Reply
Thread Tools Display Modes
Old 06-25-2010, 05:38 AM   #1
Filip Zegers
FNG
Default 1941 Willys coupe dimensions
Hi,
Like most of us, I'm on a budget when building hotrods.
Have a 1932 fibreglass 3 window (nostalgia) style + fibreglass roadster body that can be swapped on the same chassis .
I have this crazy idea of 'building' another (fibreglass) body on my 1932 chassis. In my country it's quite hard to register a car, so you will understand why...
This one will either be a traditional hotrod or maybe a taildragger.
I'm considering building a 1941 Willys body on my 1932 chassis.
Wheelbase of Willys: 104"
1932 Ford: 106"
This would mean a top chop on the willys body and extending the body +/- 2", which would be great anyway considering the (too) small body of a Willys coupe
**** Now: does anyone (perhaps several sources) know what track width front and rear original 1941 Willys coupes had?
Or better maybe: what is the width (outside) between front fenders?
& width (outside) between rear fenders?
So from outside of left fender to oustide of right fender
Just to see if my current setup of 46" Superbell / 57" rear axle, 5.60 x15 / 8.20x15 Firestones would fit between the fenders?
Or is there somewhere more info to be found on 1941 Willys coupe dimensions - I mean maybe an original workshop drawing of body, chassis with all dimensions height, length, width, track width,...
This should have existed somewhere in a catalog - or am I wrong?
In general, any factory info on the Willys coupes would be great if anywhere to be found...
Thanks a lot for any help on this matter!!
Filip
offline   Reply With Quote
Old 06-25-2010, 07:39 PM   #2
xracer40
Grenade Inspector
xracer40's Avatar
Default Re: 1941 Willys coupe dimensions
No dimensions but chassis pic may help some.
Click image for larger version
Name:	willys chassis.jpg
Old 06-29-2010, 05:09 AM   #3
Filip Zegers
FNG
Thanks!
that's indeed the first thing I get to see of it - should be possible to calculate starting from the wheelbase!!
Filip
anyone else?
Old 06-29-2010, 05:32 PM   #4
xracer40
Grenade Inspector
xracer40's Avatar
See this thread on HAMB,lots more of the type of info your looking for.
41 Willys Coupe Chassis Rail Specs
__________________
Heat'um UP!
Let Her Loose!
Old 07-09-2010, 07:01 AM   #5
Filip Zegers
FNG
just rechecking if no one can supply me with at least the following:
1941 Willys coupe:
**** what is the width (outside) between front fenders measured at wheel centerline (front axle)?
as explained, I'd love to build a coupe on a deuce chassis with 46" Superbell in front and '40 Ford brakes on 15 X 5 wheels (5.60-15 Firestone) & 57" rear axle (between wheel mounting flanges) with 15 X 7 wheels (8.20-15 Firestones)
I'm wondering if the wheels would fit in the fenders nicely or if I would need to adapt a lot
(I know there is a difference of 2" as far as the wheelbase is concerned, but that's not the point here)...
Thanks!!
Filip
Old 07-19-2010, 03:12 AM   #6
race_hemi
FNG
race_hemi's Avatar
Filip,
Check this out ...
http://www.nz-hotrod.com/vbulletin/s...willys+chassis
Cheers.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
