Reply
Thread Tools Display Modes
Old 08-05-2010, 04:53 PM   #1
roundvalley
Senior Member
roundvalley's Avatar
Default 3789733 Chevy flywheel
I have a 168 tooth, 14" Chevy flywheel #3789733. A 10.5" pressure plate will not bolt to it. I am guessing it is for a big block. ??
What flywheel do I need for a Ram 401 pressure plate 10.5", 168 tooth, SBC 350??
Did they make a 14" flywheel 168 tooth with a two different pressure plate bolt patterns??
Can't find the answer searching.
offline   Reply With Quote
Old 08-05-2010, 09:50 PM   #2
roundvalley
Senior Member
Default Re: 3789733 Chevy flywheel
How about a 3991469 or a 3986390?? Anyone know the difference?
Someone must have solved this with a SBC to earlyFord tranny. Offy adapter.
Old 08-05-2010, 11:20 PM   #3
Deuce Roadster
Deuce Roadster's Avatar
I used a 1950 Mercury pressure plate. That is what Wilcap says to use also
The bolt pattern on the 50 Mercury pressure plate is 6 evenly spaced holes and bolted to my 1957 Chevrolet 168 tooth flywheel.
Used a stock Ford clutch disc.
__________________
"Whether you think that you can, or that you can't,
you are usually right." Henry Ford
Old 08-06-2010, 07:32 AM   #4
Model A Vette
"378" numbers were used up to about 1964 so I doubt that it is for a big block unless it was for a "W" engine.
I think all the Chevy 168 tooth flywheels used 11" clutches.
The only GM dual pattern flywheels I've seen are for the later '86 & up cranks.
There may be aftermarket flywheels with dual patterns.
__________________
Ed
Old 08-06-2010, 06:02 PM   #5
Chevy55
Chevy55's Avatar
Aftermarket flywheels for Chevys come dual drilled for both clutches. Watch ebay for one or get ready to spend $200 plus for one. I do have a gm 168 tooth that is drilled for the 10.5 clutch 3728004 but I have no idea what it is off of.
Old 08-06-2010, 07:38 PM   #6
chucky stampfle
FNG
My 57 chevy has a 168 tooth fly wheel for a 10.5 inch clutch
try 55-7 chevys
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
