Reply
Thread Tools Display Modes
Old 11-17-2010, 11:29 AM   #1
46international
46international's Avatar
Default Tail light glue
I was wanting to do some custom tail light mods to my wife's OT car. I will have to cut them apart and reglue when done, What type of glue would "melt" the plastic as it glues it together. like the old testers model glue did with the car models we used to build. I did a search but did not really find an answer.
offline   Reply With Quote
Old 11-17-2010, 12:03 PM   #2
Homemade44
Homemade44's Avatar
Default Re: Tail light glue
Here is a link for Testers plastic glue. http://www.testors.com/category/1366...nt_for_Plastic
Not in the yellow tube any more.
__________________
Joe
Old 11-17-2010, 12:03 PM   #3
sunsetdart
Grenade Inspector
Not sure when you say cut them apart and reglue. If you are talking about a "butt joint" when gluing, you may want to use a super glue cause it will bond two smooth surfaces. Same goes for a smooth lap joint surface.
Old 11-17-2010, 12:45 PM   #4
Blue One
Alliance Member
Blue One's Avatar
Cutting them apart is the easy part. What works best to put them back together is a good quality 2 part epoxy.
Not too likely you will find a glue that will melt the plastic together.
The epoxy will do the trick and when dried will make a waterproof seal.
Old 11-17-2010, 12:51 PM   #5
Traditions Racing
Old School HAMBer
Traditions Racing's Avatar
A lot of glues will " cloud " the plastic, I would go to the junk yard and get some practice pieces for each glue or epoxy before you try it on the actual parts, just sayin, BDM
Old 11-17-2010, 12:59 PM   #6
Ebbsspeed
Alliance Member
Ebbsspeed's Avatar
Quote:
I think he means "soften" instead of "melt". I haven't built a model car for years, but way back in the 60's the stuff we called airplane glue would soften the plastic surface for a couple of minutes. When you stuck two pieces of plastic together with the stuff, it was STUCK. If it ever broke, it was the plastic that broke and not the glue bond.
If you've ever done any plumbing with PVC and PVC cement, you know what I'm talking about.
Old 11-17-2010, 01:05 PM   #7
57ford/60thunderbird
Old School HAMBer
57ford/60thunderbird's Avatar
i wouldnt use testers not the same old stuff its now non-toxic enviro friendly junk its lucky to glue a model together now a days
i would use a 2 part appoxy as was mentioned you can get clear from hobby shops i got mine from hobby town usa expensive but it comes in like 6 OZ bottles and drys quick and strong and you'll have plenty left over
__________________
my car show pics like pics of cars stop by and enjoy
http://keithsonlinecruisein.shutterfly.com/#
Old 11-17-2010, 03:34 PM   #8
Cymro
Cymro's Avatar
I ve used a product called EMA Plastic Weld to fix broken plastic lenses, to join acrylic sheet, and even to repair broken plastic spectacle frames for my students The Stuff will join Styrene,Butyrate,ABS,Acrylic(Lucite or Plexiglas), Perspex to each other or in any combination, (all on the label), One student even used it to make a custom fish tank to fit in a room divider he was making.
It appears to be more of a solvent than a traditional glue. The hazard warning label on the bottle reads Dichloromethane (Methylene Chloride).
Available from EMA model supplies Ltd, Unit 2, Shepperton Business Park, Goovett Avenue, Shepperton, England, TW17 8BA.
Sorry, no other contact detail to hand
until nowhttp://www.ema-models.co.uk/products/04302-liquid-solvent-cement-ml.html
There must be an US equivalent.
Old 11-17-2010, 03:39 PM   #9
Cymro
Cymro's Avatar
Liquid Solvent Cement (500ml)
Known to experienced model makers as EMA Plasweld, this solvent sticks all normal model making plastics, i.e. perspex, ABS, butyrate, styrene, acrylic etc.
It has a long shelf life, is fast acting (grabs in seconds), and has a water-like consistency so it is best used by holding or clamping the surfaces together and running a loaded brush or applicator along the length of the joint (solvent will be drawn into the joint by capillary action). A second application can be made if required, but is not normally necessary.
When joining dissimilar plastics, i.e. styrene to butyrate, the hardest material (in this case butyrate) should have the joint surface softened, by giving a light coat of solvent, prior to holding the surfaces together. Then proceed as normal.
PlasWeld should be used in a well ventilated area and contact with skin or eyes should be avoided (wash well with water if this occurs). Please note that we sell a variety of applicators and dispensers that will prove helpful.
Also available in 57ml bottles (see code PPC-2P).
PLEASE NOTE: THIS PRODUCT CANNOT BE SHIPPED OUTSIDE THE U.K
Code: PPC-2
Price: 6.00
This product can be found on our Adhesives page, along with similar products that may be of interest to you.
Copyright 2005 E.M.A Model Supplies Limited
This is it ! But no shipment overseas .
Old 11-17-2010, 03:42 PM   #10
325w
Alliance Member
325w's Avatar
Some sign makers that do work with plastics have a clear glue. Maybe a sign makers store.
Old 11-17-2010, 04:38 PM   #11
tommy
Old School HAMBer
tommy's Avatar
I customized my tail lights by super gluing some 56 Chevy tail light bullets to my 56 Ford lenses. Will they hold up? Damn if I know but they seem to be holding real well so far. I tried to knock it off but I couldn't.
__________________
Quote...You are hereby Knighted...'Sir Asseth of Hole' Tommy... 3W Larry.
Quote...It's called "HOT RODDING", not paint by numbers....Fab32
Old 11-17-2010, 05:58 PM   #12
stealthcruiser
Old School HAMBer
stealthcruiser's Avatar
Practice on some scraps, of the material in question, with some acetone.
__________________
Chuck
Old 11-17-2010, 06:21 PM   #13
46international
Thanks for the help with this...I hate to post too many times on this topc, OT car and all. The car in question is a '09 Fusion and I can't take the "tunner" looking tail lights any more. What I want, no need to do is, cut the clear lens off of the red lens under it. Then paint that crappy looking "chrome" that goes around the light. I will then need to reinstall the clear lens.
I was not thinking about clouding the clear lens, so the warnings about that is good thought. i was just wanting to make sure it does not leak or come apart.
I came accross something on another site or in my search on the H.A.M.B. about heating the assy. in the oven and that will soften the glue so you can pry apart the light. Anyone done this?
Old 11-17-2010, 06:27 PM   #14
scrubba
scrubba's Avatar
Im in the exibit business and I use plastics, A LOT. You may want to try usinng a old drafting ruler pen and fill it with a product called Tenax. It's a liquid styerene compatable glue that evaporates quickly and gives a very strong joint after about a minute . A lot of model builders just use plain old Acetone too. scrubba
__________________
See ya on de road folks ..........
Old 11-17-2010, 06:51 PM   #15
Cymro
Cymro's Avatar
There is a product called "Tensol" which is pretty much the same as the Plastic Weld above as well as several others possibly a controlled substance. try this link for some more ideas
http://www.instructables.com/answers...glue-adhesive/
Old 11-17-2010, 07:15 PM   #16
tb33anda3rd
Old School HAMBer
tb33anda3rd's Avatar
be careful trying to soften the glue. a lot of modern plastic anything, is sonic welded.
__________________
my favorite color is rust!
Old 11-17-2010, 07:16 PM   #17
19Fordy
Old School HAMBer
19Fordy's Avatar
Methyl Ethyl Ketone (MEK) but you probably will have a hard time finding it as kids like to sniff it.
http://www.fountainpennetwork.com/fo...mek-as-a-glue/
Old 11-17-2010, 08:29 PM   #18
61 chevy
61 chevy's Avatar
goop in a blue tube, strong glue at hardware store
Old 11-17-2010, 08:37 PM   #19
gmc1941
Newbie
gmc1941's Avatar
I've been able to purchase MEK at Home Depot with in the last year. In the paint dept.
Old 11-17-2010, 08:48 PM   #20
1Cheesecake
Alliance Member
1Cheesecake's Avatar
Ricers have been doing it for years...put it in the oven a low heat to soften the glue...
use a plastic putty knife to help separate the pieces
take your time and don't rush it..last thing you want to do is break the plastic...
when your ready to put it all back together clean off the glue residue and then use clear silicone to seal it back up....
I'm sure if you search on a "Pimp my Ride" website there will be detailed instructions...and maybe even pictures...
Be careful when your there...they might talk you into installing a "Fart Can" exhaust on the Fusion....
CC
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
