Reply
Thread Tools Display Modes
Old 02-14-2005, 03:32 PM   #1
Daisyduke
Daisyduke's Avatar
Question Model A rear spring perch dimentions
Hi y'all
I'm putting a model A rear spring on my 1926 model T rpu i would like to know the width of the spring perch for the rear axle. So i can weld my brackets on.
Daisyduke
__________________
Beaters Car Club UK
offline   Reply With Quote
Old 02-14-2005, 04:30 PM   #2
Daisyduke
Daisyduke's Avatar
Default Re: Model A rear spring perch dimentions
BTT
Please need help
__________________
Beaters Car Club UK
Old 02-14-2005, 04:40 PM   #3
Dan
Senior Member
Dan's Avatar
I had a similar question in post of mine, so far the consensus seems to be 47" to center of the mounts' eyes. When done with weight on the rear end your shackles should be at a 45 degree angle so the distance may be +/- 47", I plan on just tacking mine to begin with in case I need adjustments. I also cut short sections of 3" tube to weld my brackets onto, then weld the tube to the axle, I also plan to gusset the mount to the tube
Old 02-15-2005, 03:17 AM   #4
Taildraggin
Taildraggin's Avatar
Bttt
Old 02-15-2005, 08:28 AM   #5
the-rodster
Old School HAMBer
the-rodster's Avatar
I measured a model A rear axle last night, and the distance between centers on the perches was 49 1/2". I was surprised, because I thought it would be less than say a '40 rear axle, but my '40 rear has a distance of about 47" between center points.
Hope this helps.
Rich
__________________
A good friend will bail you out of jail. A true friend will be next to you saying, Damn that was fun
Old 02-15-2005, 09:51 AM   #6
Taildraggin
That helps, Thanks. I can start getting the axle mocked up now.
Old 02-15-2005, 10:18 AM   #7
Mutt
Old School HAMBer
Mutt's Avatar
Contact Posie's - they can tell you what the distance is.
Mutt
__________________
Acme Garage Service - Usually Prompt/Often Courteous
Old 02-15-2005, 03:30 PM   #8
Daisyduke
Daisyduke's Avatar
Quote:
Mutt
how?? who are Posie's???
Daisyduke
__________________
Beaters Car Club UK
Old 02-16-2005, 09:30 AM   #9
Mutt
Old School HAMBer
Mutt's Avatar
Quote:
Daisyduke
Sorry Daisy - Posie's rod and custom makes springs and kits for hot rods. Their mounting kits come with the dimensions for mounting the brackets.
http://www.posiesrodsandcustoms.com/
Mutt
__________________
Old 02-18-2005, 02:42 PM   #10
a boner
Senior Member
a boner's Avatar
I think the distance from mount eye center to mount eye center should be 48"!!!
Old 02-18-2005, 03:45 PM   #11
orcas tow
Grenade Inspector
orcas tow's Avatar
Hi y'all
Daisyduke
My 31 A coupe rear axle perches measure 49" center to center.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
