Reply
Thread Tools Display Modes
Old 04-17-2003, 11:18 AM   #1
modernbeat
Senior Member
modernbeat's Avatar
Default Modern Axles for Ford Banjo Rearend - Redux w/ pics
Okay, so this wasn't the place to experiment with firewall settings. So, here it is again, this time with the pics hosted somewhere more reliable.
What follows is another one of those great tech features in a hard to find magazine. This one, a how to put a quick-change in a late model Sedan by adapting modern axles to an early Ford banjo rear end, has a different purpose today in this era of hefty OHV engines in our '30s Ford bodies with vintage running gear. This was taken from a November 1960 Hot Rod, so it's not exactly new-tech. NealinCA sent me this after the subject came up on the HAMB. So, without further ado, here it is...........
Quick-Change for Late Sedans
Early Ford rear axle housings, a quick-change center section and late Ford axle shafts fit together with a little ingenuity to make an ideal rear end for hot competition machines
Photo story by ERIC RICKMAN
There are a lot of pieces from Henry Ford's older models that just never lose popularity and unless we miss our guess, the one piece which will be around the longest is the '48 and earlier Ford rear axle unit. The reason for the popularity is, of course. the fact that quick-change center sections are available to fit the early Ford housings. Competition machines have to be able to vary gear ratios to fit track, tire, horsepower and driver so the quick-change will be here for a while and so will the early Ford rear axle.
Despite quick-change adaptability, there are a few drawbacks to the early Ford rear axle. Axle drive gears form the inner part of the axle shaft so the whole rear housing must be disassembled to change axles. Also, these early Ford axles have a tapered outer end that fits into a hub drum unit which is usually "mean" to remove. The hubs are not of the safety variety so if an axle breaks, the car often loses a wheel and this is not a good idea at speed. Last but not least, the axle shafts designed for early Fords just don't have enough "meat" to hold the horsepower being turned out by today's big over-head V8's.
A logical solution for competition machines all the way from dragsters to Gas sedans would be to combine the quick-change features of the early Ford axles and the easy change, safety hub, stronger axles featured in later cars. Just so happens that is exactly what we had in mind to show you. We contacted Irving Cohen at Wedge Engineering in Gardena, California, for pictures and information so here is how the job is done.
Two rear axle assemblies are needed to make the conversion, a '48 or earlier Ford unit and a '49 to early '51 Merc axle assembly. If you plan to use a quick-change center section, ratios can, of course, be varied but if a quick-change is not planned, select the gear ratio best suited for your car when buying the early axle unit. The reason for the '49 to early '51 Mere rear axle is to obtain the 5.5 inch bolt circle on the axle flange which will fit early Ford, wide-base Imperial or magnesium wheels commonly used for competition. These rear ends also use a larger outer bearing than Ford rear end axles of the same years. Ford pickups of the early fifties vintage also use the 5.5 inch bolt pattern and have the added advantage of more strength in the shaft itself so are the best for an all-out competition car.
Disassemble the two rear ends and carefully check the following parts from each. Early Ford: everything except the axle shafts, hubs, and brake assemblies. Merc or late Ford pickup: axles, axle gears, backing plates and brake assemblies. Replace any bearings or other pieces not in perfect condition. Also, the outer portions of the Merc axle housing will be needed. 'The best way to attack this item is with an acetylene torch, cutting them next to the spring seat, which will leave plenty of material for machining in a lathe.
The early Ford housings must also be cut so that the later housing flanges can be welded to them. The early housing and the late housing ends must happens be machined to give a combined length of 26.5 inches (flange to flange) so that the Merc axle shafts will fit. If a narrowed rear end is desired, this is the time to make the extra cut. The axles will then also have to be cut and resplined. The housing pieces are next welded together to form new housings for the Merc shaft. One hole on the inner end of the early housing should be positioned to align with the flat portion on the Merc outer flange so that the backing plates will be properly aligned when installed.
Next comes the job of adapting the Merc axle drive gears to the Ford ring gear and spider gear carrier. Early Ford ring gears and carrier are one piece and are hardened steel so must be annealed when machining is required. Remove carrier bearings and heat the inner part of the ring gear to a cherry red as quickly as possible so that the heat will stay toward the center of the gear. Allow to cool slowly and the gear can then be easily machined. Machining operations required on the ring gear are also needed for the other half of the carrier but it is not hardened like the ring gear so does not need to be annealed. Three cuts are needed on each piece. The center of each piece must be bored out to a diameter of 1.625 inches and a depth of approximately 15/16 inch to accept the hub of the Merc axle gear. This hole is not bored all the way through the pieces since it would leave a thinner shell to fit inside the carrier bear-ing. The second cut is to enlarge the remaining part of the bore by .020 inch so that the Mere axle shafts will slip through into the axle gears. The third cut needed is to remove .035 inch material from the inner face of the carriers against which the axle gear rides. This is necessary to spread the thicker later axle gears .070 inch wider so the early spider gears will fit between them.
Merc axle gears will not fit in the early carrier in stock form since they are approximately 3/8 inch larger in diameter than the space available. So the gears are simply ground down in diameter so that they will fit into the carrier bore with ample clearance to prevent bind. The amount removed is just about equal to the beveled amount on the back side of the gear. The reworked gears will now fit into the enlarged bores in the carrier and the early spiders, although of slightly different tooth angle and size than the axle gears, will fit between them just right.
The next step is to determine whether the differential should be locked or left unlocked. If unlocked, you are now ready for assembly but if you desire to lock them for use in an all-out drag machine, the spiders must be modified to prevent differential action. This can be done in two ways. The common method used for many years was simply to arc weld the spider gears so that they wouldn't turn. A new and better method is to install a pair of spider gears made by Wedge Engineering that have only two full teeth on each side of otherwise blank gears. The teeth lock the axle gears together while the blank area prevents turning. Only two of the four spider gears need be replaced with these special locks and they can be removed at any time should the owner wish to "unlock" the differential.
Now all that remains is to assemble and install the rear axle unit in the car. If used in a car with an open driveshaft, the front of the early Ford center section or quick-change will have to he converted by using a pickup hearing retainer or other available pieces. If used on a chassis with semi-eliptical leaf springs, pads will need to be welded to the housing at the proper spacing. Whatever the application, there is a way to make the pieces fit, and the advantages are many.
Spring perch end of early Ford housing being cut off in the
lathe. Notice that cut is made exactly at the weld point.
New perches to match car it's used under are added later.
http://www.jalopyjournal.com/forum/a...1&d=1143057216
These are the parts of '48 and earlier Ford rear end which
are saved for conversion. Note spring perches have been cut
off. However, a complete rear end is needed to start with.
This is what you need from 1949-50 or early '51 Mercury rear
end assembly. Check '51 wheel stud pattern. Only ends of axle
housing are retained. Check bearings at this time.
Thrust bearing face of ring gear must be heated to soften
surface hardening as a cut must be made across this face.
Try to confine heat to center area as much as possible.
Center of Ring gear is bored out to 1.625 inch and
approximately 15/16 deep to accept hub of Merc axle gear.
.002 to .003 inch clearance is needed here. A .035 inch cut
is taken on thrust face.
Spider gear carrier housing must also be bored to take Merc
axle gear. It needn't be heated since it hasn't been surface
hardened. Thrust bearing face was machined. Use same specs as
ring gear.
Outer diameter of the axle gears must be ground down to permit
gears to fit into carrier housing. Approximately 3/16 inch of
material is removed.
Reason for grinding the outer diameter of the gear is now
quite apparent. Free-hand grinding on a bench grinder is
sufficiently accurate. Be sure that the gear is free to
rotate in the housing.
http://www.jalopyjournal.com/forum/a...1&d=1143057441
Completed housing showing Merc bearing carrier housing end
welded to a Ford axle housing. Merc ends are cut to length
in lathe so matching faces are aligned.
The rear end assembly may be used with stock center section
and a wide range of early Ford ratios or with quick-change,
as shown. Circle of Safety retainers, featured in the April
'60 issue of HRM, are recommended. This particular installation
is in Wedge Engineering '55 Chevy two door D/Gasser; it turned
163 mph at Bonneville.
offline   Reply With Quote
Old 04-17-2003, 11:30 AM   #2
Petejoe
Old School HAMBer
Petejoe's Avatar
Default Re: Modern Axles for Ford Banjo Rearend - Redux w/ pics
Great article! thanks for sharing. Now that you have pics its time to print it out.
A Streetrod has a Smallblock up front and a can of Wax in the trunk.
A Hotrod has a Flathead up front and a box of Tools in the trunk.
Fred Offenauser
Id rather be wrenchin- than shinin
Old 04-17-2003, 08:00 PM   #3
Tman
Old School HAMBer
Tman's Avatar
Thanks for the post 'beat! I printed it off at work today. I also found a rearend, just have to tell the guy what I will pay.
Old 04-17-2003, 09:36 PM   #4
Tman
Old School HAMBer
Tman's Avatar
Deal was struck!!!!! I have a 50 Merc rearend, does it make my ass look huge?
Old 04-17-2003, 10:09 PM   #5
modernbeat
Senior Member
modernbeat's Avatar
Tman, I bought my first one for $10 as a pity purchase when a guy lured me 60 mile out of town with his story of flatheads and Merc cranks for sale. They were a big batch of barnacled and burnt blocks. Got my second (spare axles) from Honest when he decided to use the special Wilson Welding axle gears and go with slightly shorter nine-inch axles. FWIW, Honest is the one I envy.
Old 04-18-2003, 01:19 AM   #6
Tman
Old School HAMBer
Tman's Avatar
Lets just say I traded a slightly larger amount of parts for mine. I still came out OK. Deal was goo for both sides.
Old 04-18-2003, 07:52 AM   #7
atch
Old School HAMBer
atch's Avatar
ryan,
tech-o-matic, please
Old 04-18-2003, 01:59 PM   #8
hotrodA
Alliance Member
hotrodA's Avatar
Good story and pictures. I also did mine, but with 28 spline late Ford axles and bearing cups.
Used the same procedures. One tip though, if you cut the ring gear with a carbide tool, it saves
heating it to anneal it. Somewhere I have a disk with the newer feature on it as well as a cross
sectional drawing of the spider carrier dimensions, if anyone's interested. Thanks for sharing the article.
Old 04-18-2003, 02:12 PM   #9
NealinCA
Alliance Member
NealinCA's Avatar
[ QUOTE ]
[/ QUOTE ]
Thanks for the tip on the ring gear/Carbide cutter. That part had me a little concerned.
[ QUOTE ]
[/ QUOTE ]
I heve the parts to do the 50 Merc conversion, but I would be interested in the late model conversion as well.
Neal
BTW, Modernbeat - I am glad you got the copy OK. Thanks for taking the time to make it available to everyone.
Old 04-18-2003, 08:34 PM   #10
modernbeat
Senior Member
modernbeat's Avatar
HotrodA, what axle gears are you using? I'd love to be able to do the conversion on the next one with nine-inch axles instead of the Merc axles.
Yeah, sorry Neal, I should have sent you a message that I got it. I appreciate you sending me the info.
Old 04-19-2003, 10:35 AM   #11
hotrodA
Alliance Member
hotrodA's Avatar
I used the 28 spline late model Ford axle gears, ground down. The late model stuff was from a 69 Cougar. Still looking for the disc and pics. Been on the road for 8 years with no problems.
Old 09-07-2003, 04:53 PM   #12
modernbeat
Senior Member
modernbeat's Avatar
Tech-O-Matic please...
Old 09-07-2003, 05:20 PM   #13
Unkl Ian
Old School HAMBer
Unkl Ian's Avatar
Location: Just past the corner of Hell and The Twilight Zone.
[ QUOTE ]
[/ QUOTE ] Carbide wasn't readily available in 1960.Now they are dirt cheap,compared to all the time and hassles they can save.Might as well use technology when we can.
Old 02-03-2004, 06:43 PM   #14
modernbeat
Senior Member
modernbeat's Avatar
BTTT
Tech Time for this....
Old 02-03-2004, 06:50 PM   #15
NortonG
NortonG's Avatar
This defenitly needs to be in the tech o matic. I'm not to this stage with my car yet but it will be good to have around.
Old 02-03-2004, 06:56 PM   #16
Elrusto
Senior Member
Elrusto's Avatar
Oh yeah, definatly tech worthy!!!
Old 02-04-2004, 10:47 AM   #17
raven
Alliance Member
raven's Avatar
Is it possible to cut off the ends of an 8" or 9" and weld them to the tubes?
Then shortend and re-spline the later model axles?
Has anyone done this?
Pics, procedures?
r
Old 02-04-2004, 11:23 AM   #18
Paul
Editor
Paul's Avatar
great post!
that kiddies, is traditional hot rodding.
Old 02-04-2004, 11:57 AM   #19
Steve
nice article thanks. if you go to homepage.mac.com/s_kraemer I have scans of an article from street rodder on basically the same conversion. they are labeled wrong the say 9in in banjo but its not its the 49 merc axles.
Old 03-22-2006, 12:02 PM   #20
modernbeat
Senior Member
modernbeat's Avatar
Update links to images...
Click image for larger version
ID:	847758   Click image for larger version
ID:	847759   Click image for larger version
ID:	847761   Click image for larger version
ID:	847762   Click image for larger version
ID:	847764   Click image for larger version
ID:	847765   Click image for larger version
ID:	847767   Click image for larger version
ID:	847768   Click image for larger version
__________________
Ex nemo non fesces.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
