12
BulldawgMusclecars
BulldawgMusclecars's Avatar
My dad experimented with a low carbon steel wire (basically all EZ-Grind is, from what I understand), and saw a huge difference in ease of grinding the welds. Grinding can cause warpage just as easily as bad welding technique,so I can see the benefit. The softer wire also makes it easier to hammer, as previously mentioned. He has some EZ-Grind, but hasn't used it yet. He gave me a roll of his low carbon steel wire last weekend, but I haven't tried it yet.
__________________
Joe Hinds
Bulldawg Musclecars
4666 S. Main Street
Acworth, GA
http://www.bulldawgmusclecars.com
Old 12-15-2010, 03:21 PM   #13
chickenridgerods
Senior Member
chickenridgerods's Avatar
I'm done with it.
I can't seem to see where you actually ground or hammered on the weld beads to test the "easy grind" claim.
__________________
Mike
Wanted:
- ARDUN parts: Hilborn & misc
- '32-34 Ford RPU parts, radiator cap, rear fenders
Old 12-15-2010, 07:40 PM   #14
oldrelics
Senior Member
oldrelics's Avatar
Quote:
5th and 6th photos show welds ground on the ends of the pieces not middle butt joint. Never hammered anything, not what I was trying to do.
Old 12-15-2010, 08:13 PM   #15
TexasHardcore
Old School HAMBer
TexasHardcore's Avatar
MoeFuzz is right, the Easy Grind wire isn't just supposed to be easier to grind, it's more malleable so after the weld proud is ground smooth, you can hammer & dolly any high & low spots along the seam.
People tend to think that TIG or gas welding is the only way to repair a panel, but many metal craftsmen have proven that it's not impossible to have a perfectly metalfinished joint using MIG. I'm thinking the Easy Grind wire will aid in this.
__________________
Tune Up or Tune Out.
Old 12-16-2010, 05:02 PM   #16
55 dude
Old School HAMBer
55 dude's Avatar
the tensile strenth of E-Z GRIND is right at 50% of your standard mig wire. using it for anything other than sheetmetal work is asking for trouble. i used to bitch about cost but ESAB claimed shorter production runs increased the product cost.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
