Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 03-23-2010, 03:12 PM   #1
poboyross
Senior Member
poboyross's Avatar
Default Engine damage from running without exhaust system?
I'm finishing up installing a 283 in my 50 Chevy, and was recently told that I shouldn't be running the motor without exhaust pipes/muffler because it can cause damage to the engine. Is that true or just some BS? All I really need it to run for is to warm up enough to open up the thermostat and get the engine refilled with coolant, finish setting the points, and testing out the carb.
thx!
__________________
Faux'dster Build thread: http://www.jalopyjournal.com/forum/s...d.php?t=615579
offline   Reply With Quote
Old 03-23-2010, 03:17 PM   #2
Mr. Mac
Senior Member
Mr. Mac's Avatar
Default Re: Engine damage from running without exhaust system?
BS in my books.About the only thing that might hurt an engine is to run with no exhaust manifolds at all and then when the engine cooled it could warp the valves.My two cents.
Old 03-23-2010, 03:26 PM   #3
57JoeFoMoPar
Alliance Member
57JoeFoMoPar's Avatar
Quote:
This has been dealt with here many times. I'll echo what Mr. Mac said. However, personally, when firing a fresh motor, I'd much prefer to have a full exhaust system, especially with mufflers. The reason being you'll be able to hear the motor and anything audible that might hint to troubles during break in that the gauges aren't telling you.
__________________
-'57 Joe
Street Aces CC - New Jersey
"When life knocks you down from first class to coach, fart a whole lot and really stink up the place...that'll show 'em."
Old 03-23-2010, 04:11 PM   #4
BudJ63
Newbie
BudJ63's Avatar
I was told back when, that the open exhaust ports (no manifold or headers) let cold air hit the valves when shut down, and could warp them as Mr Mac said. Whereas the heated pipes would keep the atmosphere warmer til the valves had a chance to cool down. If its got headers or manifolds but no exhaust system, I wouldn't worry about it.
Old 03-23-2010, 04:18 PM   #5
HemiRambler
Old School HAMBer
HemiRambler's Avatar
I've heard many times about the possibility of warping the valves...if that's true then it puzzles me how they didn't warp when you STARTED the motor???
__________________
With the help of some and inspite of others...
Old 03-23-2010, 04:31 PM   #6
1930roadster
Grenade Inspector
1930roadster's Avatar
Oh i hate that tale... I'd bet the guy that started that owned an auto exhaust shop back in the 40s. I tried on Harleys and my old big block Chevy... open, on the street and in the cold, i tried real hard too
Old 03-23-2010, 04:31 PM   #7
johnnie
johnnie's Avatar
My only concern would be running it too lean.
__________________
'57 Ford 300s, and any gassers, I am a fan.
Old 03-23-2010, 04:39 PM   #8
propwash
Old School HAMBer
propwash's Avatar
fresh motor....as quiet an exhaust system as possible so you can hear the actual mechanical parts of the engine. After "sea trials" then you can break it back to just headers. There is some danger of valves that cool too quickly tending to warp - ask any A&P or even experienced pilot about coming down out of the higher altitudes too quickly if you doubt me. Headers are just a good idea from a scavenging designe standpoint...you don't really want a bunch of flames shooting out of your heads anyway...cops might let the noise slide - but you'll be scaring the dickens out of the uninitiated and pissin' off the tightasses.
dj
online   Reply With Quote
Old 03-23-2010, 04:39 PM   #9
mart3406
Old School HAMBer
mart3406's Avatar
Jeez???. When will this old wives tale die???? No, running with an open exhaust and/or straight pipes will not hurt your engine, cause your valves to burn, bring on the 'heartbreak of psoriasis' or do any of other numerous ridiculous 'bad things' that it supposedly causes. It likely won't make any more power or cause your car to run any better or faster than if it had a properly designed, 'muffler equipped 'exhaust system either, but that's another matter. The worst it will do is likely piss your neighbors off, gain you a few tickets for excessive noise and damage your hearing, but that's all!
Mart3406
Old 03-23-2010, 04:43 PM   #10
zzford
Senior Member
zzford's Avatar
Nope, it's crap. think about it...You have a big ol' hunk of iron that's real hot... air wafts into the port... which gets the temperture change fastest, the big ol' lump of iron or the air?
__________________
I used to eat alot of natural foods
until I found that most people die of natural causes.
Old 03-23-2010, 05:05 PM   #11
poboyross
Senior Member
poboyross's Avatar
Quote:
Originally Posted by mart3406 View Post
Jeez???. When will this old wives tale die???? No, running with an open exhaust and/or straight pipes will not hurt your engine, cause your valves to burn, bring on the 'heartbreak of psoriasis' or do any of other numerous ridiculous 'bad things' that it supposedly causes. It likely won't make any more power or cause your your car to run any better or faster than if it had a properly designed, 'muffler equipped 'exhaust system either, but that's another matter. The worst it will do is likely piss your neighbors off, gain you a few tickets for excessive noise and damage your hearing, but that's all!
Mart3406
LOL....well, at least I don't have to worry about the Psoriasis. It's not a "fresh" engine by any means. It's already been broken in for some years now, I just gave it a check up, replaced all the gaskets, and tightened her up correctly.
THANKS for all the replies. I amazes me how many "BS tales" there are, from a "noob's first build" perspective.
__________________
Old 03-23-2010, 05:49 PM   #12
59ab
Grenade Inspector
I don't buy it either. Have been hearing this for years but nobody can tell who it happened to.
Old 03-23-2010, 05:57 PM   #13
rusty1
Old School HAMBer
rusty1's Avatar
...a little tip on your thermostat, drill an eighth inch hole in the flange, then install, this will allow it to purge the system of any air and it won't burp out the cap or overflow on the first startup. This won't hurt normal use thereafter.
__________________
7th Annual "Scrap Drive" Show/Swap
June 8th, 2013... Belvidere, Illinois.
www.thescrapdrive.com
Old 03-23-2010, 06:32 PM   #14
Beep
Alliance Member
Beep's Avatar
Won't hurt the engine at all,,,,,but it may sterilized the operator...
__________________
Beep
You haven't lived until you've almost died,
for those who have fought for it, life has a meaning the protected will never know
Old 03-23-2010, 06:51 PM   #15
metalshapes
Tech Editor
metalshapes's Avatar
On certain '60s Ferraris it said in the Workshop Manual to take off the headers and run it without.
So you could measure at which distance from the head the color of the flames changed.
This was to check the mixture of the carbs ( and the synchronising between the carbs )
The Italians must have had better valves than the guy who came up with the bent valves story...
__________________
I met a man who's name was time, he said "I must be going"
But just how long ago that was, I have no way of knowing.
Old 03-23-2010, 08:07 PM   #16
Von Richthofen
Grenade Inspector
Von Richthofen's Avatar
Quote:
I totaly agree ..
Old 03-23-2010, 09:07 PM   #17
David Chandler
I can remember stock cars running with nothing at all for an exhaust system. Just flames belching out of the ports. They kept coming back week after week, and I doubt if they had to do a valve job every week.
That said, to me I'd think it would be a fire hazard, or at the very least some fried wires sooner or later.
Old 03-23-2010, 09:25 PM   #18
61falcon
61falcon's Avatar
if its true, how do you explain all the cars at all the dragstrips running no exhaust. just headers.
Old 03-23-2010, 09:25 PM   #19
fab32
Alliance Member
fab32's Avatar
TOTAL BULL SHIT!! With the exception of the suggestion it would be better to be able to hear any potential noises that indicate a problem.
Frank
__________________
"What we got here is failure to communicate"
Old 03-23-2010, 10:14 PM   #20
hellcat666
Grenade Inspector
hellcat666's Avatar
Mart3406
i agree that running the car like that realy isnt guna hurt it, but not necisarily tru about it not running any better, or faster, your motor will def run differntly with a full exhaust than with just open headers, running open headers can also effect you fuel air mixture. not hurt but change. dragsters and race cars are set up and have carbs that allow them to run and make most power with minimul exhaust, but if ur trying to daily drive the car, or even drive it 30 miles once a week to a cruz night, running a full exhaust would def make the car run better in this case. just my thoughts
__________________
Russ
http://summitrodandcustom.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
