Reply
Thread Tools Display Modes
Old 08-22-2010, 08:10 PM   #1
VinnieCap
Grenade Inspector
VinnieCap's Avatar
Default 32 Ford - wood kit and top install - PICS Added 8/29/2010
Hey All,
Any pics, advice, instructions? I ordered a new wood kit for the top of my 32 4-door. I also have a new LB top kit I got last week.
Not sure if the wood comes with instructions or not. It's supposed to come this week.
The LB top kit has instructions but I am always open to advice.
Any tips are appreciated!
Thanks,
Vinnie
offline   Reply With Quote
Old 08-22-2010, 08:47 PM   #2
El Bombero
Alliance Member
El Bombero's Avatar
Default Re: 32 Ford - wood kit and top install
You can check out the build thread on my 32 sedan and see how I did it. I used the same kit you are using. If you have any questions while you are installing it PM me. I can tell you what I did. Not sure it was the "right " way but it worked.
Good Luck
Mike
Old 08-23-2010, 06:10 PM   #3
VinnieCap
Grenade Inspector
VinnieCap's Avatar
Awesome... I'll check it out. I order the wood kit from Classic Wood Mfg. in Greensboro, NC.
Old 08-25-2010, 07:57 AM   #4
VinnieCap
Grenade Inspector
VinnieCap's Avatar
Got all the old wood out last night.
Old 08-25-2010, 08:26 AM   #5
brady1929
Old School HAMBer
brady1929's Avatar
pictures. you know the old "this thread is worthless without pictures"
Old 08-25-2010, 05:39 PM   #6
VinnieCap
Grenade Inspector
VinnieCap's Avatar
Pics as requested... (hope this works).
Click image for larger version
ID:	1069295   Click image for larger version
ID:	1069296   Click image for larger version
Old 08-29-2010, 04:02 PM   #7
VinnieCap
Grenade Inspector
VinnieCap's Avatar
Default Re: 32 Ford - wood kit and top install - PICS Added.
Here are a few more pics. The wood actually went in fairly easy. We built the outer frame outside the car then just inserted it through the top. There is enough play to move it around and get it in. Here are some new pics:
ID:	1073222   Click image for larger version
ID:	1073223   Click image for larger version
Old 09-15-2010, 08:48 PM   #8
Charlie Stephens
Senior Member
Default Re: 32 Ford - wood kit and top install - PICS Added 8/29/2010
Vinnie,
If you keep the chicken wire from grounding out on the body I have been told you can use it as a radio antenna. Anybody out there with first hand experience with this?
Charlie Stephens
Old 09-15-2010, 08:50 PM   #9
Charlie Stephens
Senior Member
Quote:
Good Luck
Mike
Mike/Vinnie,
Please post instead of using PM's as I am interested also.
Charlie Stephens
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
