Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 12-22-2009, 10:54 PM   #1
Heckler
Grenade Inspector
Heckler's Avatar
Default Does brake fluid ruin brake pads?
Got a little sloppy when I was bleeding the brakes tonight. 53 buick, front drums......put on new wheel cylinders tonight. I have a hard pedal, but the car doesn't want to stop!
Also, when it is finally coming to a stop, it's kinda "jumpy". Like it goes 'er, er, er, errrr' (like if you were slowly pushing your finger across a wet piece of glass). Ya'll know what I'm saying, right!?
I pulled everything apart and I think I must have gotten some brake fluid onto the drum/pads - the pads have a shiny/greasy look to them.
Anyway, these damn brake shoes are expensive and will take me at least a week to get new ones.
Is there something I can use to clean up the pads? Can I sand them down a little? What do you think?
Thanks! Heckler.....
__________________
You got a joint on ya? .....well you'd be a lot cooler if you did!
offline   Reply With Quote
Old 12-22-2009, 10:56 PM   #2
Hyway Hauler
Hyway Hauler's Avatar
Default Re: Does brake fluid ruin brake pads?
Remove your drum and spray with brake cleaner. (inside of drum, and all brake parts) Your shoes are not ruined, they are just greasy.
P.S. you can buy brake cleaner at most parts store. spray parts, blow off with compressed air and repeat.
__________________
"Real Hot Rods Have 3 Pedals!"
Old 12-22-2009, 11:04 PM   #3
plym_46
Old School HAMBer
plym_46's Avatar
After the shoes have been sprayed and cleaned, do some surfacing with some emery cloth to abrade the friction material where the brake fluid got on them. If it soaks in like from a leaking wheel cylinder it will usually cause them to chatter and grab.
Clean the drums also.
__________________
If yer running a flathead, how come yer plugs are slanted????
Old 12-22-2009, 11:17 PM   #4
spununit
Grenade Inspector
spununit's Avatar
Brake fluid will not ruin the brakes, I have always used thinners to clean them, let them dry out a bit then hit them with some rough paper. You might have do it a few times if the fluid has really soaked in.
__________________
Why sure it's legal sherif, that's why they call us cow pokes!
Old 12-22-2009, 11:19 PM   #5
daliant
Grenade Inspector
daliant's Avatar
It sounds like you need new shoes. You can try to clean them with brake cleaner and sand them but they wont be 100%. Check the grease seal too while you have it apart.
Old 12-23-2009, 07:36 AM   #6
bobss396
Old School HAMBer
bobss396's Avatar
If they're just spattered, I've cleaned them with carb cleaner, lacquer thinner or brake clean. In the case of a blown wheel cylinder, I've usually replaced them.
In the interest of saving you a few bucks, I'll go with the others, clean, sand, reinstall and give 'em a try. If they still grab or stop poorly, replace the shoes.
Bob
__________________
Proud member of the "they closed my thread" HAMB crew. -- BobSS396
online   Reply With Quote
Old 12-23-2009, 08:15 AM   #7
R Pope
Old School HAMBer
After you clean them, if they still chatter, ride the brakes for a mile or so and burn the crud off. Note:clouds of smoke means too much pedal pressure!
Old 12-23-2009, 08:41 AM   #8
plym_46
Old School HAMBer
plym_46's Avatar
If you need new friction material, take a look around your area (do people remember the Yellow Pages) and look for a commercial vehicle brake shop. The will be able to remove the contamiated shoe/s and bond or rivet new material on, usually for not a lot of money. this was standard practice in the day, before people decided that they needed to discard old parts and buy new ones. The metal shoes would be cleaned and relined and the reinstalled, or swapped for ones that the shop had rebuilt and had on hand using your shoes as cores to be relined and shelved for the next guy.
__________________
Old 12-23-2009, 08:56 AM   #9
Road Runner
Senior Member
Road Runner's Avatar
I once had a leaking wheel cylinder with new brake shoes, I just installed.
Took them off and boiled them in water with dish washer detergent for 1/2 hour and it worked. They were like new again and didn't grab.
__________________
On the road every day...
1948 Chevy Coupe - 261
1952 Chevy Truck - 235
Old 12-23-2009, 09:04 AM   #10
Dave B.
Grenade Inspector
Dave B.'s Avatar
Quote:
Originally Posted by Pitts64 View Post
Brake fluid ruins linings, pitch them and get new ones... Cleaning them is impossible especially with an oil based cleaner.....
From what I've read, products like Brakleen and contact cleaners for electrical devices are chemically similar to dry cleaning fluid. [Note: this refers to the 'non-environmentally-friendly products - not the ones in the green cans!] I've used these solvents many times to clean brake pads and shoes that have been contaminated with brake fluid. I [obviously] don't have a problem with using this method, as long as the contamination was [1] recent and [2] hasn't penetrated deep into the pad/shoe.
My method is to thoroughly spray the surface of the brake material and then sponge off with a clean paper towel. Repeat until there is no visible sign of the contaminant. I've never noticed any adverse performance or pad wear using this method.
Finally, as a precaution, I always wear nitrile gloves when working with this stuff... it can't possibly be good for your hands!!
Old 12-23-2009, 05:18 PM   #11
Shaggy
Old School HAMBer
myself i'd run 'em they'll probably wear in after a bunch of miles otherwise it shouldnt cost too much to reline them
Everyone will probably hate my post, but that is my take on it
Old 12-23-2009, 05:35 PM   #12
nutajunka
Senior Member
Remember safety first, get yourself a pair of safety glasses or goggles, because that brake cleaner will set your eyes on fire or worse.........
Old 12-23-2009, 05:49 PM   #13
Shaggy
Old School HAMBer
Quote:
I'll tell ya from siphoning experience it dont taste worth a crap either
Old 12-23-2009, 05:53 PM   #14
Groucho
Groucho's Avatar
Location: 300 feet West of Burbank, SoCal-Near Burbank Airport
Clean as outlined here. But, don't forget to re-grease where the shoe drags on the backing plate (usually 3 pads per shoe). Then, any remaining contaminents should cook out from heat while driving
Old 12-23-2009, 06:20 PM   #15
Iceberg460
Iceberg460's Avatar
Should be able to clean them with lots of brake clean and air, I like to scuff them up with a red zip wheel (scotch-bright pad on a rotary tool of some kind).
__________________
Wanted: 30-31 Model A Tudor or Pickup upper door skins (beltline up), ok if they need lots of TLC.
Old 12-23-2009, 06:20 PM   #16
TIME TRAVELLER
Grenade Inspector
I've seen Speedi-Dri work in a pinch on shoes that were contaminated from a blown axle seal. Bury the shoes for a while and let the stuff leach the oil out. Cat litter might work too. However, I'd replace the shoes if they were mine.
__________________
That's as close as damn is to swearing!
Old 12-23-2009, 06:44 PM   #17
redoilman
FNG
I've would just use hot water and maybe a scothbrite pad and give them a quick scuff, rinse out the drums also.. One thing brake fluid hates and thats water! Always worked for me in the past.
Old 12-23-2009, 06:53 PM   #18
john walker
Alliance Member
john walker's Avatar
if it's just a bit on the surface from 10 minutes ago, brakekleen usually works, then sand them. otherwise, you will never get them bone dry again, so toss them. safety first, yours and everyone in your path.
__________________
www.johnwalkersworkshop.com
206 789 6800
7613 greenwood ave n
seattle, wa, 98103
Old 12-23-2009, 07:10 PM   #19
Road Runner
Senior Member
Quote:
Actually quiet the opposite - Brake fluid is hygroscopic, meaning it attracts and retains moisture.
Making it necessary to bleed the brakes on a regular basis and to not store brake fluid for a length of time, once the original seal is broken.
Water alone doesn't dissolve brake fluid.
That's why you need a detergent when washing it off your hands.
Boiling in water with detergent gets even very badly soaked linings as dry as they can be.
The detergent lifts the brake fluid and the boiling water flushes it out.
It's a very safe method, doesn't cost anything and works.
Solvents like brake cleaners, with a low flash point, don't penetrate much past the surface.
__________________
Old 12-23-2009, 07:58 PM   #20
plym49
Old School HAMBer
plym49's Avatar
First you clean your brake pads as already described.
Then you see if the pads have glazed . If so, use a rasp (there is actually a special file that is used for this, it looks like a flat rasp with teeth that look like the arced scales of a fish) to roughen them up.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
