Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 12-02-2010, 09:41 PM   #121
Bored&Stroked
Alliance Member
Bored&Stroked's Avatar
Default FlatCad - Block Details
Thought I'd post some pictures of the block, crank, etc -- to give you an idea as to what this engine is all about. Until I got my hands on this beast, can't say that I ever had one apart before . . .
1) Block: It was the first monoblock casting from Cadillac - is strange in some areas. It does not have a valley area with the typical cast lifter bores. Instead, it is open and there are four separate 'lifter blocks' that block into the valley area.
Click image for larger version
The pan rails extend past the normal main-cap parting line -- like a 426 hemi or Donovan 417. The entire main cap sits below the pan rail.
All intake and exhaust passages exit at the top of the block - makes the ports a LOT better than a flathead Ford (we get 'quick way' exhausts in the FlatCad for free).
It came with large valves from the factory -- about 1.85 intakes and 1.65 exhausts (don't have the details in front of me). We're going to hog this sucker out and run somewhere around 2.05 titanium intakes and 1.75 titanium exhausts. Here is a shot with some sample stainless valves of this size:
Here is a shot of one of the lifter blocks - on the bench and in the engine:
2: Crankshaft - a huge 90 pound monster . . . with two large 'bolt on' counter-weights. The stock stroke is 4.5" and the journals are huge. This will be replaced with a custom Crower billet crankshaft -- with BBC journals, BBC snout and Ford FE flywheel flange.
3) Rods - Due to the size of the crankshaft and the 3.5" bore, the rods have a side mounted cap (like many diesels) - the length is 8.75" - with pressurized pin oiling. We don't have much choice but to make our custom rods the same length, but we should be able to fit a BBC style big-end through the bore.
That is all for this evening . . . need to complete the stud girdle while I wait for some parts I need to complete the crank and cam designs . . .
Enjoy!
__________________
As my old buddy used to say . . . "Gas, Grass or Ass" - nobody rides for free ! Seemed he was always alone . . .
offline   Reply With Quote
Old 12-04-2010, 10:11 PM   #122
hotroddub
hotroddub's Avatar
Default Re: FLATCAD RACING Bonneville 2011 Build
This is going to be good! I cant wait to get my stock flattie fired up now. What engine are the titanium valves made for, BBC?
Old 12-05-2010, 02:09 PM   #123
38FLATTIE
Old School HAMBer
38FLATTIE's Avatar
Quote:
They will be custom made. Right now, we are still working out the details.
Bored&Stroked, I know from all the phone calls, and DOZENS of emails, that there has been a ton going on with the engine.Progress has been good, and it's a very exciting part of the build. Helluva job you're doing!
I think, when we release all the engine mods, you guys watching will be amazed! This is a full on race motor, and when you see the details, there will be no doubt about it!
Car is apart, to get bead blasted, then epoxy primer. Need to set pinion angle, after we get the tranny adaptor, finish welding the rear up, get the frame blasted and painted, and run brake and fuel lines.
ID:	1168773   Click image for larger version
ID:	1168774   Click image for larger version
Old 12-05-2010, 05:08 PM   #124
Bored&Stroked
Alliance Member
Check out the Amazing Ginzu . . . . Iron Chef Approved . . . FlatCad Front Motor Plate - I think you'll like it
http://www.jalopyjournal.com/forum/s...22#post5941122
It was too good to not put on it's own post - here is a teaser picture:
B&S
__________________
Old 12-09-2010, 02:49 PM   #125
Flat Roy
Grenade Inspector
Flat Roy's Avatar
Here are som pic's of the Intake Manifold that will attach a GMC 6-71 blower to the Flat Cad. Are we ready to GO FAST?
Name:	Flat Cad 2 - 004 a.jpg
ID:	1172857   Click image for larger version
Name:	Flat Cad 2 - 006 a.jpg
ID:	1172858   Click image for larger version
Name:	Flat Cad 2 - 008 a.jpg
Name:	Flat Cad 2 - 009 a.jpg
ID:	1172860   Click image for larger version
Name:	Flat Cad 2 - 010 a.jpg
__________________
Just can't help myself! I gotta mess with stuff.
Old 12-09-2010, 03:12 PM   #126
choptvan
Alliance Member
choptvan's Avatar
Fast? I am ready to chop this thing already.
__________________
Hell Bounders CC Club President
Old 12-10-2010, 06:51 PM   #127
38FLATTIE
Old School HAMBer
38FLATTIE's Avatar
Roy, that looks GREAT! It's everything I thought it would be- super job!
Hmmm, we need a body/paint guy to join the team!
Ok, we're still moving along, but it's not all that exciting!
Body is completely disassembled, and blasted. It and all the parts are getting epoxy primed, and then we'll start the body goof-off and rust repair. We have more rust than we thought, but that's a surprise, right!
We are going to get the frame epoxy coated in a shiny black, then put the body back on it, after the body is primed, and take it to choptvan .We will then give it it's initial body chop. We'll just tack the top on, so that it can be removed, to weld the roll cage better.
The car will then go to Gary Hart, who is doing the roll cage. I feel extremely lucky to have someone with Gary's experience doing the cage, as I know it will be done right in regards to safety, and tech specs.
Hmmm, did I mention we need a body/paint guy to join the team!
ID:	1174047   Click image for larger version
ID:	1174048   Click image for larger version
ID:	1174050   Click image for larger version
ID:	1174051   Click image for larger version
ID:	1174053   Click image for larger version
ID:	1174067   Click image for larger version
ID:	1174069   Click image for larger version
ID:	1174070   Click image for larger version
ID:	1174072   Click image for larger version
Old 12-10-2010, 07:26 PM   #128
38FLATTIE
Old School HAMBer
38FLATTIE's Avatar
and a few more!
ID:	1174107   Click image for larger version
ID:	1174108   Click image for larger version
ID:	1174110   Click image for larger version
ID:	1174111   Click image for larger version
Old 12-10-2010, 07:29 PM   #129
pregrid
Grenade Inspector
pregrid's Avatar
won't that all buff out?
Old 12-11-2010, 11:28 PM   #130
choptvan
Alliance Member
choptvan's Avatar
Well shit. I thought so by the pix you sent. I told you what it would take. I could get some help here to get that taken care of....
__________________
Old 12-13-2010, 07:55 AM   #131
38FLATTIE
Old School HAMBer
38FLATTIE's Avatar
Quote:
Thanks Shannon, but I couldn't afford the quote!I think I have it taken care of, though.
...and the saga continues!
We're working on the bellypan, so that we can run /BVGCC. Obviously, we'll have to make some mods to it, but we have it 'roughed' in.
ID:	1176950   Click image for larger version
ID:	1176951   Click image for larger version
Old 12-13-2010, 08:06 AM   #132
26 roadster
Senior Member
26 roadster's Avatar
Get a rule book! Do your research on the web site. A lot to know and the most fun you will every have. SCTA does not play and the tech guys will not "look the other way", so do your home work
__________________
your old when everything reminds you of a story,,,I have a lot of stories
Old 12-15-2010, 07:21 AM   #133
38FLATTIE
Old School HAMBer
38FLATTIE's Avatar
Boring stuff, but necessary . We don't want the body to rust, now that it's blasted, so we coated it in epoxy sealer primer.
ID:	1178984   Click image for larger version
ID:	1178985   Click image for larger version
Old 12-15-2010, 07:53 AM   #134
Ebbsspeed
Alliance Member
Ebbsspeed's Avatar
You guys still looking for a running flathead to test your cam/lifter setup in? If so, send me a PM.
The stuff looks GREAT, neat project!
Old 12-15-2010, 04:05 PM   #135
plan9
Old School HAMBer
plan9's Avatar
looking tits guys. there is some great work being done, especially in the engine department.
__________________
Panel Beaters CC / Sidewinders
Old 12-15-2010, 06:02 PM   #136
Bored&Stroked
Alliance Member
Whew . . . finished the Crankshaft and Rod designs and got them off to Crower. Now we need to "get in line" and hopefully get something turned around in decent time. We heard it was about a 4-month wait, maybe they'll move faster and keep us happy
I'm not going to tell you all the secrets of every design for the FlatCad - as a LOT is going into this and who knows if it is going to work Also, we want a chance to run it, learn and hopefully be competitive, so we're not going to share everything we're doing . . . hopefully you all can understand.
Here is what I can share -- the crankshaft will be a custom billet design. There are a lot of things that we're doing to it to run a more modern bearing/design package and have a more performance oriented design. We need modern and available bearings - which is why we're going for BBC stuff. One of our biggest concerns is coming up with a design that is strong enough to take the horsepower and extended high-rpm usage . . . not an easy goal.
Here is a image that shows some of the design work for the snout and rear flange. What I'm showing has been edited to protect the guilty -- so all key design criteria is not included . . . or all the key dimensions.
Now I need to finish the girdle, main caps, intake plate and motor plate designs . . . much to do, but these are not as long of lead-time items as the crank and rods (at least I hope)!
__________________
Old 12-15-2010, 07:10 PM   #137
38FLATTIE
Old School HAMBer
38FLATTIE's Avatar
Quote:
Damn, the engine guys must all be quarterbacks, cuz they get all the glory!
Dale, I know I told you this before, but Fan-fucking-tastic!
Old 12-15-2010, 08:33 PM   #138
41 Dave
Old School HAMBer
41 Dave's Avatar
Buddy, Glad to see your team is making some progress on your mill. Looking forward to updates as you complete the build.
Hope you and family have a Merry Christmas and a Happy and productive New Year.
__________________
41 Dave
41 Fords Are Us !
Frustrated Chef
Next to retire . . . . well maybe . . .
Old 12-22-2010, 05:34 PM   #139
38FLATTIE
Old School HAMBer
38FLATTIE's Avatar
Thanks Dave, and wishing you and yours Happy Holidays too!
The body is back on, and I delivered it to choptvan today. Stay tuned- I know there will be lots of pics!
ID:	1185921   Click image for larger version
ID:	1185922   Click image for larger version
Old 12-22-2010, 06:23 PM   #140
pregrid
Grenade Inspector
pregrid's Avatar
Let the fun begin!!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
