Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 11-20-2009, 09:23 AM   #1
Streetwerkz
Streetwerkz's Avatar
Default Streetwerkz 30 sedan build
Finally have gotten time to start this project, I hope it stays on course.
It's a 1930 Ford Sedan
Goals for the project are to keep designs, and architecture from the 1930's, 40's, and 50's in mind during the build.
make the vehicle modern enough to be safe, and reliable.. not too modern
Kustomize just enough, and not to much
lots of Horse Power
109" wheel base
traditional front suspension
chopped, channeled
who knows what else.... we'll play alot of it by ear as we go
Heres what we started with, I bought it off ebay, and supposed to be a 60's chop on it. Which I believe cause they did a horrible job, I'm sure it was gonna have a mile of lead in it
Click image for larger version
ID:	820527   Click image for larger version
ID:	820528   Click image for larger version
__________________
www.STREETWERKZ.com
Custom Powder Coating & Media Blasting
My Build http://www.jalopyjournal.com/forum/s...d.php?t=419718
offline   Reply With Quote
Old 11-20-2009, 09:40 AM   #2
Streetwerkz
Default Re: Streetwerkz 30 sedan build
blew it apart to find out what needs replaced, try to figure out how to fix what's been done wrong
then built a simple jig to hold the cowl so I could start repairs
ID:	820544   Click image for larger version
ID:	820545   Click image for larger version
ID:	820547   Click image for larger version
ID:	820548   Click image for larger version
__________________
www.STREETWERKZ.com
Old 11-20-2009, 09:42 AM   #3
Streetwerkz
I was going to cut up the gas tank (which was good) for more room up front,
traded a buddy for one that had already been cut on so he could have my old one to use.
cut the bottom out, got it mounted
then cut out the lower cowl's and cleco'd in the patches
ID:	820552   Click image for larger version
ID:	820553   Click image for larger version
ID:	820555   Click image for larger version
__________________
www.STREETWERKZ.com
Old 11-20-2009, 09:44 AM   #4
Streetwerkz
next I started on the dash
I wanted something with style, and personality.
So I found a dash out of a 50 Chevy sedan, and knew where it belonged
thank god the face of the dash if nice and flat, made lay out a dream.
had to take 9 5/8" out of the dash, took 2" off each end, and the balance out of the glove box.
cut her up, and got about half way threw fit up when I realized it was 10 pm, because my internal clock said go home lol
I love it!
ID:	820557   Click image for larger version
ID:	820558   Click image for larger version
ID:	820560   Click image for larger version
ID:	820561   Click image for larger version
__________________
www.STREETWERKZ.com
Old 11-20-2009, 09:46 AM   #5
chris55
Senior Member
chris55's Avatar
looking good
__________________
Originally Posted by breeder
i bet your own reflection thinks your an asshat!
Old 11-20-2009, 04:00 PM   #6
sawbuck
Alliance Member
sawbuck's Avatar
yup, looks great... that dash is gonna look cool in there
__________________
its not how fast you go....its how you get there...
Old 11-21-2009, 07:44 AM   #7
Streetwerkz
thanks,
I'm excited, be scrounging parts for a while so I could get started.
it's nice to finally make some progress
__________________
www.STREETWERKZ.com
Old 11-21-2009, 08:43 AM   #8
shadetreerodder
Grenade Inspector
shadetreerodder's Avatar
Cut weld repeat. Good job so far. Keep up the good work.
__________________
Real Hot Rods have three pedals.
Romans 8-14
Crossmembers CC / HAMB Chapel
Old 11-21-2009, 08:49 AM   #9
Cshabang
Senior Member
Cshabang's Avatar
body looks pretty good..If its a 60's chop..then its probably gas welded...so you may be able to hammer and dolly that stuff pretty straight....In my opinion, the 112-116 wheelbase may look a tad too long...good luck, keep us posted!
__________________
BANG ZOOM, ITS NOT ROCKET SURGERY..
Would I be bitching if i said i was sick of people BITCHING?
Old 11-21-2009, 06:47 PM   #10
Streetwerkz
not much done today, as I had a guest drop off a project that took a while to go over
needed to add some inner structure support, so I made this out of 1/4" X 2" bar stock, then gusseted the ends.
hard to believe this little bracket took about 2 hours to make
I had to first measure the radius of the gas tank so I could match it, and then bend the ends down, and add gussets at the ends for strength.
befor, the area where the bolts are
cut the bar stock, measured the radius, rolled it to form, then bent on the ends, and matched hole locations
Added gussets on the ends, and welded into place
So now I have more over all strength, and a lip to werk from for the new dash
ID:	821907   Click image for larger version
ID:	821908   Click image for larger version
ID:	821910   Click image for larger version
__________________
www.STREETWERKZ.com
Old 11-21-2009, 06:47 PM   #11
Streetwerkz
then I finished out the cad, and cut out my base for the motor mount from 3/8" steel
__________________
www.STREETWERKZ.com
Old 12-03-2009, 04:22 PM   #12
floored
Grenade Inspector
floored's Avatar
I just found this, let's keep it going. Any progress?
__________________
Never do today what you can put off 'till tomorrow, or something like that.
Old 12-03-2009, 04:39 PM   #13
JohnnyFast
JohnnyFast's Avatar
Location: Duluth, MN (Hey, Al....where's that global warming ?)
Was that front mount cut from the drawing I posted here ?
__________________
JohnnyFast (aka SJFast)
Fenders ? We don't need no stinking fenders !!
Old 12-04-2009, 07:51 AM   #14
Streetwerkz
not much lately due to holiday, and werking on a project for Ian Johnson of Extreme 4X4 for Crawl magazine.
Hope to get back to it this week end
Yes JohnnyFast I used the file from the HAMB tech section, and lengthened it a few inch's.
Saved me some cad time, THANKS!!
very nice file, easy to werk with, and cut awesomely
__________________
www.STREETWERKZ.com
Old 02-01-2010, 07:45 PM   #15
Streetwerkz
Been werking a hour here and there after the shop closes this past week... here's and update
Was going to fix the old fire wall, but then I had the opportunity to do werk for a brookville dealer, and struck up a trade
got a new firewall, toe boards, and front x-member for the frame for some blasting and Powder coating.... love me some trading!!!
started rebuilding the doors while I decide what to do about the cowl sides
ID:	887883   Click image for larger version
ID:	887884   Click image for larger version
__________________
www.STREETWERKZ.com
Old 02-01-2010, 07:49 PM   #16
hvychvy
Senior Member
hvychvy's Avatar
Lookin great!!
Old 02-01-2010, 09:11 PM   #17
JKerb
Newbie
JKerb's Avatar
Lookin good. I like the dash.
Old 02-02-2010, 07:44 AM   #18
Streetwerkz
Thanks
I can't wait to finish the dash, I quickly realized that befor I could go any further I had to square up the body, and fix the doors.
the way it always goes, have to do 20 other things, befor you can do the 1 you want lol
__________________
www.STREETWERKZ.com
Old 02-02-2010, 09:21 AM   #19
inkmunky
Quote:
Originally Posted by Streetwerkz View Post
Thanks
You don't HAVE to do it that way, you could do the thing you want then do it over again after you did the 20 things you shouldve done first
Looks awesome man cant wait to see whats in store for the frame/motor setup.
Old 02-03-2010, 07:53 AM   #20
Streetwerkz
the motor... a left over from another project... nothing special
Chevy 454
__________________
www.STREETWERKZ.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
