View Poll Results: Would you want to try this?
YES! 104 52.26%
NO! 37 18.59%
I'd Probably just save for Cokers/Diamondbacks 58 29.15%
Voters: 199. You may not vote on this poll
Reply
Thread Tools Display Modes
Old 04-27-2010, 11:05 PM   #1
BIGREDTODD
Alliance Member
BIGREDTODD's Avatar
Default Cheap Wide Whitewalls (revisited) using "White Tire Paint"
I'm going to do my best to keep this simple and concise...
After searching and reading and reading a bunch of threads on the subject, and not finding a lot of thorough information, I decided to attack the following problem:
  1. *Needed to put good tires on the T-bird
  2. *I didn't have $750 for a set of radial wide whites
  3. *I did have about $350 and a free weekend
So I decided that, after reading mixed reviews of all other tire paints out there from Krylon, Ebay tire paint, to the snow-coat roof paint, that I'd go for the good stuff from Orn Sigurdsson in Iceland (Great guy, shipped immediately, takes about a week to get here). I ordered 3 cans ($80shipped) to be on the safe side, but only used 2 of the cans:
I went down to Pep Boys and bought a set of Cornell 1000 radials. A lot of folks might call these cheapie crap tires, but they are made by Cooper, and this is the fourth set that I've bought. Really nice tires, and a clean sidewall (More on that later). $220 carry out, then had my tire guy mount/balance them for $40 with the whitewall turned to the inside:
I wanted to do my best to clean the sidewall of the factory markings:
So I sanded them of with 80 grit, with an electric orbital sander:
And they ended up pretty well. It should be noted that you'll need to move around quite a bit. The rubber heats up, stops sanding off in a "dusty" form, and clogs up the cheap sand paper I was using. I followed the 80 grit with 180 over the entire sidewall to give the paint a little "tooth" and to give a uniform surface visually:
I then made a "jig" of sorts to make sure that all the tires had the same radius. I used a sacrificial hubcap, a strip of 16 gauge steel bent with some thought for the shape of the tire, allowing room to clamp a blade to the side, set for a 2 1/2" whitewall:
__________________
1949 Ford 2 door sedan for sale: http://www.jalopyjournal.com/forum/s...d.php?t=869609
offline   Reply With Quote
Old 04-27-2010, 11:18 PM   #2
BIGREDTODD
Alliance Member
BIGREDTODD's Avatar
Default Re: Cheap Wide Whitewalls (revisited) using "White Tire Paint"
Here's the basic material (excpet for blue masking tape, steel, and Razor blades). About $40 worth of goods at the neighborhood Home Depot:
This photo shows tire #1 taped off with black duct tape. This was a stupid idea. DO NOT USE DUCT TAPE!!!! I used blue painter's tape on all tires, including this one after I realized all the residue the duct tape leaves behind:
More to come, just uploading pictures and posting!
BIGREDTODD
__________________
Old 04-27-2010, 11:29 PM   #3
BIGREDTODD
Alliance Member
BIGREDTODD's Avatar
Not shown in photos, but very important:
*Use a wax/grease remover (I used Oil Eater from Costco) to thoroughly clean the tires of any oily residue. Extremely important!
*Before you paint, warm up the paint. I soaked mine in the utility sink for 10-15 minutes. It really makes a difference, and is a recommendation in the provided instructions.
Here's a couple of shots showing how the blade compass worked. First, the attachment to the aforementioned sacrificial hubcap:
The glowing stop sign should be taken as further warning about the stupidity involved with the duct tape. Here's a close up of how I clamped a razor blade to the return leg of my "compass", Plan on using a new blade for each tire. They dull quickly on the tires, and you only want to cut through the tape:
After switching to more practical blue masking tape, this shows the first tire after the radius cut with my jig. I would use more tape on subsequent tires, just for more of a comfort zone:
__________________
Old 04-27-2010, 11:37 PM   #4
BIGREDTODD
Alliance Member
BIGREDTODD's Avatar
I'll admit, it's a little nerve-racking after the first coat of paint. It covers pretty well but the brush strokes are pretty evident:
But before I knew it, the first coat was done, it was 1 a.m. and time to go to bed after all had the first coat:
No pictures of the second coat, as there's nothing that can be captured on camera. It covered very well, and the bruch strokes settled out quite well.
__________________
Old 04-27-2010, 11:43 PM   #5
BIGREDTODD
Alliance Member
BIGREDTODD's Avatar
I forgot to note it above, but I used a new brush for each coat, on each tire. I bought cheap brushes that held up pretty well, but I HATE cleaning paint brushes and figured I'd err on the safe side.
While I didn't photograph it due to a mild hangover and being generally excited to see the finished product after its second coat (re-coat only after 24 hours of dry time as recommended), this step will have a great impact on the final success.
Before you try to peel the tape, take a fresh razor blade and cut right to the inside of the tape, if not perfectly on the edge. I found that this took 2 blades per tire, as you are cutting through the rubberized white paint.
Take your time, be patient, and don't attempt to cut the tape until the paint is completely dry. It just makes a mess.
__________________
Old 04-27-2010, 11:46 PM   #6
chopped51
Senior Member
chopped51's Avatar
Been there done that. Ran tire paint and every kind of white coating you can think of. Bottom line? Nothing lasts. You do it over and over and over.
You spent a lot of $$ of paint and supplies. Could have paid for two WWW.
You'll see...............
__________________
Relax. I think this should work. www.areafifty1.com
1951 Merc Kustom
1950 Merc M1
1927 STEEL RPU
Old 04-27-2010, 11:54 PM   #7
BIGREDTODD
Alliance Member
BIGREDTODD's Avatar
The supplier recommends not loading the tires for one week after painting. That worked fine for me since the Bird was on stands already.
For the moment, these are all the finished photos I have (see below). The engine & engine compartment is about 90% through paint, and ready for reassembly, so I can't roll her out at the moment.
I hate the waiting game for tech threads to finish, so here are the tires back on the car. I'd say from 5 feet away you'd never thick to consider they were painted on, which was the goal. I still have a few touch ups to do as far as removing some residue and some overzealous brushing, but this should give a pretty good idea:
__________________
Old 04-28-2010, 12:00 AM   #8
UnsettledParadox
Senior Member
UnsettledParadox's Avatar
subscribed!! thanks for taking the first bullet for us!!
__________________
Fashion is fleeting; Style fades; Tradition is FOREVER.
Old 04-28-2010, 12:03 AM   #9
BIGREDTODD
Alliance Member
BIGREDTODD's Avatar
Quote:
That's kind of the point. I need 4 of 'em (and I also needed a Mallory tach drive dizzy for the Bird)
And I have another can for touch up. I will post updates from time to time after some use, and some time has gone by. Other HAMB'ers have successfully used this specific product (from Iceland) for years without trouble. I figured, since I couldn't find a tech thread using this product, I would learn for whoever cared to follow along...
__________________
Old 04-28-2010, 12:18 AM   #10
Lazer5000
Lazer5000's Avatar
Looks like you put a little more time into it than I did Todd.
Paint=$80
Tires=$220
Balancing=$40
Total=$340
All this= you have $10 left. Lunch is on you! Ha ha, bet you didn't know I was some kind od numbers wizz.
__________________
"Government is not the solution to our problems, government is the problem."- Ronald Reagan.
Old 04-28-2010, 12:26 AM   #11
chopped51
Senior Member
chopped51's Avatar
I couldn't afford WWW either. I'm in Canada so they're $1,000 by the time I get them.
Live and learn. I'm not knocking it. I'm just saying. They look great.................... until you start driving and crazy shit like rain happens.
__________________
1951 Merc Kustom
1950 Merc M1
1927 STEEL RPU
Old 04-28-2010, 01:12 AM   #12
PunkAssGearhead88
Senior Member
PunkAssGearhead88's Avatar
I used the same exact "White tire paint" you used, on the rear tires of my shoebox and It looked ok for the first few months, but after about a year they have definately discolored... I prepped everything as I should of as well... Dunno why that happened... I have have yet to see a paint used on tires that lasted..
__________________
If you're hung like a horse, you don't need a Mustang.
Old 04-28-2010, 01:27 AM   #13
KrisKustomPaint
Senior Member
KrisKustomPaint's Avatar
Quote:
Should have done more burnouts.
Looks great and I can see that being very useful for tire sizes that don't normally come in wide whites or performance tires that aren't offered in white walls.
Old 04-28-2010, 01:31 AM   #14
PunkAssGearhead88
Senior Member
What does burnouts have anything to do with it?? It discolored on both tires, and I dont have posi. For how much the paint costs, and what it claims, it definately wasnt what I expected.
__________________
Old 04-28-2010, 01:42 AM   #15
Lono
Senior Member
Lono's Avatar
Yep i used the white can stuff too on a brand new set of tires.
I drove them less than a mile and the white started pealing off.
what didnt peal off wouldnt come off until I hammered them with a pressure washer.
I hope you have better luck. If you're not to frustrated try some enamel paint, its known to stick to some tires too.
Old 04-28-2010, 08:02 AM   #16
Lazer5000
Lazer5000's Avatar
I have heard that it works better on older tires. I guess new tires (under a year) "out gass" as the rubber continues to cure. This out gassing causes the discoloration. As the tire age the gasses reduce and the paint should stay whiter longer. But hell, even if you only have to touch them up every six months or so it could still be woth it.
__________________
Old 04-28-2010, 08:37 AM   #17
atomickustom
Old School HAMBer
atomickustom's Avatar
Thank you for setting up this test.
Several of us will be waiting to see what you have to say after driving the car for a while. They look nice and I hope they hold up, but ANYTHING looks good when you first do it. The big question we will all be waiting for is how they look after a couple months on the road.
__________________
My real name is Dave
Old 04-28-2010, 08:43 AM   #18
BIGREDTODD
Alliance Member
BIGREDTODD's Avatar
Quote:
That's my understanding also about the "outgassing"...the website that sells the paint mentions that the shiny sidewall should be scuffed, and wax/grease remover used.
You can spray the stuff as well, and I think I'll try that next time just for kicks (absolutely no brush marks).
If I only have to touch them uponce or twice a year, I'll be happy. The car is garaged, so they aren't going to cook out in the sun. I've heard so many customers complain about the WWW from the manufacturers yellowing in short order, and seen first hand how some have checked over time, this was a calculated risk...
Thanks for all the comments, both positive and negative. Some interesting feedback...
__________________
Old 04-28-2010, 08:52 AM   #19
rivguy
Grenade Inspector
rivguy's Avatar
They look pretty good to me. Try using white spray can primer with the same set up. It lays out flat and has a nice matte look. I've had mine sitting outside for two years and they still look good. I read about this in Rolls and Pleats a few years ago. You know how hard it is to get paint overspray off of a tire.
Old 04-28-2010, 08:59 AM   #20
Dan
Senior Member
Dan's Avatar
cool idea with the compass...
funny how whenever I accidentally get paint overspray on a tire you cant get that shit off to save your life...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
