Reply
Thread Tools Display Modes
Old 02-15-2010, 04:31 PM   #1
zgears
Senior Member
zgears's Avatar
Default 350 Chevy freeze plug problem
Photobucket
Im looking at trading for a 68 Chevy with a gm goodwrench 350. only problem is the guy says it has a leaky freeze plug. he says it always had anti freeze, and it may be poorly seated or rusted. so how hard of a fix is it? should i walk?
offline   Reply With Quote
Old 02-15-2010, 04:36 PM   #2
R Pope
Old School HAMBer
Default Re: 350 Chevy freeze plug problem
Changing the plug is easy, if you can get at it. Some are a bitch to even see! The real problem may be, did he cook the engine before he noticed the leak?
Old 02-15-2010, 04:41 PM   #3
c-10 simplex
Senior Member
c-10 simplex's Avatar
What are the terms of the trade?
Even if the truck had no engine............
Old 02-15-2010, 04:43 PM   #4
brigrat
Alliance Member
brigrat's Avatar
Which freeze plug, there are 2 behind the flex plate, motor or trans would have to be pulled if it be them..............
If it is from rust plan on pulling all of them...............
Old 02-15-2010, 04:50 PM   #5
Hackerbilt
Old School HAMBer
Hackerbilt's Avatar
I've replaced rusty ones before, also block heaters that had the O-ring fail...BUT you need to confirm its actually a freeze plug and not a cracked block.
Never take someones word on something like this. They might not be out to take you...but they could be mistaken on the source of water themselves!
Get a good light and some coveralls...you need to do some poking around.
__________________
Bill
Old 02-15-2010, 04:57 PM   #6
zgears
Senior Member
zgears's Avatar
agreed, ill be careful.
Old 02-15-2010, 04:58 PM   #7
zgears
Senior Member
zgears's Avatar
passenger side thats all i know.
Old 02-15-2010, 04:59 PM   #8
zgears
Senior Member
zgears's Avatar
1400 in trade for guns.
Old 02-15-2010, 05:01 PM   #9
ocfab
ocfab's Avatar
Quote:
i would do it!
Old 02-15-2010, 05:04 PM   #10
temper_mental
Old School HAMBer
temper_mental's Avatar
Could be a simple freeze plug to change or a cracked block it would be worth having a shop look at it.
__________________
RIP SGT Tim SANCHEZ
3/5/74 3/14/07
Thaw
http://www.youtube.com/watch?v=n43G4K_lOxA
TX mile 151
Old 02-15-2010, 05:08 PM   #11
53sled
Old School HAMBer
53sled's Avatar
could be a bottle of water glass cures it. that stuff is amazing, but bypass the heater core FIRST.
__________________
If only the good die young. I'll be here when you're gone.
Old 02-15-2010, 05:55 PM   #12
brigrat
Alliance Member
brigrat's Avatar
Go to a radiator shop or borrow a radiator pressure pump, pump it up to 12-15 lbs and crawl underneath.............................
Old 02-15-2010, 06:17 PM   #13
carcrazyjohn
Alliance Member
carcrazyjohn's Avatar
Check the cab floor and rear cab mounts first ,If all that checks out ,Id do it but there not my guns ,I could shoot somebody real easy but to run them down I don't know.
Old 02-15-2010, 06:23 PM   #14
Deuce Roadster
Deuce Roadster's Avatar
GREAT ADVICE ...
Here is a photo showing the freeze plugs on the front and the side of a engine. There are also two in the rear ( no photo )
__________________
"Whether you think that you can, or that you can't,
you are usually right." Henry Ford
Old 02-15-2010, 06:27 PM   #15
NHBandit
NHBandit's Avatar
Around here that truck would bring 1400 with NO engine. I say go for it no matter what..
online   Reply With Quote
Old 02-15-2010, 06:31 PM   #16
fergusonic
Grenade Inspector
fergusonic's Avatar
IF it is a Freeze Plug: "Passenger SIDE"...sounds like the one behind the Motor mount. Can be changed by jacking the engine up a mile....remove , measure diameter with calipers, and be sure that you purchase the correct dia BRASS one for replacement, put some sealant on outside of freeze plug before tapping it in with a correct size socket/hammer.
Around here the water has a lot of chemicals in it and so it's a good policy to put Distilled water in the system instead of tap water.
good luck
Old 02-15-2010, 06:56 PM   #17
c-10 simplex
Senior Member
i don't understand; You're paying $1400 and guns?
Old 02-15-2010, 07:06 PM   #18
Von Rigg Fink
Old School HAMBer
Von Rigg Fink's Avatar
how many guns, and what models?
__________________
Goldchainers CC S.E. Michigan Chapter
Charter Member
Some guys could fuck up free lunch.
Old 02-15-2010, 11:44 PM   #19
zgears
Senior Member
zgears's Avatar
no 1400 in guns
Old 02-15-2010, 11:59 PM   #20
Sirweesarunch
FNG
Sirweesarunch's Avatar
Go for it , whats $1400 these days when a new truck is close to $40,ooo .. if you can get the freeze plug out by knocking it in and then grabbing it with pliers to wrench it out . They sell rubber ones that are inserted and you turn a nut to swell it into the hole kind of like a row boat plug ,, same theory .. reason for the rubber one is it can be a real challenge to pound a new one in - in such a tight area ...
__________________
Answers to questions $2.00
Answers that require thought $5.00
Dumb looks are still free ..
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
