Reply
Thread Tools Display Modes
Old 11-15-2009, 08:28 AM   #1
porkchop4464
Default 700 r4 wiring,help,please!
Hey all,
Am I understanding it correctly, that if I wire the red or (A) of the three pins on the 700 , then daisey chain or loop the red to blue and then white, with a cut switch on the brake pedal on the blue wire, that this is the easiest and cheapest way to wire a 700? I don't need a lock up converter in any gear but 4, and I also would be fine to lock this thing up with a single toggle on the dash (on and off). There looks like there are 4 pins, but there are only three on the 700 r4, right? I need it explained in teh crudest and simplest way. All help will be grealty appreciated. I see all these kits, and I don't want to spend 60 bucks and pull teh pan and re-wire and bla, bla, when , if there is a single wire or two combined with a switch that can solve this deal. Any pros or people who have roughed it through not buying a kit and figuring this beast out - please help.
the Pork
offline   Reply With Quote
Old 11-15-2009, 08:54 AM   #2
powdercoater46
Grenade Inspector
powdercoater46's Avatar
Default Re: 700 r4 wiring,help,please!
You only need to put 12 v on one wire, controlled by a toggle switch. You will have to manually switch it off when u plan to slow to a stop. This is the low budget way.
I'll have to look at a diagram in the garage to tell u which wire gets the 12v.
Old 11-15-2009, 09:25 AM   #3
troylee
troylee's Avatar
Instead of a toggle switch Yoou can use a 2 pole brake switch at the peadle. A hyd brake light switched plumed in with a light relay Is what I use. You can get all the parts for under 20 bucks. You mite be able to piggy back off the brake light switch you already have into the relay.
Old 11-15-2009, 10:06 AM   #4
Von Rigg Fink
Old School HAMBer
Von Rigg Fink's Avatar
Quote:
this is what i want to do.
you have a part number for the light relay or would any 2 pole relay work?
what happens when you just take your foot off the accelerator for a long period in lock out and not touch the brake pedal? Does the TV cable tell the trans to unlock the converter?
__________________
Goldchainers CC S.E. Michigan Chapter
Charter Member
Some guys could fuck up free lunch.
Old 11-15-2009, 10:23 AM   #5
Zombie Hot Rod
Senior Member
Zombie Hot Rod's Avatar
http://www.thehotrodcompany.com/shop...ct_id=RW%5F700
This style runs off of a pressure switch that you install into the side of the transmission. It's still $60 bucks, but you don't have to take the pan off to install it.
__________________
- brian
www.AtomicHotRods.com <----- "Psssst, Hot Rod Documentaries and T-Shirts over here."
Old 08-16-2010, 08:16 PM   #6
345 DeSoto
Senior Member
345 DeSoto's Avatar
Location: Summer Skaneateles,NY/Winter Port St.Lucie, FL
If I get this type of switch, will it lock the TC in 4th gear automaticaly? What needs to be done to get the TC to unlock...or does this switch do both functions automatically?...
Click image for larger version
Old 08-17-2010, 06:55 AM   #7
345 DeSoto
Senior Member
345 DeSoto's Avatar
anybody?...
Old 08-17-2010, 08:52 AM   #8
hoop
hoop's Avatar
As soon as you start to slow down enough trans downshifts as soon as that happens converter unlocks.
__________________
HOOP
Old 08-17-2010, 09:50 AM   #9
dare-to-be-different
dare-to-be-different's Avatar
Quote:
If you take the wiring in your picture (posting #6) and interrupt one wire with a toggle switch on the dash, you can force it to stay unlocked no matter what.
Even if the trans or the "control kit" wants the convertor locked, you can prevent that with the added switch so you can keep it unlocked if you choose.
- your question implies that you may want to run in 4th without being forced to accept the convertor being locked. correct? (I run unlocked almost all the time)
That was your question wasn't it?
__________________
Some people like to relax in a leather recliner,
but to others there is nothing better than cardboard
...on concrete. Valvoline commercial.
[SIGPIC][/SIGPIC]
Old 08-17-2010, 01:03 PM   #10
345 DeSoto
Senior Member
345 DeSoto's Avatar
DARE-TO-BE-DIFFERANT - No, what I'm wondering is if the converter will lock and unlock in a normal manner...by itself, at the appropriate time...
Old 08-17-2010, 01:50 PM   #11
JAWS
Senior Member
JAWS's Avatar
Credit goes to smoke em up site.
__________________
http://vagabonds.cc/
Old 08-17-2010, 06:56 PM   #12
What's an apropriate time?
Each and every kit or method has a different idea of what is apropriate.
It sounds like you are asking for one of the really expensive kits that does everything without any driver input. Try B&M.
__________________
[SIGPIC][/SIGPIC]
Old 08-17-2010, 07:45 PM   #13
fiftyv8
Old School HAMBer
fiftyv8's Avatar
Great stuff...
__________________
THE MORE YOU LEARN, THE MORE YOUR REALISE YOU DONT KNOW!
Old 08-17-2010, 08:51 PM   #14
Rob Paul
Senior Member
Rob Paul's Avatar
On this kit the blask wire runs to the pressure switch, but where does the red wire go? DOes it just get power when the key is on?
ROB
Old 08-18-2010, 06:20 AM   #15
345 DeSoto
Senior Member
345 DeSoto's Avatar
Black is to ground, red is to 12V "Ignition On"...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
