Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#21 | |
Tech Editor
Quote:
Great tech!
__________________
Daddy always said, If yer gonna be dumb, ya gotta be tough! - And I'm one tough sumbitch! T5 Tech |
#22 |
Awesome post.. I originally was going to drill my axle too but I was getting lazy... Your finished product looks so cool I'm going to have to do it.
Just a note on hole sawing thick and or hard material: If you drill one or two 1/8" holes right inside the diameter of the hole saw it will cut a whole lot easier. These holes allow chips to escape, lube to get in, and give the hole saw a better bite. It will cut your time in half and save you wear on your blade. See below:
#23 | |
Location: Kingman, Arizona - The place on the way to other places....
Quote:
I use hole saws fairly often. Mostly in alumimun, now and then in 1/8-3/16" steel. (T McG's post done today (Hole Saw Trick) is a good one for larger holes.) As a fwiw, I like to drill pilot holes prior to cutting with hole saws. Makes the hole saw cutting bit easier since you're only doing sawing if you have a 1/4" pilot hole. Easier to gauge the pressure as well. Good post, you've got me thinking a drilled axle would look great on my 31 roadster.
__________________
Sailing the turquoise canyons of the Arizona desert. C9 |
#24 | |
Senior Member
Quote:
#25 |
Old School HAMBer
El P,
do you chamfer the holes? how's the best way to do so? do they make chamfer bits that large?
__________________
atch (Mike Atchley) <>< MO hambers - join Missouri H.A.M.B.ers and check out this thread |
#26 | |
Old School HAMBer
This guy wanted the crisp edge so I just deburred it with a half round needle file and left as much as I could.
I have seen chamfer bits large enough but fitting down in the web might be an issue so the best bet is a file and some patience. I have gotten pretty good with my Dynabrade mini belt sander but would worry about it getting away from me. Good work takes time. Quote:
#27 |
Old School HAMBer
Nice post. I've always used a hole saw. Well, the first two holes in the first axle was with a regular $60 bit which bacame a paper weight.
I always tell people there are five steps: 1) measure 2) measure 3) measure 4) mark 'em 5) drill 'em (and that you can never use too much cutting fluid)
__________________
Pics of your mom naked at killKIRK |
#28 |
Old School HAMBer
BTTT, as a tech week runner up and all around cool post...
Sam.
__________________
SBC's rule... all others drool. |
#29 | |
Senior Member
Quote:
__________________
Vagabonds CC |
#30 |
Old School HAMBer
Good stuff.
__________________
CrossMembers CC |
#31 |
Old School HAMBer
I was notified that the photos got lost in one of the HAMB upgrades. I just posted them over on my PhotoBucket account.
Here is a link to the photos for this thread. |
| Thread Tools | |
| Display Modes | |
