Reply
Thread Tools Display Modes
Old 04-24-2010, 06:50 PM   #1
oleskool
Grenade Inspector
oleskool's Avatar
Question Speedometer cable lubricant
What is the best lubricant to use on a speedometer cable?
Thanks for your input.
__________________
Criticism is the father of ignorance!
offline   Reply With Quote
Old 04-24-2010, 06:52 PM   #2
29nash
Default Re: Speedometer cable lubricant
Just about any grease.
Old 04-24-2010, 06:52 PM   #3
bobscogin
Senior Member
Don't know what's best. but I've always gotten good results from white lithium grease.
Bob
Old 04-24-2010, 06:53 PM   #4
dmac620
Grenade Inspector
dmac620's Avatar
Graphite in a spray can. Can be found in Lowe's or Home Depot. Just did mine a couple of months ago and had good results.
Old 04-24-2010, 06:55 PM   #5
brad chevy
Old School HAMBer
Xs-2 on white-lithium grease
Old 04-24-2010, 06:57 PM   #6
AAFD
AAFD's Avatar
Any Lithium-Based Grease will work best. Always clean the cable with solvent and blow dry (or air dry) it, then add the new Lithium grease.
Old 04-24-2010, 07:00 PM   #7
pauls fords
Grenade Inspector
pauls fords's Avatar
Grease eventually hardens and the speedo will start to jump around, go to a parts store and ask for 30ND motor oil {non detergent} 30 weight, saturate the inner cable when assembling it. I use 30 ND because any multi visc oil 10-40 will dry up because it has detergent in it.
Old 04-24-2010, 07:30 PM   #8
Alliance Member
Mr48chev's Avatar
Quote:
Bob
+1 that is all I have used for the past 45 years.
__________________
Happiness is having a garage big enough to hold all ttools and projects and small enough to keep warm enough to work in the winter.
Old 04-24-2010, 08:18 PM   #9
AAFD
AAFD's Avatar
http://www.speedometershop.com/faq.html
Old 04-24-2010, 08:23 PM   #10
Deuce Roadster
Deuce Roadster's Avatar
O'Reilly's Auto Parts actually sells a SPEEDOMETER CABLE lubicant. It comes in a small tube ... costs about $2.50 or so and I just bought some a few days ago for the speedometer in my 32 roadster.
After 15 years on the road ... the cable has a slight twitch and need lube.
I plan to take care of that item tomorrow
__________________
"Whether you think that you can, or that you can't,
you are usually right." Henry Ford
Old 04-25-2010, 05:23 AM   #11
claymore
Powdered Graphite comes in a nice little tube like a toothpaste tube with a nice small opening to put into the housing. Never dries out or leaks.
Old 04-25-2010, 06:31 AM   #12
tommy
Old School HAMBer
tommy's Avatar
The graphite lube that I used made for speedo cables came in a tube mixed with alcohol. The alcohol carried the powdered graphite all the way to the other end of the cable. The alcohol evaporates leaving the dry graphite inside to lubricate the cable. Disconnect both ends and pour it in from the top. When it comes out the bottom end, you know that the entire length got lubricated.
__________________
Quote...You are hereby Knighted...'Sir Asseth of Hole' Tommy... 3W Larry.
Quote...It's called "HOT RODDING", not paint by numbers....Fab32
online   Reply With Quote
Old 04-25-2010, 10:27 AM   #13
knotheads
graphite is what we always used when i worked at service stations. (remember when service stations did lube and oil changes?)
Old 04-25-2010, 10:38 AM   #14
burnout2614
burnout2614's Avatar
White lube.
Old 04-25-2010, 10:55 AM   #15
a50merc
a50merc's Avatar
They have been using Grafite ever since Car's were Built
so I like Grafite & have been using it on All my cars
since the 50's
Just my 3.5 cents
Old 04-25-2010, 11:01 AM   #16
39cent
Senior Member
39cent's Avatar
my Dad told me to use graphite, that was for my first car a Model A, [in 55] ggg
__________________
"If you think you can do
a thing or think you can't do a thing, you're right".- Henry Ford,
Old 04-25-2010, 11:36 AM   #17
61bone
61bone's Avatar
Graphite or dry lube. Doesn't dry, gum or cause speedo to run slow when cold.
Old 04-25-2010, 06:39 PM   #18
Model A Speedster
Newbie
If you can get the cable and housing off the car, do so. Pull the cable out of the housing and clean it as best you can. Suspend the housing so that it hangs straight up and down with a coffee can underneath. Now pour some STP down the housing and let it drip into the coffee can. This will take a while. Reassemble. Enjoy. From an old Model A guy.
__________________
You can't build a reputation on what you are going to do. - Henry Ford
Old 04-25-2010, 07:40 PM   #19
4dFord/SC
4dFord/SC's Avatar
Think I used Vaseline the last time I did mine, X years ago.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
