Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 04-12-2010, 04:49 PM   #1
HELLMET
Senior Member
HELLMET's Avatar
Default tru spoke wheel lug nut fitment
how deep does the lug need to be? i have some but they bottom out even with the thick washer.is there a spacific lug nut for tru spokes? thanks billy
offline   Reply With Quote
Old 04-12-2010, 04:57 PM   #2
Mr.Bomba
Mr.Bomba's Avatar
Default Re: tru spoke wheel lug nut fitment
With the washer on it should be a little shy of being flush with the the back mounting pad (spacer) hope this helps!
Old 04-12-2010, 05:01 PM   #3
HELLMET
Senior Member
HELLMET's Avatar
i think the lug nut is to long if i double the washer it will get tight but i dont know if it will tork down properly. what should the tru spoke tork to? these are old ones 15x7.
Old 04-12-2010, 05:07 PM   #4
Mr.Bomba
Mr.Bomba's Avatar
do they have the spacers on the backside? they bolt on with 4 screws
Old 04-12-2010, 05:31 PM   #5
HELLMET
Senior Member
HELLMET's Avatar
No the only thing i have is the wheel adaptors i had to go 5x5 to 5 4 3/4 and they are 1-1/4 thick the good ones.the tru spoke would not clear my hub center on the rotor.
Old 04-12-2010, 05:43 PM   #6
4woody
Senior Member
Are you sure you've got the right washers?? Maybe the P.O. (if there was one...) gave you some that aren't the right thickness?
Old 04-12-2010, 05:43 PM   #7
54fierro
Grenade Inspector
54fierro's Avatar
They make short and long shank mag lugnuts. Are you already using the short ones?
Old 04-12-2010, 05:45 PM   #8
ryno
Old School HAMBer
ryno's Avatar
check with lug nut king. i believe he's in san diego ca. i needed 1" long shank ones, but im running the factory spacers that come with tru's.
Old 04-12-2010, 05:55 PM   #9
HELLMET
Senior Member
HELLMET's Avatar
Do you have pics of the spacers? I did not know they had spacers. Maybe thats my problem.
Old 04-12-2010, 06:15 PM   #10
HELLMET
Senior Member
HELLMET's Avatar
The lugs are 1" shank i belive.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
