Reply
Thread Tools Display Modes
Old 09-10-2010, 06:03 PM   #1
patrick2965
Senior Member
patrick2965's Avatar
Default Model A Tudor side glass installation--HOW?
I should be installing the side glass in my 29 Tudor this weekend. I haven't found any tech info.
Question--This window run channel sits into the vertical support channel below the horizontal window line. Unlike the door, you cannot drop the glass in from the top of the car. What is the proper procedure for getting the glass into the run channels? Do you bend out the steel support that holds the felt, insert glass, bend back steel support? Pictures during procedure?
By advice, I bought the rigid U channel without the chrome edge from Sachse Rod Shop. The run channel fits the support channel in the doors and rear sides just fine and will be glued in with 3M weatherstripping cement, again by advice. The side glass will be operational too. I'm not taking the easy way out, gluing the stuff in to be stationary, Henry didn't.
If you have experience, please help. Any corrections about what I have been advised as correct procedure is requested too.
Thank you!
__________________
Custom and performance driveshafts built here. Axiline equipment, quality concious builders.
For most folks, common sense really IS rocket science.
offline   Reply With Quote
Old 09-11-2010, 09:26 AM   #2
patrick2965
Senior Member
Default Re: Model A Tudor side glass installation--HOW?
Morning bump.
__________________
Old 09-11-2010, 05:17 PM   #3
36-3window
Old School HAMBer
36-3window's Avatar
on my `28 tudor rear side glass i installed it first , then slid in the felt channels and then glued them in place.
__________________
when small men begin to cast long shadows it is a sure sign the sun is setting.
Old 09-11-2010, 05:26 PM   #4
daddio211
Alliance Member
daddio211's Avatar
I did the same thing 36-3window did with my '31 Tudor. I dropped the glass in first, then worked the felt window channels in, then secured the channels to the body. Wasn't simple, but I did it by myself in less than an hour for both sides.
__________________
Wife's '27 T Roadster build: http://www.jalopyjournal.com/forum/s...d.php?t=734383
Dad's '50 Ford Tudor: http://www.jalopyjournal.com/forum/s...d.php?t=861732
Old 09-11-2010, 05:56 PM   #5
COOP666
COOP666's Avatar
Quote:
I'm pretty sure i did the same thing, but it was a few years ago, and I've forgotten. i do remember that it was a bit more of a pain that the door glass.
Old 09-11-2010, 08:17 PM   #6
patrick2965
Senior Member
Y'all basically did the same. HOW? Did you insert the felt channel from underneath? Was the channel cut to the same length as for the door? Shorter?
Here's why I'm asking so much. My car was basically stripped of everything. I have no reference from disassembly. I have found no pictures. Most everybody around here has A/C and sealed stationary rear side glass. I don't have A/C in Arkansas!????!! Many guys bought, not built their own.
Thank y'all very much so far.
__________________
Old 09-11-2010, 08:40 PM   #7
motoandy
Senior Member
motoandy's Avatar
Hoping to get good feedback also. I am right behind you in about 3 weeks. Hope to have it painted in 2 and glass installed in 3.
any back to the garage for now..............
__________________
Life ain't easy when your fat and greasy
ASSORTED NUTS,CC
Old 09-15-2010, 08:44 PM   #8
patrick2965
Senior Member
Here's how I have figured it out based on these guys and and playing inside the car afterwards.
To install the sideglass, you first insert the glass without the window run channel and hold it high in the window opening. You then insert the glass run channels from underneath. Apply weatherstripping cement or favorite glue stuff to hold the channel in place---with the window high, pull out, glue low, THEN window low, pull channel, glue high. OR vise-versa if you choose.
Why was something as simple as this be so cotton pickin' hard to figure out for me?????
__________________
Old 09-15-2010, 08:48 PM   #9
COOP666
COOP666's Avatar
That sounds right - I wish i had been taking photos when I did mine. I just remember spending a couple of hours futzing around with it and getting pissed until I figured out the correct sequence of steps.
Old 09-15-2010, 08:56 PM   #10
patrick2965
Senior Member
Man, it's like one of those wooden puzzles that somebody else took apart.
Hmmm, slide it this way to insert piece L through ...........................
Hey Coop, did you do anything about the body and outside of the door glass and side glass to keep weather from coming between??????????
__________________
Old 09-15-2010, 09:13 PM   #11
rtc1930
FNG
rtc1930's Avatar
Check out this link on installing glass into a Vicky Model A.
http://jmodela.com/window.html
On page 19 It basically says (I read it quick) you install the glass before the felt and then slide the felt in place clipping the bottom first and then top. I'd recommend reading the article to make sure I didn't miss-interpret that. I also recall reading on another site the front felt channel should be wider then the rear so you can pop the glass in that way but it doesn't seem to make sense.
I'm about to install the glass in my Town sedan but not for another 2 weeks.
Bob NJ
__________________
"Fix what's broke"
Old 09-15-2010, 09:15 PM   #12
yngrodder
Alliance Member
yngrodder's Avatar
I Bought Factory Window kit from Snyders, I first unscrewed the interior (Metal Panel) Inserted and glued one of the fuzzys in then I inserted the glass in it and then started the second fuzzy, I then moved the window up and down sliding the second fuzzy up with the window a little at a time, until it was all the way up. Then put the window regulater and Metal Panel back in. (Factory Model A fuzzys have a clip that holds them in place but you Glue them in as well)
Old 09-15-2010, 09:19 PM   #13
patrick2965
Senior Member
Bob NJ
Bob, it doens't make sense because of how the glass is cut. The way I figured this out was to finally get a donor rear side glass for my Tudor. The way my body panels fit, the glass is approx 3/8" shorter than the distance between the body opening verticals. So that is why you have to put it together like a wooden slide together puzzle.
I'm enjoying the new challenges.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
