Shaved side wall ?????
Discussion in 'The Hokey Ass Message Board' started by da34guy, Oct 28, 2009.
  1. Any body got a good trick to shave the side walls on tires ?
    Gettin the lettering off is what I mean
    Thanx
  2. chaddilac
    chaddilac
    Just use a flap disc on a grinder... the higher grit you go the smoother it'll get.
  3. FiddyEffie
    FiddyEffie
    i'd use a DA, a grinder has too much weight on it, i've tried haha the sidewall ends up very wavy
  4. chaddilac
    chaddilac
    it takes a gentle hand!!:D
  5. Drive Em
    Drive Em
    Here is a post I did on the Hamb a few months ago:
    My '64 Galaxie is built to look like a 60's stock car would look like. I am using modern Bf Goodrich radials for a nice ride, but the blackwall lettering does not look right, and it really bothered me. My solution was to sand the sidewalls smooth to get a nice un-cluttered sidewall. A little experimenting on an old tire led to this process shown here.
    You will need a dual action or "DA" sander, and a few discs of 80 grit paper. This process will not harm the tire in any way, as I have done it on several cars now with great results:
    Here is the tire with all the lettering visible:
    I leave the air in the tire as it it far easier than sanding on an un-inflated tire. If you have some really nice wheels, you may chose to mount them on some junk wheels just in case you slip with the sander and end up sanding your wheels. You really don't want to get right up next to the rim, so just be careful.
    You basically start sanding on the lettering, and let the sander do the work until the lettering is gone:
    This is the progress after about a minute:
    This is after a few more minutes. You want to sand down until the letters are gone and no more, though it is really hard to do any damage to the sidewall using the "DA". I go ahead and lightly sand all the way around the sidewall so it all has the same texture, which ends up nice and smooth:
    I removed all the raised lettering, but chose to keep the tire size, serial numbers and well as the D.O.T. markings, though you can remove it all for a really smooth look. The edge against the wheel needs to be gone over with some Scotchbrite to knock the glaze off and give a nice uniform appearance:
    shoebirdgal likes this.
  6. texas56
    texas56
    Iver heard of doing it with a grinder, there are some videos online you can search for that show you how. It is tuff to get them to look good though I hear. I just had these done last week and the tire show that did them has a machine that kinda looks like a bench grider. The guy that did it told me it took him 15 years to get good at it.YOu cant even tell these are done. Came out really nice.Only cost 100 bucks for the set to get it done but well worth it.
  7. Larry T
    Larry T
    I did it about the same way as DriveEm. Used a die grinder (cut back the speed) and USED Rotoloc discs. Finished it off by block sanding by hand. It was a pain in the butt, but I like the finished look.
    Larry T
  8. flynbrian48
    flynbrian48
    To make el cheapo wide whites, I use a 36 gr. disk on the 7" grinder, then follow that up with 80gr. on the DA, and finish with 120. Second the leaving the tire on the rim, aired up. Balance them after shaving. Light truck white lettered tires yield nice big whitewalls. Just cleaning up the goofy lettering, leave the grinder part out and use the DA.
  9. neverliftmotorsports
    Do like a lot of women drive the damn car down the curb for a couple miles.
  10. gafridge
    gafridge
    <!-- / message --> <!-- sig --> ____ That was just wrong,although just about an hour ago,I saw a women in an Expedition_that had two wide whites on the right side because of this.____________
  11. 65PANELRAT
    65PANELRAT
    lmfao!:d
  12. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    I been getting them from Diamond Back. A little more money but they do them everyday.
  13. Shaggy
    Shaggy
    from Sultan, WA
    Do burnoffs against curbs!
  14. zzford
    zzford
    I've had good luck with some EDGE and a Gillette razor on my face, might it not work on a tire?
  15. az67goat
    az67goat
    from Mesa, AZ
    What's Diamond Back??
  16. Von Rigg Fink
    Von Rigg Fink
    from Garage
    A Tire Manufacture;)
  17. H3O
    H3O
    da with 220 will take a while but will do it. 80 grit for most of the work and go to 180-220 to finish it.
  18. dirty old man
    dirty old man
    Will this work with a raised white letter tire to make a blackwall? There are several tires on the market that are about what I want in size, both width and O.D.,and at a ecent price, but they have raised white letters, and those don't look right on what I'm building.
    Dave
  19. Drive Em
    Drive Em
    No, if you start grinding on raised white letters, you end up with a whitewall.
  20. zimm
    zimm
    from iowa
    cool thanks for posting
  21. nickleone
    nickleone
    From Street Rod Builder June 2006.
    Nick
  22. nickleone
    nickleone
    Forgot to post page 2 from the sidewall article
