Reply
Thread Tools Display Modes
Old 11-13-2010, 07:28 PM   #1
FunnyCar65
Senior Member
FunnyCar65's Avatar
Default Straight Axle/Cross Steering Set Up Do and Dont's
I'd like to start a end all tell all thread on straight axles set up with cross steering.Whats the best way, best parts to use.Input by those that have done it with success please.
__________________
You wouldn't be so damn pissed if I wasn't right!
offline   Reply With Quote
Old 11-13-2010, 07:39 PM   #2
hillbilly4008
Old School HAMBer
hillbilly4008's Avatar
Default Re: Straight Axle/Cross Steering Set Up Do's&Dont's
man i read this title to fast, i thought it read "Straight Axle/ Cross Steering Set Up To Do Doughnuts"
Old 11-14-2010, 06:17 AM   #3
FunnyCar65
Senior Member
FunnyCar65's Avatar
Default Re: Straight Axle/Cross Steering Set Up Do and Dont's
Any tech tips and or photos of the proper way to set up the drag link to prevent bump steer?
__________________
Old 11-14-2010, 07:28 AM   #4
redlineracer42
Senior Member
redlineracer42's Avatar
Hi,I know you want the pitman arm level so ya don't create bumpsteer.Also,I set up the axle so the kingpin inclination was 7 degrees back at the top.
Old 11-14-2010, 08:26 AM   #5
lawman
Old School HAMBer
lawman's Avatar
her are a few pics of a cross steer and Vega box on a 51 chevy truck frame and 38 Chevy cab. Hope these help.Tom (Tired Old Man)
Click image for larger version
Name:	Picture 335 (Medium).jpg
ID:	1148698   Click image for larger version
Name:	Picture 338 (Medium).jpg
ID:	1148699   Click image for larger version
Name:	Picture 337 (Medium).jpg
Name:	Picture 341 (Medium).jpg
Old 11-14-2010, 08:27 AM   #6
RAY With
Old School HAMBer
RAY With's Avatar
Quote:
Totally agree -Bump steer on a straight axle is lethal to your health
__________________
http://www.hotrodchat.com/gallery/ 29,660 +pictures and 160 albums and growing-Many HAMB FRIENDLY and some not. Many subjects and many old drag pictures from the 50-60's
Old 11-14-2010, 08:31 AM   #7
Rpmrex
Rpmrex's Avatar
You'll want a pan hard bar on cross steer.
Old 11-14-2010, 08:54 AM   #8
porknbeaner
Alliance Member
porknbeaner's Avatar
Quote:
Actually a panhard bare is a good idea on any setup. But I see it as a necessity on a cross steer.
__________________
If it don't make ya dirty it ain't yours
No man crosses a chasm in two jumps
Old 11-14-2010, 09:27 AM   #9
redlineracer42
Senior Member
So true on the panhard bar!!! I forgot to mention that!
Old 11-14-2010, 01:41 PM   #10
FunnyCar65
Senior Member
FunnyCar65's Avatar
This is the kinda info I'm after.I see alot of parallel leaf spring set ups with out a panhard?
__________________
Old 11-14-2010, 02:41 PM   #11
GARY T.
Alliance Member
GARY T.'s Avatar
Anybody got a pic of one with a panhard bar ---wheres the best places to attache it so it ain't ugly?
__________________
Old 11-14-2010, 11:12 PM   #12
Martys 55
FNG
Martys 55's Avatar
heres a pic of mine not the best pic i will take a couple for you this week marty
Old 11-15-2010, 12:30 AM   #13
KrisKustomPaint
Senior Member
KrisKustomPaint's Avatar
The dead spring perch looks like a tidy alternative to a panhard bar.
online   Reply With Quote
Old 11-15-2010, 06:57 AM   #14
Model A John
Alliance Member
Model A John's Avatar
If you have parallel leaf springs, you don't need a panhard bar. My Chevy II is set up that way with a Speedway kit.
Old 11-15-2010, 08:25 AM   #15
C/Gas55
Grenade Inspector
C/Gas55's Avatar
Parallel leafs should not run perfectly "parallel" to each other. If they do, you will need a panhard bar.
Old 11-15-2010, 08:57 AM   #16
porknbeaner
Alliance Member
Quote:
A pan hard bar is kind of like a backyard sway bar. No before some ass hat tires to say I said it was a sway bar I did not say it was or is a sway bar. So we can overcome that little bit of drama before it starts.
I helps keep everything in line. Leaf springs have some lateral strength by nature but they are designed to go up and down. The pan hard bar keeps it from swaying from side to side. On any steering setup your steering box for all intents and purposes is stationary if the suspension moves to the side and the steering box doesn't move with it something has to give. Normally your wheels turn to make up for the difference. It is more acute on a car with cross steer; where the steering box is solid in the chassis and the link reaches across to cause the wheels to turn when it is moved.
So if you use something to keep your suspension from moving from side to side you limit that motion. A properly set up pan hard bar will accomplish that. Build it so that at rest it is level or nearly level. A good idea also is to make the panhard bar as long as possible. That way it swings a longer smother arc and the motion of the suspension doesn't affect it as much.
Actually a watts link works even better but it does take some engineering. Might look for someone who has built one or knows the geometry of one to help you out or draw you a picture if you decide to go that route.
__________________
Old 11-15-2010, 10:57 AM   #17
High Class Rat
Grenade Inspector
High Class Rat's Avatar
Porknbeaner,
Which side of the frame should a pan hard bar be mounted to? I seem to recall reading somewhere that it should be attached to the DRIVERS SIDE of the frame.
Old 11-15-2010, 11:47 AM   #18
KrisKustomPaint
Senior Member
Quote:
Originally Posted by High Class Rat View Post
Porknbeaner,
It makes no difference, unless something is in the way.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
