Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Grenade Inspector
I have a 1960 Chevy 283 engine and want to put a 350 turbo trans to it--but will not bolt up to engine bell housing have a 1 1/2 '' space between engine and trans---flywheel and flexplate-( small 13'' flywheel) hits--also what year starter to use-stagger bolt pattern---looking for person who has this combination and what did they do--Thanks
#2 |
Old School HAMBer
As long as you have "NOTHING" bolted on to the back of the block a 350/400 turbo trans "WILL" bolt right up!
#3 |
Alliance Member
Take the flywheel off and bolt flex plate on.....
__________________
H.A.M.B. CHAPEL CROSS MEMBERS CC |
#4 |
Newbie
is the torque converter all the way into the tranny?
#5 |
Senior Member
#6 |
Old School HAMBer
use one or the other...flywheel for standard trans, flexplate for automatic. not both.
63-80something starter should work, ask for one for a 307 engine from about 1970 with the th350 trans in a midsize car (chevelle/nova) |
#7 |
Alliance Member
no flywheel. flexplate with atuo tranny .
__________________
"TOO MUCH BOOGIE WOOGIE" |
#8 |
Grenade Inspector
You are using a Chevy 350 tranny ,, Right?
Should bolt directly to the block. Tommy |
#9 |
Old School HAMBer
did you remove the stock adapter that was used from the factory on your then power glide?
#10 |
Old School HAMBer
it's a natural fit. 350 turbo to a 283
#11 |
Alliance Member
IT will bolt right up. Sounds like the torque convertor is not all the way in. You might have to use the larger diameter flywheel cause not all the 283 blocks have one of the correct holes for the starter housing that works with the small flywheel. Before installing the tranny make sure you have the starter/flywheel combo worked out.
__________________
Just what I need......Another Nailhead! Makin it Git with Old Shit |
#12 |
use flexplate only with auto trans, you do know that dont you?
#13 |
or check and make sure you dont have a BOP trans. but it sounds like you have some ohter issues. follow the advice the others have given and you sound be OK.
__________________
http://www.myspace.com/atomicbrothersphotography No matter where you go. There you are! |
#14 |
Old School HAMBer
why do you have a 13" flywheel in this assembly? and where did the 1½" spacer come from? You make it trying solve the problem? You must have some seriously long crank flange bolts to keep the flex plate AND flywheel in there.
dj |
#15 |
sounds like an Olds or Pontiac trans ... photo please
#16 |
Newbie
Pilot bushing left in the end of the crank, not allowing the input shaft of the tranny to slide into the crankshaft ?
#17 |
Old School HAMBer
pictures help dude!
#18 |
Old School HAMBer
Not on an automatic!
#19 |
Newbie
So did ya finger it out ?
#20 |
Grenade Inspector
Remove the adapter plate for the powerglide trans!!!!
| Thread Tools | |
| Display Modes | |
