Reply
Thread Tools Display Modes
Old 02-16-2011, 08:21 PM   #61
kwmpa
Senior Member
kwmpa's Avatar
Default Re: Balancing Act
Quote:
Originally Posted by knuckhed55 View Post
Was wondering if anyone has done this with WIDE FIVE wheels / drums, this is where i dont know where to start, its hard to find an old shop that can still balance rims/tires/drums together, I love those WIDE FIVES but they sure are high maintenance... Please help... Thanks
use the beads and itll balance out
offline   Reply With Quote
Old 02-16-2011, 08:31 PM   #62
gimpyshotrods
Old School HAMBer
gimpyshotrods's Avatar
Get a lightweight Aluminum wheel adapter from Dick Spadaro, not a heavy steel one from Speedway, etc. He's on this board too.
When you bolt the adapter into the wheel, any shop can balance it, just like any other wheel.
__________________
Ala Kart had air bags in 1957. Traditional? Yes!
Old 02-16-2011, 08:39 PM   #63
Engine man
Senior Member
We use paper pouches full of a powder in flotation truck tires. You can balance everything perfectly with wheel weights but a small amount of dirt or ice in the wheel can ruin that balance. Movable ballast can balance on the fly and compensate for any changes.
Old 02-16-2011, 11:10 PM   #64
Blacksmith54
Newbie
Blacksmith54's Avatar
The tire shop I used a lot used bead they looked Waxie to me put one pouch in each tire on the back of my tow truck a 1995 Medium duty International 4700 roll back out side on the back of both sides the truck was parked in my yard last summer the temp was in the 115's to 118's and one of my guys told me about hearing one of them blow I went and checked it out and sure enough left side was toasted plys everywhere next day same guy was walking past the truck and about thirty feet away and the other side blew. Never could find any of the beads.
Old 02-17-2011, 02:11 AM   #65
Mitchell de Moor
Alliance Member
Mitchell de Moor's Avatar
Will this product work on tubeless Bias-Ply 6.70 - 15 Firestones or tubless radials?
__________________
Looking for 1956 Oldsmobile Roof, Rockers, Fenders, Quarters, etc.
Old 02-17-2011, 08:29 AM   #66
bonez
Old School HAMBer
bonez's Avatar
Incredible stuff! But i think all they do is absorb vibration in some way, im no expert, but its close to impossible to balance a wheel via a bag of beads.
Still, great to know, here in italy nobody want to balance my unilug Cragars so this is my only option i guess. thyre 155/80 and i dont really feel any vibration, at all, but i'll still do it. Thanx to whoever bumped this old thread up.
Quote:
website says it does. They have diffrent products for diffrent applications.
better contactin the m b4 purchase thou.
__________________
Sent from my ouiji board with black magic
Old 02-17-2011, 08:57 AM   #67
Mitchell de Moor
Alliance Member
Thanks!
__________________
Old 02-17-2011, 10:17 AM   #68
petew
Grenade Inspector
petew's Avatar
Just purchased dyna beads for my 35 KH wires. As I understand it the taller or skinnier the tire is the better they work, They are not recommended for the tuner type wide and short wheels/tires, the ones with no sidewalls.
Also to get them in the tire through the valve stem a friend of mine put a vibrating etching scribe tool against the feed tube from the bottle to the valve stem and they marched right in.
Pete
Old 02-17-2011, 02:32 PM   #69
gimpyshotrods
Old School HAMBer
I put the edge of my quarter-sheet sander up against the valve stem, and that seems to do the trick to get them in.
__________________
Old 02-17-2011, 02:49 PM   #70
R Pope
Old School HAMBer
I won't buy a tire that needs more than a tiny bit of weight. If they are built that lumpy, they won't stand up under hard driving. If the tire shop won't go for it, I find another shop.
The shot or whatever must act like a torsional damper, cancelling out vibes by moving around inside. If the tire is out of round, anything loose inside will go to the part that's farthest from the hub, and make things worse.
Old 03-13-2011, 02:49 PM   #71
cmyhtrod
Grenade Inspector
cmyhtrod's Avatar
I asked the guy who services the tires on my trucks about these. His reply was if they work so well, why do companies make tire balancers?
Old 03-13-2011, 03:11 PM   #72
Atwater Mike
Old School HAMBer
Quote:
Ask a tire guy in the industry for an unbiased answer. There may be an economic factor here...
Ask the Head American about gasoline powered cars. His reply will be, "If they work so well, why is GM producing the fabulous 'Volt'?"
__________________
Mike in Atwater
online   Reply With Quote
Old 03-13-2011, 05:51 PM   #73
simon g-s
Grenade Inspector
simon g-s's Avatar
Put them in my dirt tracker tyres. Got double vision vision at anything over 70 mph before dyna beads, smooth as you like now, 120 no problem !
Highly recommended.
Click image for larger version
Old 03-13-2011, 06:18 PM   #74
Brewton
Brewton's Avatar
I've put these in 2 sets of front tires on my coupe (the 2nd set yesterday). Hayes-T and I used his orbital sander with a shelf rod stuck in it and vibrated all the beads through the valve stems. My first set of tires I did this the hard way by tapping the valve stem... this will make you go F^%$$& mad! Anyway, I took the weights off my first set of tires... no shakes. I left the weights on this new set... even smoother! I'm fixin to put some in the rears just to see if I can get it even smoother. Great product! I recommend them to all Hotrodders!
__________________
- If it burns fuel, makes noise, goes fast and scares children - it's cool!
Old 04-02-2011, 10:54 AM   #75
Weasel
Old School HAMBer
Weasel's Avatar
About time for another bump - I have a big issue with my Willys throwing stick on weights off the rear tires and I cannot use clip ons on the 16" x 8.5" rear US Indy Torq Thrust-alikes so Dyna Beads here we come....
__________________
Procrastinate NOW!
Old 07-11-2011, 09:56 AM   #76
Nads
Old School HAMBer
Finally put em in, but only in the Radir slicks round back, a definite improvement but around 80 mph there's still some vibration, perhaps putting some in the front tires would help.
__________________
Over enthusiasm and ownership of a MIG welder do not a fabricator make.
Old 06-03-2012, 11:22 AM   #77
Hot Rod Packard..
Hot Rod Packard..'s Avatar
These work by countering the hop of a tire. You can look on YouTube and see a illustration on how they work. If the tire hops in one direction the beeds move in an opposite direction to counter balance the hop or shake. The beeds never find a happy place in the casing and stay there. If the tire is moving they are working. This is why they are not heavy like lead shot. If it were heavy it will have a harder time moving around inside the tire while the tire is under speed. You cant use them in tubes or tires that have has any thing like slime or fix a flat put in them. The inside of the tire must be dry and clean. Innovative balancing says to take the weights off when you install the beads but I'd you wanted I don't see why they couldn't stay. I personally would remove them on an open wheeled car. I called and ordered enough for the front and rear tires. Nice people to deal with and very informative. Cost 68$ shipped to my house. I don't think that's bad cause any shop (unless you have a hook up) will charge 15-20 $ a tire to spin balance. Im looking forward to trying it and will post the results here. I have done a bit of research after asking about these beads. They work! From what I have found, if they don't work then they have been installed in a dirty tire.
__________________
BRIAN.
Febuary 2010 Hot Rod Magazine.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
