Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Alliance Vendor
Only works if part is off the motor, but I remove frozen studs, bolts and stuff like that from aluminum by throwing it in my nitric tank.
Eats the steel in a few hours and doesn't attack the aluminum. So if you got an old aluminum part with a stuck bolt find your local plater, he'll get it out. |
#2 |
Alliance Member
Good information to know. Thanks for posting it.
Frank
__________________
"What we got here is failure to communicate" |
#3 |
Old School HAMBer
Yes, cool tip! Check yer PMs in a bit. I have a question.
#4 |
Old School HAMBer
I've had good luck with a little heat, either from a heat gun or small torch. I got all the plugs out of a set of aluminum heads that had been sitting off the car for 30+ years by soaking them with some penetrant for a couple hours and using a heat gun on them.
__________________
Just tuned my car now she really peels lookin' real tough with chrome reversed wheels |
#5 |
Alliance Vendor
I've also seen a cool trick where the part ( a sump plug) was warmed with a torch and then wax from a crayon put on it, as it cooled I guess the wax must have got into the thread, or something, but the plug came out easy.
#6 | |
Grenade Inspector
Quote:
__________________
I don't hate kids I just feel better when they are not around www.crowncycleco.com |
#7 | |
Tech Editor
Quote:
__________________
Daddy always said, If yer gonna be dumb, ya gotta be tough! - And I'm one tough sumbitch! T5 Tech |
#8 |
Alliance Member
Wax works killer for getting stuck stuff unstuck. I didn't believe it untill I tried it. Now I'm one of the converted
__________________
I don't always like Ford, but I'll always be a Mel fan. FOUND: Mopar 3 speed overdrive, thanks to the HAMB
| Thread Tools | |
| Display Modes | |
