Reply
Thread Tools Display Modes
Old 11-29-2010, 11:43 AM   #1
orula
orula's Avatar
Default How to lower my 53 Chevy truck?
Hello everyone,thank you in advance for your help and your advice.
I'm doing a restoration on my '53 Chevy truck and I'm doing a lot of updates. I installed a front end IFS Mustang II Air Ride and Rear 4 link bar. I had two C-Notch to drop the rear frame. Can I install only Shokwave in the rear instead of installing the air bags and shock absorbers? What other changes do you need the frame?
Many many thanks. Frank
online   Reply With Quote
Old 12-15-2010, 09:05 AM   #2
orula
orula's Avatar
Default Re: How to lower my 53 Chevy truck?
Hello Guys, in the meantime I did some work to lower my pick up. I try to insert some pictures and tell me what you think
Old 12-15-2010, 10:16 AM   #3
orula
orula's Avatar
On the rear:
[IMG]
http://i1024.photobucket.com/albums/...NKC-NOTCH5.jpg[/IMG]
Old 12-15-2010, 10:31 AM   #4
Chevy54
Senior Member
Chevy54's Avatar
Wow...good looking work. This could be a informative thread for someone doing the same. If you have not bought your shockwaves yet i would recomend using reg style bags with external shocks. I had a set of Shockwaves and hated them...minimal travel and a hard ride. You willl get alot more travel and a much better ride and save a boat load of cash!! Good luck man!
__________________
Eric
My 51 Daily Driver Build
http://www.jalopyjournal.com/forum/s...d.php?t=570961
offline   Reply With Quote
Old 12-15-2010, 10:37 AM   #5
jgang
Grenade Inspector
jgang's Avatar
very nice work. please keep the updates coming. this is very imformative. thanks a million. have a good day
Old 12-15-2010, 10:43 AM   #6
TMoney
TMoney's Avatar
I've heard shockwaves wont travel as far. There is no replacement for a good set of normal bags. Shocks are the easy part anyway. Awesome looking work though man. That thing is LOOOOOOOWWWWW!!!
__________________
MISFITS INC. Spokane, Wa
Old 12-15-2010, 12:09 PM   #7
orula
orula's Avatar
Many thanks guys, for me it is an honor that you appreciate my work. I studied a lot and saved thousands of photos to learn and of course you are my teachers, so I thank you very much for your help. I will continue to add photos and I will be happy to help someone. On the back I thought to install a pair of Shockwave 8000 Black Series 5 "Stroke, what do you recommend for me? Thanks again
Old 12-15-2010, 12:18 PM   #8
PurdueSD
Alliance Member
PurdueSD's Avatar
Nice! Where did you buy the four bar set up from?
Old 12-15-2010, 12:59 PM   #9
Chevy54
Senior Member
Chevy54's Avatar
Quote:
I would stay away from them..there are better and less expensive ways that will give you a better ride for a little more work and I see you have the fab skills that should make it easy...save your money and fab up some supports for a set of 6inch bags and external shocks...you will be happier in my opinion.
__________________
Eric
Old 12-15-2010, 02:33 PM   #10
orula
orula's Avatar
Quote:
This is a rear 4 link Heidts brand and I bought from SummitRacing. Unfortunately I live in Italy are penalized for the high cost of shipping and taxes for purchases in the U.S. for the heavy parts but the passion to have an American car was too strong for me and now I want to take this project forward.
Old 12-15-2010, 02:42 PM   #11
orula
orula's Avatar
Quote:
Thanks Chevy54, I just have to find the right position to install the airbags (you said this?) and I will try to capitalize on your valuable suggestions. I hope to find a suitable space that does not hinder any movement. Sorry for my english. Many thanks
Old 12-15-2010, 03:16 PM   #12
Chevy54
Senior Member
Chevy54's Avatar
From what I can see from your pics....I would install 2 cross members at the top of your C-notch, one both front and back then make plates over the axle housing and install your bags directly over it. Looks like you have plenty of room for it to work at a 1:1 ratio. Then mount shocks on the backside or rearend. I would also install some rubber snubs from a traction bar setup in your C notch so there is no metal to metal bottom outs! Just throwing out ideas if you have not already thought of them.
BTW..English is perfectly fine man!
__________________
Eric
Old 12-16-2010, 07:46 AM   #13
orula
orula's Avatar
Thanks for your advice Eric, just yesterday I welded the Panhard bar on the C-Notch.Should I weld the other two brackets on the rear-end and two on the Panhard Bar for the installation of airbags.
Congratulations on the car of your Avatar.Many thanks and you have a nice day. Francesco (is my real name)
Old 12-16-2010, 01:14 PM   #14
Chevy54
Senior Member
Chevy54's Avatar
Thanx...You should be able to fit a bag in between your panhard bar mount and the C-notch.... Just fab up a upper mount for bag now off of what you have there. You will be glad u went the bag route over shockwave im sure.
__________________
Eric
Old 12-16-2010, 03:46 PM   #15
Hondo78
FNG
Hondo78's Avatar
Very nice work, I am about to cut into my '36 frame as well and followed the warnings about the Shockwaves, as easy to install but lacking in the ride department. My '54 Chevy PU project is next and you have given me the bug to cut it up and drop it this winter.
Great work, also cool wheels in the back ground of the first photos black wide rims, fit a Jag 5 on 4.25"??
__________________
"If you want a custom, you have to cut it up to make it yours"
Old 12-16-2010, 04:37 PM   #16
Wvgearhead
FNG
Looks good man!
Old 12-18-2010, 04:09 PM   #17
orula
orula's Avatar
Thanks for the compliments Hondo78. The wheel rims you saw in the first photo are preliminary and were of a BMW 320 5x120 bolt patt, 16x7".
For my Chevy pick up I took 4 Wheel Vintique Chrome Smoothie 15x6" front and 15x7" rear with Bullet Style center caps.
Old 12-27-2010, 03:40 PM   #18
orula
orula's Avatar
Smile Re: How to lower my 53 Chevy truck?
I'd love to hear your opinion. Not be long before it comes time to paint the frame of my truck. I thought about doing black with silver details, but thinking it would not be a bad idea to do white... White frame, rear end and various components in silver. What do you think? It would be folly to paint it white and silver? Many thanks
Old 01-10-2011, 09:59 AM   #19
orula
orula's Avatar
Hello everyone , please I need some advice from you. Should I buy the kit for Air Ride (Air Tank,Dual Compressor ecc.) and I wanted to ask you for advice between these two brands: AirZenith or RideTech? There is a kit that I really like and it is this:
http://cgi.ebay.com/ebaymotors/ws/eB...AQ:MOTORS:1123 ....
I do not know if you can say ...?
I decided to paint the frame in White, what do you think?
Many thanks. Frank orula
Old 01-16-2011, 04:11 PM   #20
orula
orula's Avatar
Hello guys, today I will post a slide of my truck from the beginning till today. Click on the picture below
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
