Reply
Thread Tools Display Modes
Old 09-11-2010, 01:51 AM   #1
Heart Of Texas
Newbie
Heart Of Texas's Avatar
Default Part numbers - Over the counter 12 Volt Overdrive Solenoids
I am hoping this post will provide me with a viable part number I can use to order a 12 volt overdrive solenoid. I am specifically seeking a part number that can be used at a auto parts store like NAPA etc. The type of solenoid I seek has a 1 inch shaft length when measured from the mounting plate. Its intended use will be in a R-11 Overdrive unit.
Researching HAMB and other INTERNET sources there are plenty of references to using the existing stock of 12 volt OD solenoids to replace the OEM 6 volt units when converting to 12 volts. This information is usually accompanied with recommendations to purchase a replacement from antique parts vendors, usually at a cost near $300 dollars plus rebuildable core. Occasionally the provided information alludes to "over the counter" NAPA, AutoZone etal... units. It is this elusive over the counter replacement part's part number and source I seek.
This month Hemming Motor News is running a story penned by the 5th Avenue folks which lists the part numbers for a number of OEM 12 volt solenoids
Thanking all of you in advance.
__________________
Ken Cates
Waco, Texas
offline   Reply With Quote
Old 09-11-2010, 03:11 AM   #2
slider's house of kustoms
Grenade Inspector
slider's house of kustoms's Avatar
Default Re: Part numbers - Over the counter 12 Volt Overdrive Solenoids
ken if you can get me the oem numbers I can attempt to cross them over to a aftermarket number.
Slider
Old 09-11-2010, 03:15 AM   #3
Grenade Inspector
own Switch
Back to Results
3 Images
<< Prev Next >>
Full
Part: ECH OD6284
Product Line: Echlin Ignition
List Price
Your Cost
Unit
54.08
34.62
Each
Qty Available: 0.00
Qty
Warranty
Limited 12 Months
Material Safety Data Sheet (MSDS)
There is no MSDS for this item
Buyers Guide
MakeModelEngineYear(s)
FordCrestline
1952 - 1954
FordCustom
1957 - 1957
FordCustom
1949 - 1949
FordCustom 300
1957 - 1959
FordCustomline3.9 L 239 CID V8 L Head1952 - 1953
FordCustomline
1954 - 1956
FordFairlane
1955 - 1961
FordFairlane 500
1957 - 1961
FordFalcon
1960 - 1961
FordMainline
1952 - 1956
FordThunderbird5.8 L 352 CID V81958 - 1958
FordThunderbird
1955 - 1957
FordThunderbird
1959 - 1961
LincolnCosmopolitan
1949 - 1951
MercuryColony Park
1957 - 1958
MercuryCustom
1952 - 1956
MercuryMedalist
1956 - 1956
MercuryMedalist
1958 - 1958
MercuryMercury
1949 - 1951
MercuryMontclair
1955 - 1958
MercuryMonterey
1950 - 1958
MercuryParklane
Old 09-11-2010, 09:31 AM   #4
NONAME
Old School HAMBer
NONAME's Avatar
last months hemmings has an article on these and 6 to 12 conversion plus part numbers. I'll look them up later unless it gets posted
whoops just read the last line of your post
__________________
BLUE SKIES AND SUNSHINE, NEVER HAD A BAD DAY IN MY LIFE
www.oldcarglassguy.com
Old 09-11-2010, 12:38 PM   #5
Heart Of Texas
Newbie
Slider - thanks for the offer! The part numbers I know about come from the Hemming Motor News article:
AR-10H-62 : 55-57 Packard, 56-59 Plymouth, 56-63 Stude, Hudson, Nash Rambler and 55-56 Chevy
1AR-10H-62 :57-63 Chevy
AR-10F-62: 59-63 Studebaker Truck
AR-11-62: (same as Ford B6A-6916A) 56-65 Ford< Mercury and Edsel
Again the distinguising factor for the solenoid I need is a 1 inch shaft length measured from the mounting surface. The type of solenoid I am replacing has a sides on the ball end... I can grind down the full ball type or replace the shaft with the one from a 6 volt solenoid.
Thanks again for the help.
__________________
Ken Cates
Waco, Texas
Old 01-14-2011, 11:44 PM   #6
greasemunkey
Grenade Inspector
greasemunkey's Avatar
I take it, we still have an elusive solution? Just curious...trying to avoid the ebay route...
__________________
'54 Customline
'41 Merc
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
