Reply
Thread Tools Display Modes
Old 11-14-2010, 04:44 PM   #1
jsteph
FNG
jsteph's Avatar
Default What do you think about a 455 olds?
Looking at getting a 455 olds, any comments questions, ideas?? Thoughts on the engine itself??
offline   Reply With Quote
Old 11-14-2010, 04:48 PM   #2
justinpba
FNG
Default Re: What do you think about a 455 olds?
One of the torquiest motors to come out of Detroit! I love 'em. If you're not planning on running after market heads, look for one pre '70 or find a set of heads off a 425. They had a 'C' casting. Best flow. Good luck!
Old 11-14-2010, 06:06 PM   #3
hoboy56
Senior Member
hoboy56's Avatar
Oh, yes yes. I have one in my 55 Caddy. Came out of my pops 75 Olds 98 Regency, his second to last car he owned. Awesome , torquey motor.
__________________
There's an Asshole in every crowd.... that I'm in
Old 11-14-2010, 06:28 PM   #4
hotrodladycrusr
Old School HAMBer
hotrodladycrusr's Avatar
LOVE my 1970 Olds 455 in Big Olds. I've got 114,000 miles on it. It came out of a streetrod with who knows how many miles from that AND who knows how many miles in the original Oldsmobile that it came from.
__________________
Will trade cookies for old good for nothing flathead heads or hubcaps.
Old 11-14-2010, 07:05 PM   #5
mohr hp
Grenade Inspector
mohr hp's Avatar
If you want a very pretty engine with iron Olds heads, the top of the exhaust ports will always look bad because of the heat. Not a problem on a beater. rugged torquey motor. not much oil pressure, but doesn't seem to care.
Old 11-14-2010, 07:18 PM   #6
joe_padavano
Grenade Inspector
As far as Olds heads are concerned, all the big block head castings except the "J" code smogger heads flow within about 10% of each other. If you plan to do any porting at all, the J heads flow as good as any and are dirt cheap. All BBO heads have chambers that run about 80 cc. Olds varied compression ratio with the size of the dish in the pistons. 442s and Toronados came with 2.070"/1.625" valves. Others usually got smaller valves. The heads can be machined to accept the larger valves. Also, 1971-76 heads (codes G, Ga, H, J, K, and Ka) all have induction hardened valve seats. Earlier heads do not.
Old 11-14-2010, 07:19 PM   #7
Choppa Hanee
Choppa Hanee's Avatar
Just go get it j
__________________
the BOMB SQUAD c/c
choppahaneecustoms
Old 11-14-2010, 07:21 PM   #8
HotRodMetal
Grenade Inspector
HotRodMetal's Avatar
Great Motor. My Dad had one in the Olds 98 we had. Gobs of torque.
__________________
bend-press.com
Old 11-14-2010, 07:30 PM   #9
Deuces
Old School HAMBer
May as well build a home made RAM AIR setup for it.... It should be good for another 10 ponies or so...
__________________
***** God Bless the U.S. *****
Old 11-14-2010, 07:45 PM   #10
1957Custom
Grenade Inspector
I learned some really good secrets about Olds heads. Big old Oldsmobile's rule!
Old 11-14-2010, 10:06 PM   #11
mickeyc
Alliance Member
mickeyc's Avatar
Hello jsteph, MickeyC from the Louisiana bayou country. Picture this in your minds eye. A30ft. long 13 foot wide cypress wood constructed shrimp skiff. Cypress wood stays wet and heavy by nature. also 400 hundred lbs of ice, A thousand lbs or so of various tools, nets trawl boards. Plus a 100 gallons of gas, and a pair of 200+ lb. steely eyed
shrimp slayers. All powered by a cast iron 455 Olds with very heavy cast
iron water cooled exhaust manifolds and a borg warner cast iron gear
(transmission) This skiff was cranked at 4:00 a.m. and run in the four barrel for anywhere from10 to 20 or miles. Then would pull a 50 foot trawl
for 2 hour tows as many as 4 or 5 times a day or night. After a full day of work, we would then run back to the dock with ( hopefully) several hundred pounds of shrimp. This went on for weeks at a time. The big Olds
kept on keeping on. Ultra reliable motor with gobs of torque.
Old 11-14-2010, 10:16 PM   #12
Vintageride
Grenade Inspector
Vintageride's Avatar
I agree.
I miss my W-33 powered delta. I had lots of puzzled looks from folks at stoplights.
You will have no regrets with the Olds 455.
Vintageride
Old 11-14-2010, 10:59 PM   #13
Stevie Nash
Alliance Member
Stevie Nash's Avatar
Olds = Torque
__________________
Outsiders C.C.
Wanted: 1937 Nash Coupe
Old 11-15-2010, 12:54 AM   #14
56oldsDarrin
56oldsDarrin's Avatar
Usually the 70's motors have "smogcamitis".
The modern high-lift , shortish duration cams do wonders.
I am running the Performer RPM cam, and Its docile enough to drive everyday.
Other than that, my motor is a 75, J head, smogger.
However, in an older Higher compression engine, the W30 cam sounds real good.
also,
I ran the car with a points distributor for a long time (it ran fine).
But, then I chose to go GM HEI,... yea it runs better/gets better milage.
The damn thing smoothed out what little "lumpty lump" the RPM cam had.
__________________
Darrin
Old 11-15-2010, 01:23 AM   #15
dieselc
Senior Member
dieselc's Avatar
Olds are good engines. Strong and reliable, go for it.
__________________
Lifes short and hard like a body buliding elf!
Old 11-15-2010, 06:17 AM   #16
lothiandon1940
Old School HAMBer
lothiandon1940's Avatar
My pal, Willy has one in a Cutlass Convertible. Hauls ass. Torque Monster!
__________________
"......and the hops flowed like water"....J.T.
Old 11-15-2010, 07:04 AM   #17
440shawn
Senior Member
440shawn's Avatar
Had a 68 Olds 455 ran great with tons of torque, go buy it.
Old 11-15-2010, 07:05 AM   #18
tjet
Alliance Member
tjet's Avatar
I have one in my '59 pickup. It really stands out from the crowd of SBC's. They also have a very nice exhaust note & sound healthy, even with a stock cam.
Very solid following on the web. http://www.realoldspower.com & http://www.442.com just to name a couple. Most of the issues with oiling & heads have been sorted out by Olds perf engine builders
As far as used speed parts, Olds has the advantage over Caddy, Buick, & Pontiac due to the heavy marine jetboat use in the '70's. While not as cheap as a SBC, you can build a very strong 455 for less $$ or equal to a BBC. Another plus: An aluminum head 455 weighs the same as an iron head SBC, & the spark plugs are way easier to get to.
I suggest you get this book too
http://cgi.ebay.com/ebaymotors/Oldsm...sQ5fLiterature
Old 11-15-2010, 07:19 AM   #19
BOWTIE BROWN
Alliance Member
BOWTIE BROWN's Avatar
there is one in town with alum. Heads & been worked , jeeez does that then move.
good motor .
__________________
BOWTIE BROWN
YESTERDAY IS A MEMORY ...TOMORROW IS A VISION .....TODAY IS A BITCH
WOUNDED WARRIOR PROJECT.
Old 11-15-2010, 07:28 AM   #20
jasonp
Alliance Member
jasonp's Avatar
I agree with everyone else, lol
__________________
You only live once!!!
R.I.P. Dad 1-13-55 - 12-17-11
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
