Reply
Thread Tools Display Modes
Old 05-26-2010, 05:55 PM   #1
Capt.Mike
Newbie
Capt.Mike's Avatar
Default 40 ford door adjustment
How do you adjust the doors on a 1940 Ford 2 Dr Sedan? Since there appears to be no adjustment in the hinges I am guessing you have to torque the body mounts. Having never tried this before I could use some help.
The drivers door is about 1/2" to low at the latch. The right door is fine.
I have the vehicle on a level surface.
The project is fun but progressing slowly. I did attempt to start the engine this week, after sitting for 16 months. A clean carb, new wires and plugs, new fuel pump and lines and a cleaned out tank with fresh fuel did the trick on the first crank. I was like a kid in a candy store. The 5.0, running through new Flowmasters, sounds great.
offline   Reply With Quote
Old 05-26-2010, 06:36 PM   #2
36-3window
Old School HAMBer
36-3window's Avatar
Default Re: 40 ford door adjustment
is the driver's door just low because the hinges are worn out? how are the door gaps?
__________________
when small men begin to cast long shadows it is a sure sign the sun is setting.
Old 05-26-2010, 07:00 PM   #3
39 All Ford
Alliance Member
39 All Ford's Avatar
Quote:
I mocked up my 39 Coupe doors last week, If 1/2" low at the striker, the gap at the top front of the door must be too big OR the gap at the front bottom must be too small.
You can get away with bending the hinges just a little before they start looking screwed up, and the cowl posts will "adjust" a little if you use the right tool. The first time I mocked my doors I made a tool by welding a small plate to a 20" x 1" square tube and bolting the plate to the hinge mount.
This will provide good leverage and control.
__________________
Building a car is easy, building a car right is a mite bit harder.
Old 05-26-2010, 07:19 PM   #4
milwscruffy
Alliance Member
milwscruffy's Avatar
Please keep in mind that the hinge pin holes are meant to be in line with one another so tweaking things may screw that up. A long piece of 1/4" rod should be able to pass throgh both hinges at once. On most all that i have done , i have had to take the door off the A-pillar with the hinges still on the door and then drill out or grind the remaining bolts. Everyone that i have touched has had the bolts welded to the hinges. It's a fair amount of work but after doing this you can get much more adjustment on the door.
__________________
If all else fails........give me another beer.
Old 05-26-2010, 08:14 PM   #5
Capt.Mike
Newbie
Capt.Mike's Avatar
Here are some pictures of the problem. The hinges are bolted on which can give some adjustment in and out. The gap on the front is even from the bottom to the top hinge than it begins to widen. On the rear of the door the gap is pretty even top to bottom. Of course the gap at the top goes from 1/4" at the front to almost 1" at the rear. The right door is about 1/4" gap all around. The body seems to be in the correct position and is not bowed or warped. I installed new pads all around when I put the body back on the frame.
This was a project-in-progress that I bought. All though it had a pretty coat of paint on it the frame still had cracks and cuts that required it's removal for repair.
Click image for larger version
ID:	985253   Click image for larger version
ID:	985254   Click image for larger version
ID:	985256   Click image for larger version
ID:	985257   Click image for larger version
Old 05-26-2010, 08:18 PM   #6
Capt.Mike
Newbie
Capt.Mike's Avatar
Also - the hinges look almost new. They have no play or wobble in them.
Old 05-26-2010, 08:20 PM   #7
vintageauto
Alliance Member
vintageauto's Avatar
It may not be the hinge(s). Try shimming the body. I have a chart/booklet that shows where to shim the body for this type of problem and other alignment problems. I'll try to find it. I got it a few months ago on ebay. Its a pretty good reference for many 30's-40's cars.
Murph
__________________
If you always do what you always did....you will always get what you always got.
Old 05-26-2010, 08:36 PM   #8
vintageauto
Alliance Member
Below is the description of the body shimming guide for a 1940 Ford.. I think its what you need. I have the details where to get it on ebay.
Murph
So the much awaited time has come to bolt your body back onto the frame...your project is going to really start looking like a car again! The trouble is, it isn't that simple! I can't tell you how frustrating it is to try and get the body bolted down and shimmed correctly so all of the doors open and close nicely! A shim here, a gap there...it can really be a challenge to get things right. This auction is for a guide which is intended to take much of the guess work out of making the necessary adjustments when properly aligning the doors in the door opening on your car when bolting the body back on. This information is taken from old body shop manuals from the 50's when guys did this sort of work daily...back before the uni-body!
The best thing about this guide is that it is not body specific. The principals outlined can be used for any body designed/built in the 1930's, 40's,50's, and many 1960's model vehicles.
These sheets use condition/remedy scenarios which show unfavorable door gaps, and the shim remedy to fix the issue. It is important to note that this is not a complicated manifesto in mechanical engineering! It is intended to be a basic guide in properly shimming a body as it was done at the factory.
Please note: This is not a crappy black and white photo copy from an old Chilton's! With this auction you will receive a NEW, CAD-Clear, Color, large format 8.5x11" 8 page guide. The body illustrated is a 1940 Ford, but again it is universal to all bodies from that era. The charts will come rolled in a sturdy shipping tube...not folded up in an envelope to make it there on a dime!
Thanks for looking, please see my other items for Frame dimensions and rare collectible speed parts.
__________________
Old 05-26-2010, 08:41 PM   #9
vintageauto
Alliance Member
The sellers username on ebay is: ilovetmatt27
Here is the auction opening, I paid $6.00 bucks for it.
Body Shimming Guide 1935 36 37 38 39 40 Ford nos COLOR
Color - 8-pg - Clear Drawings - NOT a crumby Photocopy!
Please wait
Image not available
Item condition:New
Ended:Mar 16, 201006:34:45 PDT
Bid history:1 bid
Sold For:US $6.10
Shipping:$1.50 US Postal Service Parcel Post See more services
Start of layer
Service and other details:
Service
Estimated delivery*
Price
3-10 business days
$1.50
Local Pickup
Free
*The estimated delivery time is based on the seller's handling time, the shipping service selected, and the payment method selected. Sellers are not responsible for shipping service transit times. Transit times may vary, particularly during peak periods.
Click To Close
End of layer
See shipping discounts
Start of layer
End of layer
| See all shipping details
__________________
Old 05-27-2010, 05:50 AM   #10
Capt.Mike
Newbie
Capt.Mike's Avatar
Thanks guys.
Old 05-27-2010, 06:21 AM   #11
2345.coupe
Alliance Member
2345.coupe's Avatar
here's a old body man's trick, simple and easy..........jack on the back of the door, let it down, check, repeat several times each time going a little higher, then check.........
I need more weight in my car to finish the door alignment so I'll finish it when the motor and trans are installed.......
Old 05-27-2010, 07:19 AM   #12
okiedokie
Senior Member
okiedokie's Avatar
I did the shim shuffle on my 40 coupe to align the doors. Man, that took some trial and error. Buy the chart. Joe
Old 05-27-2010, 07:53 AM   #13
alchemy
Alliance Member
alchemy's Avatar
If the gap between the hinges is correct, the problem is the shims under the mounting bolts. Don't bend the hinges.
Your problem needs a shim under the bolt right at the A post to cure. Do not put a shim under the front edge of the cowl too, as you need to swing the door upward at the A post.
You may find a need to install a smaller shim under the B post as well if you can't get a good gap at the back of the door (if you go too far and can't get it back down), but this is a very slight possibility.
Start with a 1/16" shim under the A pillar, driver's side only.
Old 05-27-2010, 10:49 PM   #14
Capt.Mike
Newbie
Capt.Mike's Avatar
Thanks again. I ordered the book. I just got home from working on one of the fire crews at Charlotte Motor Speedway so I am out of gas for tonight (it was fun though). I'll try a few shims tomorrow just to start getting a feel for how it works.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
