Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
I was talking to a buddy of mine this morning and he told me that he had picked up what he thought was an old 56 or 57 Chrysler that has a Polydine engine in it. Seems like I remember that they could be converted to hemi heads without too many problems. He said that the engine was running and the old car was solid, was asking $1,500.00 for it. Is that a reasonable price? What cubic inch would that engine be, 331, or 354? Any info would be appreciated.
Thanks.
__________________
Adios Amigos |
#2 | |
Grenade Inspector
Quote:
I just sold a 66 Plymouth with the 318 Poly (last year it was ever used) and with a 4 speed and flowmasters it went and sounded great.
__________________
Even if you're on the right track, you'll get run over if you just sit there. |
#3 |
Old School HAMBer
The Chrysler Polysphere engine was cheaper alternative to the Hemi. The Polysphere heads use one rocker shaft per head rather than two. Hemi heads will bolt onto a Polysphere because the block is basically the same. Note the spelling.
__________________
She's wearin' new colors and runnin' pretty good I got four hundred horses tucked under the hood. |
#4 |
Old School HAMBer
Location: Well south of where the Amish live in Michigan.
There's a site, http://www.1962to1965mopar.ornocar.com/poly318.html that gives soup up info... seem to be a pretty stout motor. My little bro had one someone gave him thinking it was a "regular" 318 when we were "kids". Wish I'da kept it.
I'd be interested in engine pix if you go to look at it. Jay
__________________
My other car is an Amish Drag Buggy. "Hold that nitro- we're gonna cut a rug!" |
#5 |
Old School HAMBer
The polysphere Aka poly was 331 in56 &354 in 57.Those built Through 58 were built on hemi blocks & can be converted by changing heads, pushrods, & pistons.$1500 seems steep considering the additional scrounging. TWJoice's comments have a good point, the polys were totally ignored because of its bro. the Hemi. You will almost be guarenteed to be the only one at an event, & all the 55 -58 intakes (mild to wild) will fit. The design is a canted valve simular to the Ford Clevelands
#6 |
Old School HAMBer
The Plymouth Polysphere engine is a differant animal. The Plymouth poly is the "A" series. It was transformed into the modern "LA" series (as in the 318-360) in the 1960's and later into the 360 magnum. I have done the research on this. Chrysler, Dodge, and Desoto Hemi heads will not bolt-on a Plymouth poly. The bore spacing, bolt holes, water passages, and everything else is different.
__________________
#7 |
I found a site http://www.hothemiheads.com that has a lot of good info on them. Looks like a hemi rebuild kit runs about $1,400.00 plus labor for machine work. Probably another $6-800.00 for heads and valve work, plus about $300.00 for an intake. Trans adapters are around $400.00 this looks like it's adding up pretty fast.
Found another one at a junkyard that the guy says is "mostly Comple" and will turn over. It's the old "I think I have it sold, guy is supposed to come by and give me a deposit on it today" He's wanting $1,500 for it, may go up and look at it and see if it's a 331 or a 392.
__________________
Adios Amigos |
#8 |
Old School HAMBer
Chysler, Desoto, Dodge and Plymouth all had their own OHV V8 engine development programs. The Chrysler, Desoto and Dodge hemis were twinned with Polyspherical headed engines. Plymouth had no Hemi.
There were additionaldisplacement engines for Canadian and other export markets. After 57 The Hemis were discontinued except for the Chrysler 300D and Imperial for 1958. After that no Hemi. The Poly engines continued through 58 and there may have been some in 59 The 361 B engine appeared in 58. The Chrysler 383 and the Desoto 383 both appeared in 59. These are separate designs with the same displacemnt with little in the way of parts interchange, The Chrysler design had some design faults and the Desoto 383 went on to become the venerable 383 that we all know and LUV. The 318 Poly (also know as the 318 wide block appeared in 58 in Plymouth. It was soon adopted as the corporate small block and continued in production into 1965 at least. It is a separate design from the lighter weight casting LA family 318. Are you with me so far? Dodge Polys are found in 241, 277, 315, 325 Cube displacement. Desoto's are .... hummina,,, hummina,,,,, $1500 for an incomplete mystery condition mill is quite frankly just plain silly. There aren't exactly rare, they are well built, parts take a little searching. Their production run was basicly 4-5 years, they existed in the shadow of the more exciting Hemi Engines and so there was not a great deal of performance development. Chysler quickly moved on to a more standardized designs that cost far less to produce and were lighter in weight, and then created still another design evolution. These are good engines, made with high nickel content iron. The machining was costly as well. Plus you get to explain what it is to your machinist. Only the really old crazy, batshit guys that nobody fucks with know what they are and may have even done one. I just got of the phone with a respected local guy with 25 years experience and had never heard of my 315 let alone worked on one. I would really like to talk to someone who has done a Poly. You will have to get creative. And the scalloped lower edge of the head and valve cover are unique. Please see enclosed photo of my 56 315 Poly. It was an embarassment of riches is what it was. They must have lost a lot of money doing it that way. Goddamn that Lester Colburt!
__________________
"Stops on a dime, gives nine cents change." Bill King |
#9 |
Senior Member
Thanks guys! No wonder I've been so confused about this stuff for so long - it's confusing. Now if I can just remember some of what I've read here, I might be able to have an intelligent conversation with some of my Mopar pals...This is why I'm on the HAMB...Thanks again (if this is accurate info - if not - thanks for nothin'!)........
__________________
Tyre Friars Hot Rod Gang |
#10 |
Grenade Inspector
I have a poly motor from a 58 D-500 it was a replacement for the more expensive Hemi. The block numbers can be looked up on the early Hemi site and you will find the early blocks are the same numbers as the Hemi. I was given this running 58 Dodge and the motor is the 354 block. Right now it is a two barrel but I plan on changing over to a four(same intake as the Hemi Dodge) this is a good looking motor and the standard tranny will make it all worthwhile. $1500, seems excessive and there are plenty of moters out there for far less. The cost of converting one of these is just too much.
#11 |
Old School HAMBer
354 Hemis run $500-1000. 1500 for a poly is excessive.Benzine440 your 315 poly is the same as the hemi except heads,pistons & pushrods. Go to webrodder. Doc Fromader has a buildup on a 315 Hemi on it. He uses an exotic stroker crank & cam, if you ignore that most of the rest is applicable to building your 315. Tex Smith's Hemi book goes through doing a 392, & there is a site linked to Bob Walker's Hot Head site that covers a Chr. build. Between them you should be able to get your engine done. The engine picture doesn't show well on my computer, but i'd get rid of that heavy generator & (if your staying poly) chrome those unique valve covers.
#12 |
Alliance Member
read this:
http://www.jalopyjournal.com/forum/s...ight=poly+hemi and this: http://www.jalopyjournal.com/forum/s...ight=poly+hemi and this: http://www.jalopyjournal.com/forum/s...ight=poly+hemi
__________________
I don't always like Ford, but I'll always be a Mel fan. FOUND: Mopar 3 speed overdrive, thanks to the HAMB
#13 |
Old School HAMBer
[QUOTE=Bugman]read this:
http://www.jalopyjournal.com/forum/s...ight=poly+hemi Bugman on your first link above,in the list of comentary you said the Desoto polys use Desoto hemi heads. Actually they use Dodge head assemblies on Dodge 325 CID blocks. |
#14 | |
Alliance Member
Quote:
-Jeff
__________________
#15 |
Thanks for the tips guys. I thought that the price was a little high on both the car and the motor. They are starting to get scarce around here. I looked for a 392 about 10yrs. ago and couldn't find one. There were plenty of 331, 354's and early hemi's still around but no 392's. Now there aren't hardly any Hemi's left in the local junkyards. There are still a few yards back in the mountains that I haven't hit in awhile that might have something tho. Will try to look around when the weather gets a little better and see what I can find.
__________________
Adios Amigos |
#16 | |
Quote:
#17 |
As Far As Plymouth's Go, 56 Would Be The 277 Poly (the Little Brother Of The 318) The In 57 The Turned Into The Poly 318
__________________
YA, WELL I DON'T LIKE YOU EITHER. |
#18 | |
Old School HAMBer
Quote:
#19 | |
Old School HAMBer
Quote:
BobK put some up that looked damn cool, but weren't whaat I was looking for. Jay
__________________
#20 | |
Old School HAMBer
Quote:
__________________
| Thread Tools | |
| Display Modes | |
