Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 06-11-2012, 10:51 PM   #241
dragsled
Alliance Member
dragsled's Avatar
Default Re: FED with killer Flathead
Sounded good in the warm up , I'm sure you guys with get it straighted out, BTW are you looking for another Barrelvalve if so I can check around over here, I'm asumeing it's a square one , Right , Talk to you later Tim Jones
__________________
My Dragster Build http://www.jalopyjournal.com/forum/s...d.php?t=645702
offline   Reply With Quote
Old 06-11-2012, 11:02 PM   #242
mctim64
Alliance Member
mctim64's Avatar
Sounds good on the first start. Needs a little tuning as you said, but you are on your way.
hope you don't mind but I thought you needed the player installed.
__________________
Y-Block Powered Model A Tudor project http://www.jalopyjournal.com/forum/s...d.php?t=667198
"it looks just like a Tellafunkin U-47"
http://yblockguy.com/
Old 06-12-2012, 02:51 PM   #243
fenderless
fenderless's Avatar
Thank you guys for the encouraging words
Roger and I have allready made some plans, so stay tuned
Br
Kjell
Taildragger&fenderless
online   Reply With Quote
Old 06-13-2012, 04:32 PM   #244
fenderless
fenderless's Avatar
Talked to Roger today, and we desided to make a new spool for the barrel valve. Hope this will do the trick!?
Next is to book Dyno/roller to try to tune it for max HP.
The last thing we did was to give the killer some more air, we put on the BIG wheel on the crank!
Br
Kjell
Sidewinder...........
Click image for larger version
ID:	1663982   Click image for larger version
Old 07-06-2012, 05:10 PM   #245
fenderless
fenderless's Avatar
Finally got hold of the Dyno guy! So we are booked inn 17. July.
Hope to get all sorted out so we can get a little faster down the track!?
A new poster poppet up for this years main event for us Vintage guys ower here. Then it's off for the HAMB drags, and warmer weather
Old 07-06-2012, 05:33 PM   #246
roseville carl
Alliance Member
roseville carl's Avatar
Killer pic!
__________________
"Keep Em Between the Whites"........
and yes Virginia the world is Flat!!
Old 07-12-2012, 05:24 PM   #247
fenderless
fenderless's Avatar
Thanks Guys
Have finally managed to get an appointment with the dynoman
Wednesday at 12 noon. So now we just have to finish the dyno headers and mount the new spool that Grinder1 made. Cross our fingers and hope the best!
Br
Kjell
Taildragger&fingerless
ID:	1688903   Click image for larger version
Old 07-20-2012, 02:23 PM   #248
fenderless
fenderless's Avatar
First of all my thoughts go to all victims, families and residents of the in Colorado. Resent you had the big fires, and now the shooting, very tragic.
We have had a few days to ponder on our engine test.
Bored&stroked gave me some valuebal innformation prior to the dyno test.
Alot of thought have gone through my head:
First pull gave us way rich AFR, OK, lets lean it out.
Second run a litle better, now killing a sparkplug, too wet, and one melted down! the wet plugs where the 4 cylinders in the middle. the 4 on the corners are ok. AFR showed still rich.
Thired run, even better.
Rethinking, going through the pills and mapping them.
As we have made a new spool, we desided to lean it down to 20%.
Now the engine start really responding, butt still not good abowe 3000rpm
We continued leaning with baby stepps, just to make shure we did not hurt enything.
I think we got to the 7th pull, when the engine got better and better, it made a big "popp" on full load. Ops! to lean!
After that we got a noise comeing from the bottom end! Not good!
We concluded that we had learned alot, but was still way off our target!
After a short dinner, we desided to get the dragster back to the shop, and tear the pan off, we really needed to find out what was causing the noise.
Roger was really quiet and i think nervous too!
We was really happy that the crank and rods looked ok, the problem was a loos flexplate! I know i torqued it twice! Why? well we need to pull the engine out to find that out.
The other problem need also to be looked at, why it did not perform!?
Well we thing that the blower needs to be checked, as it just managed to push 5 psi of boost. At full load the engine sounded like it was surgeing for air!!? Knowing it might be a worn out blower, I have started looking for a new one.
Oh, figures, the killer just gave us 200hp at 2000rpm's with almost no boost!
The saga continues........
Br
Kjell
Old 07-20-2012, 02:43 PM   #249
Mr 42
Senior Member
Mr 42's Avatar
Awesome Build Kjell.
I hope i will be able to see you at Kjula maybe..
Old 07-20-2012, 03:07 PM   #250
Paulie9fingers
Paulie9fingers's Avatar
Great thread and cool dragster.
__________________
Help battle cancer
http://4kforcancer.org/profiles/paul-wetzstein/
Old 07-20-2012, 03:48 PM   #251
roseville carl
Alliance Member
Kjell before getting new blower did you try any different pulley combo's? may not be spinning fast enough. what were your torque figs?
Glad it was just a bolt issue.........
__________________
Old 07-20-2012, 08:39 PM   #252
dragsled
Alliance Member
dragsled's Avatar
Well Kejll a loose flywheel bolt is a hell of a lot better than a lose rod bolt,well sorta going down the track it could be a really bad deal, Good luck Tim Jones
__________________
Old 07-22-2012, 05:17 PM   #253
fenderless
fenderless's Avatar
The bolt issue looks like a easy fix The pullys we use is 25% over, so if my figuers are right it's gona give approx. 15psi?
We took out the blower, and we found out that I had used too thick a gasket, so to much clearence on the rotors! Also leaking pop-off.
We took the bloower appart and put it togheter to today, so hope everything will go back this week
A new smaller top pully should also help, maybe a one that could give us 35%!?
Kjell
Old 07-22-2012, 05:19 PM   #254
fenderless
fenderless's Avatar
Quote:
I totally agree Tim, lucky that it happened now, and it did not damage anything
Kjell
Old 07-23-2012, 08:53 PM   #255
tommyflathead
Alliance Member
tommyflathead's Avatar
Kjell,
absolutely magnificent and well documented!!
great also to read the global collaboration from all of us die hard flathead nut's !!
__________________
sometimes you have to be like gorilla
Old 07-24-2012, 01:02 AM   #256
roseville carl
Alliance Member
Kjell you just using a pop off and not a burst plate? the 25% od will give you somewheres around 13 or so depending on your CI and how much backpressure you have on the exhaust side and cam timing all play a part in the final numbers thats the fun of it .......playing!!! Just make sure you go in small steps to keep out of detonation.......
__________________
Old 07-24-2012, 04:33 PM   #257
fenderless
fenderless's Avatar
Thanks
Yes we just have pop-off, that funny thing at the back of the inntake, pointing nicely towards my head! There was not enough space for a burstplate.
Next uppgrade will be a new inntake with port nozzles.
We was thinking of making it with all runners towards the middle, so we probably will get more even mixture. As our current intake, it tends to get too rich in the middle cylinders, and leaner on number 1,4,5,8.
We have also desided to just use our current set-up 25%, and upprade with newer style belt set-up, and gear for 45-50% to get us up to 20+ psi.
When i mailed my specs to Hilborn, they sent me four 61A nozzles, are they to large?
Kjell
Old 07-31-2012, 05:26 PM   #258
fenderless
fenderless's Avatar
Finally got everything back together, we had the engine out to fix the flexplate.
We changed the bolts with new that does not have threads all the way up, and more locktite. hope it will not come loose again!
As we had the engine out, we checked the bearings, and everything looked OK! Now it's just to load her up and try out our luck next race
K
Old 08-18-2012, 05:58 PM   #259
38FLATTIE
Old School HAMBer
38FLATTIE's Avatar
kjell, make sure to hook up with Randy Jackson of The Gasser Garage, and Sam Woodard, at the HAMB drags!
Old 08-31-2012, 09:50 PM   #260
fenderless
fenderless's Avatar
Thanks for the advice Buddy, but could not log inn to net before the drags.
But met the King Chassis crew
Hopefully i will meet a Flathead guy here in NW Arkansas in a couple of days
Br
Kjell
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
