Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 09-01-2009, 11:24 PM   #1
jmcglynn
Alliance Vendor
Default Covell Extreme Metalshaping Class
Last weekend I attended Ron Covell's "Extreme Metalshapinig" class. I thought I'd share some pictures and some pointers I picked up.
The class was hosted by Cotati Speed Shop. I've seen their work, and it's always beautiful, their shop was very impressive too. First class operation.
The plan for the class was to see a scaled-down 37 Ford-style fender and flush-fit skirt fabricated from scratch. Without giving it all away in the first breath, let's just say that Ron didn't disappoint!
offline   Reply With Quote
Old 09-01-2009, 11:35 PM   #2
jmcglynn
Alliance Vendor
Default Re: Covell Extreme Metalshaping Class
Ron began by explaining the "basics" of metal shaping, having been to other metal shaping workshops before I have to say Ron got the key information across with no muss and no fuss.
In a nutshell, there are only 2 things that you can do to shape a piece of metal: shrink it or stretch it. Folding/bending will change the geometry of a part, but it doesn't create "shape" -- compound curves.
Ron explained it better than I can, and he had a couple of good visual aids to make the point.
With that out of the way, Ron talked about the project for the weekend. For the workshop he used a combination buck/hammerform that he had constructed. He also spent time explaining how you could make a flush-fit skirt without a buck, to fit an existing fender.
He talked about the important details of the buck construction, and alternate approaches.
One of the keys to developing the bucks he used for the fender and skirt is planning in the correct clearance between the edge of the fender opening and the edge of the skirt.
Old 09-01-2009, 11:39 PM   #3
jmcglynn
Alliance Vendor
Why is this both a buck and a hammerform?
A buck is just a form that describes the shape of a part so that you can shape metal to fit it. It could be made from sheetmetal sections, wood, steel rod and probably 100 other things.
A hammerform is a rugged form that you hammer the metal over (or into) to actually create a shape.
The buck Ron made includes steel inserts which are used to directly form the edges of the fender opening and the skirt opening after the metal is shaped to fit the buck.
You can see the steel flat bar around the fender opening, and if you look closely you can see some 5/8" round bar that is used to form the bottom edges of the fender.
Old 09-01-2009, 11:47 PM   #4
jmcglynn
Alliance Vendor
One really important point Ron talked about (it was important for me, because I forget to think this through sometimes when I make a paper pattern for a shaped part) is to make the pattern accounting for how the part will be shaped.
I don't have a good visual, but I'll try to describe it.
On this fender, if you make the pattern for part of the fender by pinninig the paper to an edge of the buck (say the fender opening) and then pull it down to the top edge you will have to form the part my shrinking the top edge severely, pulling the metal down in the same way.
If you pattern it by laying the paper against the high point of the shape and pulling the edges down to meet the top of the fender and the wheel opening then you can shape the part by shrinking booth edges and stretching the middle. That way the shaping work is spread "evenly" across the panel.
Old 09-01-2009, 11:51 PM   #5
jmcglynn
Alliance Vendor
Here Ron is using a Lancaster-style shrinker to, well, shrink the edges. You can see the blue lines on the part, this is the area Ron intends to shrink.
Ron also talked about how to divide the part into separate panels for shaping, and the pros/cons of putting the seam(s) in different spots. For this fender he's making it in two parts (not counting the skirt). If you have less experience/confidence you might make it in 3 parts.
Old 09-01-2009, 11:54 PM   #6
jmcglynn
Alliance Vendor
After about two passes on the shrinker on each edge Ron test fit the part to the buck. What he's checking is not that it fits the buck at this point, but he's trying to judge whether he's done enough shrinking. Looking at the angle of the edges he deemed it far enough.
Also, look at the white board in the background. See the diagram in the bottom left whith the green marker? That is a cross section of the fender (in blue) showing how the metal will be progressively shrunken on the edges and stretched in the middle to shape the part.
Old 09-01-2009, 11:59 PM   #7
jmcglynn
Alliance Vendor
After shrinking, Ron used an English Wheel to stretch the middle of the panel. You could also do this part (the stretching) using a ball-faced mallet and sandbag. The advantage of the wheel is that it reduces the amount of metalfinishing/smoothing later and it's not as hard on the joints.
Old 09-02-2009, 12:03 AM   #8
jmcglynn
Alliance Vendor
Here is a great e-wheel tip: Cross up your wheeling patterns. Think of it like block sanding. When Ron and I wheeled the top insert for my Stude pickup (on the "Chopping and Sectioning" video he sells) we did that and it really helps maintain a smooth surface and an even shape.
The first pass on this part Ron did at about 30 degrees to the long direction. This is the second pass, crossing the first pass at 90 degrees.
Also, you want to use the flattest wheel you can that will fit the curve of the panel you're making. More sharply curved wheels shape faster, but they also leave more marks (tracks) in the part.
Old 09-02-2009, 12:07 AM   #9
jmcglynn
Alliance Vendor
Here is the third angle of attack on this part, side to side across the short dimension of the panel. If you compare this wheel with the one in the first e-wheel picture you can see he's moved to a flatter wheel (because it fits when wheeling in this direction). He's also blending into the shrunken areas along the edges.
The shaping process involves repeated checking of the part on the buck to make sure everything is moving in the right direction. When you find an area of the panel hitting the buck either it needs to be raised (wheel it) or everything around it needs to be shrunk.
Old 09-02-2009, 12:10 AM   #10
jmcglynn
Alliance Vendor
If you over-stretch a small area it is possible to "cold shrink" it by working it with a slapper over the buck. You'll probably put in some kinks in the process, but they can be worked out with a little careful hammer/dolly work. Just make sure you don't stretch it again!
Old 09-02-2009, 12:15 AM   #11
jmcglynn
Alliance Vendor
Ron fit both panels to the fender buck, and scribed a line where they overlapped. The bottom panel was trimmed on this line, and the two panels were tacked together. Ron went into a lot of detail about the proper fit and welding technique.
He TIG welded the joint, then used an air planishing hammer to smooth the weld. There was almost to weld bead (maybe 1/2 the thickness of the base metal?) and the weld hammered out perfectly flat and glass smooth.
This planishing hammer is one of Clay Cook's "Proline" tools, it's really a nice piece.
Old 09-02-2009, 12:18 AM   #12
jmcglynn
Alliance Vendor
Ron did some wheeling and hammer-and-dolly work to make sure the transition (the takeoff) between the panels was a smooth curve. He also tuned up the edges of the fender.
He fit the fender to the buck, and scribed a trim line around the perimeter. The trim line is offset from the edge of the buck to leave the right amount of metal for rolling the edges over.
Old 09-02-2009, 12:19 AM   #13
jmcglynn
Alliance Vendor
The fender is clamped to the buck and the wheel opening is hammer-formed.
Old 09-02-2009, 12:20 AM   #14
jmcglynn
Alliance Vendor
Here is a close-up of the hammer forming process.
Ron was careful to select a hammer with a face that fits into the curve of the opening.
Old 09-02-2009, 12:22 AM   #15
jmcglynn
Alliance Vendor
Then Ron rolled the bottom edges of the fender over the 5/8" round rod on the buck.
Old 09-02-2009, 12:25 AM   #16
jmcglynn
Alliance Vendor
There are two things to take note of in this picture.
First Ron is using wood blocks to clamp against the outside of the fender to keep from marring it.
More importantly, notice that on this tightly curved flange he started by forming the ends first, then he moved on to the middle. Rolling the ends like this locks the edge in place so the edge of the fender doesn't deform as he forms the roll.
Old 09-02-2009, 12:26 AM   #17
jmcglynn
Alliance Vendor
Here is the bottom front of the fender rolled over.
Old 09-02-2009, 12:33 AM   #18
beater32
Grenade Inspector
beater32's Avatar
Bloody awesome.Thanks for taking the time to post!
Old 09-02-2009, 12:33 AM   #19
jmcglynn
Alliance Vendor
Next Ron moved on to a very detailed explanation/demo of "metal finishing".
This is a process where all of the lumps and bumps are smoothed out so that the fender is as smooth and true as possible.
A key point is to be able to solidly position the fender so that it doesn't move as you work on it. You can't do good work if you're chasing the part all over. Ron has the two back edges clamped solidly to the bench, and two sandbags holding it down.
This process depends on several factors -- being able to "read" the panel and identify what needs to be changed (low spots and high spots). It also depends on proper hammer and dolly technique and know the difference between on-dolly and off-dolly hammering (and when to use which one)
(the book by Frank Sargent "a guide to metal bumping" covers this pretty well as I recall. Eastwood used to sell it)
Old 09-02-2009, 12:37 AM   #20
jmcglynn
Alliance Vendor
The wood clamp strip made a few indentations in this area of the fender. Ron started by hammering off-dolly (holding the hammer tight against a large low spot and tapping down the surrounding high spots.
In some cases where there was a low spot in a neutral area Ron would hammer on-dolly (you can tell because of the distinctive ring of the hammer hitting the the dolly through the sheetmetal)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
