Reply
Thread Tools Display Modes
Old 10-29-2010, 07:14 PM   #1
LKPar1270
FNG
Default Flathead block crack
I've got a '51 RT Flathead with the familiar crack between the water jacket opening and head bolt hole. I wasn't really worried about it until today when looking closer I discover the crack goes past the head bolt hole toward the valves about 3/4 inch. What's the chance of drilling the end of the crack and stopping it?
offline   Reply With Quote
Old 10-29-2010, 08:40 PM   #2
59ab
Grenade Inspector
Default Re: Flathead block crack
Certainly worth trying. Good luck!
Old 10-29-2010, 08:53 PM   #3
LKPar1270
FNG
I'm thinking just a small hole, 1/8 or so would be better than a threaded hole with a bolt in it. My thinking is a smooth hole would be stronger and less likely to let the crack restart than one with the sharp ridges and valleys of a threaded hole. Would the head gasket block any coolant seepage with this kind of fix?
Old 10-29-2010, 09:04 PM   #4
lowsquire
Old School HAMBer
lowsquire's Avatar
yeh it may seal a small hole..maybe not though.depends where it is. . make very sure you drill it past the end of the crack..thats the important bit.
__________________
www.ranchodeluxe.com.au
Old 10-29-2010, 09:06 PM   #5
Screamin' Metal
Screamin' Metal's Avatar
yup, drill 1/8 hole at the end and v that puppy out and lay in some brass. or, get a sealace kit and sew her up....then rough her down close,flap wheel to within.030, blue her up, file down close then hone to perfection.
Old 10-29-2010, 09:20 PM   #6
Captain Chaos
Captain Chaos's Avatar
I saw a guy that does crack repairs, wont say how but from studying his finished work it looks like small hole with brass dowel driven or screwed in then each one overlapped til the crack is filled .
__________________
Run what ya brung and don't bring the excuses
Old 10-29-2010, 09:26 PM   #7
obsolete zach
Grenade Inspector
obsolete zach's Avatar
pretty detailed "how to" in tex smith's "the complete ford flathead v8" book. done with irontite plugs.
__________________
The Delinquents CC
I like customs.
Old 11-02-2010, 03:55 AM   #8
LKPar1270
FNG
More problems....more cracks. I have a crack near the valve seat on one intake valve. Is this a place that works well with stitching?
Last edited by LKPar1270; 11-05-2010 at 09:53 AM. Reason: removed link to picture that didn't work
Old 11-14-2010, 11:33 AM   #9
ablebob
Newbie
ablebob's Avatar
If you are interested I just listed a Irotntite pressure tester & pinning kit in the misc classified section. I'm downsizing my shop. I used to pin a lot of cracks, even thru seats. I'd say the success rate is 90%. There is also a liquid called fluidweld that seals up small cracks in aluminum & cast iron. Never had a crack start from threads in a pinning hole. My guess is the irregular surface of the threads spreads out the stress in many directions.
Old 11-14-2010, 12:39 PM   #10
Ancient Rodder
FNG
Quote:
Yep, thats the way we used to do it. Drill, tap, brass screw, keep overlapping till you get past or to the end of the crack. The 8RT has head bolts, change all of them to studs, clean stud holes with a thread chaser, coat the block ends of the studs with ceramic sealer prior to reinstalling them ( I'd have the block acid dipped prior to doing any thing ) when you get through and ready to refire it up put a product called "Liquid Glass" in the coolant, it will seal any thing you may have missed. After having said all that, there are still good blocks out there of the 8BA/RT configuration.
JMO
Old 11-14-2010, 01:06 PM   #11
JonF
Grenade Inspector
JonF's Avatar
You said "coat the block ends of the studs with ceramic sealer prior to reinstalling them ", do you recommend a brand name sealer and where can I buy it??
Old 11-14-2010, 07:44 PM   #12
Ancient Rodder
FNG
Quote:
I'm using "Moroso Ceramic Engine Seal". I dip the stud threads in the bottle and screw into the block. I've not used it as a block sealer as they describe in the directions, I have been useing "Water Glass" since the "60s" with good results. Picked this tip up from a diesel enginen shop.
Old 11-14-2010, 07:47 PM   #13
Ancient Rodder
FNG
I originally said "liquid Glass", the correct name is "Water Glass". sorry bout that.
Old 11-14-2010, 07:52 PM   #14
ironpile
ironpile's Avatar
I`ve heard and seen a lot of good things about the stitching system.Might be the same as sealace system.Any concentrated heat could cause problems with an old and seasoned block.I would like to try it myself but the kit is too expensive for experimentation. Good luck what ever way you go,and keep the forum up to date on results.
__________________
Retirement: Nothing to do and plenty of time to do it.
Old 11-14-2010, 11:03 PM   #15
aaggie
Alliance Member
I have an old book written for Model T Fords and it has a chapter on repairing cracks in the block. It describes drilling a series of holes plugging each with a brass rod and grinding off the excess. The book was published in the late teens and has all sorts of tips and instructions.
There is a chart that shows how much gas is in the tank by dipping a stick in and measuring the wet line. Another shows how to sew up a split sidewall in the tires. The best is instructions on filling the Acetylene generator on the running board and lighting the headlamps with a match.
Old 11-16-2010, 01:01 AM   #16
LKPar1270
FNG
Since this block has been bored enough to need sleeves (didn't now they didn't come that way) I've decided it's not worth the time or cost of stitching. I found another RT block today (a '50) and will junk the cracked block. The pistons are stuck in the 'new' block. Visual inspection doesn't show any cracking, even at the usualy places between the head bolts and water jacket holes, so I think it's solid. I should be able to use the crank and rods and maybe the cam out of the engine I'm going to junk.
Thanks for all the help and good information.
Next step: press those pistons out and get this thing hot tanked, more closely inspected, bored and lightly decked, and start building.
Old 11-16-2010, 01:13 AM   #17
LKPar1270
FNG
Another question already. I find there are lots of new old stock piston sets available for the flathead V8. Will any set for the 239s fit this block, or are there differenced between the block styles? What do I need to look for?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
