Reply
Thread Tools Display Modes
Old 10-26-2010, 06:57 PM   #1
Leebo!
Alliance Member
Leebo!'s Avatar
Default Can a distributor "go bad"
THis might be a dumb question, but can a distributor go bad? I have been having a trouble for some time, and am ready to throw my truck and myself into a wood chipper. I can get it running, and get it running smooth by vacumm gauge. WHen it gets warm, it starts popping and misfiring. If i try to restart it, it wont, and cant turn it to any position to restart it. I thought my coil might be bad, but changed coils and it didnt help.
Its a Mallory Unilite if that makes a difference.
Im a shade tree mechanic at best, but have never had this much trouble!
Thanks!
offline   Reply With Quote
Old 10-26-2010, 07:03 PM   #2
fitzee
Old School HAMBer
fitzee's Avatar
Default Re: Can a distributor "go bad"
I have had them half wore out and still work. I have to ask what model are you talking,Ford,dodge, chevy?
Old 10-26-2010, 07:05 PM   #3
old lady's mad
Grenade Inspector
old lady's mad's Avatar
they go bad all the time, unilite is a points dizzy right. most likely the bushings are worn in the top and expnding when hot , in turn not opening the points enough to fire the coil . try this close the points up to about 10 instead of 18. if that cures it , guess what . its worn out.
Old 10-26-2010, 07:06 PM   #4
Leebo!
Alliance Member
Leebo!'s Avatar
Wow, forgot important details.
350 SBC. cams not stock, but not super lopey.
How does the advance (vac) work? Would that make any diff when warm?
Old 10-26-2010, 07:07 PM   #5
Leebo!
Alliance Member
Leebo!'s Avatar
Old ladys mad-
Can you elaborate what you mean by "closing" points 10 instead of 18?
Old 10-26-2010, 07:07 PM   #6
themoose
Old School HAMBer
themoose's Avatar
Unilite should be electronic.Could be a bad module
__________________
Custom Tees With your ride
Too soon we get old too late we get smart.
One out of two ainít bad
Old 10-26-2010, 07:09 PM   #7
29AV8
Grenade Inspector
yes. most people do not even realize it. I have changed several for customers here of late.
__________________
"Bury the dead they smell up the place"
Old 10-26-2010, 07:10 PM   #8
Ebbsspeed
Alliance Member
Ebbsspeed's Avatar
Agree, sounds like the module gets flaky when it warms up.
online   Reply With Quote
Old 10-26-2010, 07:11 PM   #9
53sled
Old School HAMBer
53sled's Avatar
throw in a junkyard hei, only takes a minute to know for sure. I have 2 or three around.
__________________
If only the good die young. I'll be here when you're gone.
Old 10-26-2010, 07:12 PM   #10
Leebo!
Alliance Member
Leebo!'s Avatar
IS the module replaceable on a Unilite? I have changed them in stock HEI's
Old 10-26-2010, 07:13 PM   #11
themoose
Old School HAMBer
themoose's Avatar
Quote:
Yes
__________________
Old 10-26-2010, 07:14 PM   #12
chevyshack
chevyshack's Avatar
Can a distributer go bad? Hell yea! theres not one part that cant go bad on any engine. Your block can even go bad when it cracks or has a rod come out the side. Ive replaced a distributer on my dads truck and it was only 5 years old. Dont make them like they used to.
Old 10-26-2010, 07:20 PM   #13
Slick Steve
Grenade Inspector
Slick Steve's Avatar
sounds like a job for GMCBUBBA! http://www.jalopyjournal.com/forum/member.php?u=15923
Contact him, he can help.
__________________
"Street rods have a Chevy in front and a can of wax in the back.......Hot Rods have a Flathead in front and a box of tools in the back"-- Fred Offenhauser
Old 10-26-2010, 07:27 PM   #14
wingnutz
Old School HAMBer
wingnutz's Avatar
Thanks!
The most trouble I've had was with the "Mallory" uniltes... everything from bad bushings to bad sending/receiving units. The bearings would get so bad the shaft would death wobble and take out the senders as well as the cap and rotor.
I never had any issues with their dual points except for one time a wire came off the spade post by the points!
For race applications I pony up for MSD or if you can afford it... the Mallory
Mags are a hefty unit!
__________________
"ANNUIT COEPTIS NOVOS ORDO SECLORUM... AD MAJORUM DIA GLORIUM"
Old 10-26-2010, 07:31 PM   #15
Leebo!
Alliance Member
Leebo!'s Avatar
YEah, Im leaning towards a new module, based on some of the stuff I have just pulled up on the net. I have been saying for a bit now that I felt the dist was the culprit. Hell, I have rebuilt or replaced everything but the air in the tires trying to trouble shoot this. Im out of things to change if this doesnt fix!
Old 10-26-2010, 07:37 PM   #16
mt94ss
Grenade Inspector
mt94ss's Avatar
Another thought, is the engine an older rebuild? Could be a timing chain issue. Have you put a timing light on it to see if it is 'dancing' around? Also, I had a BB chev that the cam went flat and it did that too. Just have to do a process of elimination.
I'd do a dist. swap first and go from there.
Good luck!
Later,
Mike
__________________
Liberty, In GOD We Trust, E PLURIBUS UNIM
My engine:
http://www.youtube.com/watch?v=HDMbG7mMwW4
Old 10-26-2010, 07:38 PM   #17
dynaflash
get rid of the Unilite Module and replace it with a Pertronix unit. And yes they make a Pertronix to fit the Malory dist. The Unilite modules are not very good and one just cost me a 155 mile wrecker bill.
__________________
Signature area was left blank by Dynaflash
Old 10-26-2010, 07:42 PM   #18
old lady's mad
Grenade Inspector
well evedently its an electronic unit not points. one other thing to look at as a posibility . if you have a tach . unhook it . they can go bad and ground out the neg. side . there are ways to test and see whats bad. with out waisting money just throwing parts at it . unless you have spare parts laying around or can borrow some from freinds.
Old 10-26-2010, 07:42 PM   #19
themoose
Old School HAMBer
themoose's Avatar
Unilites are very susceptible to voltage spikes. Mallory sells a filter to protect the module.Make sure all of your grounds are good. A bad ground will cook the module.
__________________
Old 10-27-2010, 07:52 AM   #20
GMC BUBBA
Old School HAMBer
GMC BUBBA's Avatar
The uni-lites usually fail when hot and work when cold. Change it to a pertronixs replacement unit.
OR we can supply you with a built "bubbas" unit if needed......
__________________
Bubba's Hot Rod Shop - Linder Technical Services
[SIGPIC][/SIGPIC]
Vintage ignition systems are our specialty. If it makes spark, we can do it.
888-809-3835 TOLL FREE
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
